Sony 53XBR45 Turn-On Issue - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Sony
Sony
Discuss Sony 53XBR45 Turn-On Issue in the Brand Specific Service Forums forum; Sony 53XBR45 Turn-On Issue I have a Sony 53XBR45 that works perfectly ... outstanding picture, all remote functions work, etc. => it's as good ...
Old 12-28-06, 02:21 AM   #1 (Link)
Alias: garycase
Loc: Texas
User: #5068
Since: Dec 2006
  garycase2001 is offline
I have a Sony 53XBR45 that works perfectly ... outstanding picture, all remote functions work, etc. => it's as good as when we bought it new in '97 EXCEPT for one annoying attribute:
When turned on, the light will blink for a LONG time before the set comes on (sometimes 15 seconds; sometimes several minutes). It usually helps to just power off/on several times (I always wait a second between keypresses) ==> but it can still take a good while to get the TV on. Once on ... it's perfect ==> and remains that way as long as it's on (I often just leave it on all day ... and have left it on as long as 3 days).
This TV has such a great picture I hate to toss it (it's not our primary TV any more; but it actually has a better SDTV picture than my 50" Plasma or my 67" DLP) => but it would be nice if I could fix the turn-on issue.
Old 12-28-06, 07:13 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is online now
Re: Sony 53XBR45 Turn-On Issue
Your problem is easy to identify, not easy to correct. Sony sets have had auto bias circuits for years, and yours does as well. I actually had this same set for a while. The way they work is by sending a pulse out in the vertical interval ( the part that you can't normally see at the top of the pix) in each crt, then measuring the return voltage of that pulse. The video processor then adjusts the gain of each CRT to have the correct relative voltage for each tube. The result is pretty good color as the tubes age, where sets without this will shift gray scale pretty severely. As the tubes age, it takes longer for them to warm up and balance out. Your Sony blanks the video until it can achieve proper balance. Eventually, when one of the tubes gets far enough out, it will just never display a pix. The bottom line is that your tubes are aging and it will be time for a new set before long.
There are a couple of potential patches for the blanking. One is to try adjusting the screen (G2) controls up a bit. You have to be careful because going too far will introduce retrace lines and prevent producing blacks. It will also likely alter your gray scale and this has to be readjusted in the service menu. The procedure is to switch to an input with no video signal and turn up each G2 control until you see retrace lines, then back it off until the screen is black. Then adjust the gray scale in the service menu.
The other potential solutions are to restore or rejuvenate the tubes, defeat the blanking circuit, or increase the filament voltage to get more output from the weak gun(s). Restoration is very tricky and should only be done by someone who has a very good CRT restoration unit and is very experienced with these tubes. It can easily make the situation worse or finish off a weak tube. Defeating the blanking circuit is possible but nearly always results in color problems and is not an acceptable choice, IME. Increasing the filament voltage is risky because it causes much more heat in the filament and cathode and can work well, but you risk burning out the filament or acceleration of the aging of the cathode. If there is sufficient cathode emitter material left, a combination of gentle restoration and filament voltage tweaking can extend the life of the set, but it will likely need regular gray scale adjustment until the tubes get to the point where they just won't produce a good pix. None of this is practical unless you are a serious DIYer, because you have to keep tweaking the set as the tubes age out.
Start looking for a new set...
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 01-16-08, 11:04 PM   #3 (Link)
New Member
Alias: Botcher
Loc: Ocean County NJ
User: #15613
Since: Jan 2008
  botcher is offline
Once I get my 53XBR's convergence fixed, it also looks like my set is not as focused as it once was. It seems to look better the longer its on, but is there a focus adjustment inside somewhere like the older small one-crt sets, or is there separate focus adjustments for each RGB tube?
Botcher
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Sony »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
