| Manufacturers Service and Support Mitsubishi WS-55807 red conv. problem for first few secondsDiscuss Mitsubishi WS-55807 red conv. problem for first few seconds in the Home Theater | Audio and Video forum; Mitsubishi WS-55807 red conv. problem for first few seconds I have a Mitsubishi WS-55807, about 7 years old. A problem just delevloped when you first turn it on the ... |
| | #1 (Link) | |||
| Mitsubishi WS-55807 red conv. problem for first few seconds I have a Mitsubishi WS-55807, about 7 years old. A problem just delevloped when you first turn it on the red convergence is off. Basically about 1" lower than it should be (double text, bad pic). After anywhere from 5-30 seconds it just fixes itself. Been doing it for about a week now. Any info on what to check? I'm thinking something mechanical sticking, but I guess it could be a bad solder joint.... Thanks in Advance | |||
| | #2 (Link) | |||
| Re: Mitsubishi WS-55807 red conv. problem for first few seconds Bad solder joint on the red convergence output channel would be most likely. Could be a bad IC or corrosion from a coolant leak as well on that model. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| mitsubishi hd 1080 red and green shadows | kmacgrego | Manufacturers Service and Support | 50 | 06-12-08 06:25 PM |
| Mitsubishi WS-55511 Red Convergence | sasquachh | Manufacturers Service and Support | 1 | 12-31-07 11:28 AM |
| Mitsubishi WS-55807 | c`lan | Manufacturers Service and Support | 7 | 12-05-07 12:59 PM |
| Mitsubishi HD1080 TV. Red and Green Shadows. | aqad786 | Manufacturers Service and Support | 12 | 11-20-07 01:46 AM |
| mitsubishi model #vs-60609 red and green shadow pic | deltex | Manufacturers Service and Support | 1 | 09-23-07 07:20 PM |
