| Manufacturers Service and Support Where to find Pioneer SD-643HD5 Remote control?Discuss Where to find Pioneer SD-643HD5 Remote control? in the Home Theater | Audio and Video forum; Where to find Pioneer SD-643HD5 Remote control? I just snagged this television off of cragslist for free but unfortunately, it doesn't come with a remote. To get ... |
| | #1 (Link) | |||
| Where to find Pioneer SD-643HD5 Remote control? I just snagged this television off of cragslist for free but unfortunately, it doesn't come with a remote. To get an OEM replacement, it looks like it can run me well over $150-200! That's way out of my budget considering it actually looks like a Fisher-Price toy. Are there any universal remotes with the same features/buttons or am I just out of luck? Also, is there any where to get a service manual for free or am I going to have to pay for it? I managed to find the Hitachi 43uwx10b service manual for free but I'm not having any luck with this pioneer.Last edited by pswayze; 09-21-08 at 09:35 PM. | |||
| | #2 (Link) | |||
| Re: Where to find Pioneer SD-643HD5 Remote control? Pioneer has 2 versions of that remote. One is only about $40. You might call them to find out what the difference is. Probably not programmable. Pioneer service manuals are among the most expensive on the market, usually $50-100. You may find a place to download it if you look at the sources in the links here http://www.hometheatershack.com/foru...ful-links.html but the only ones that I know of that might have it are subscription sites. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #3 (Link) | |||
| Re: Where to find Pioneer SD-643HD5 Remote control? For the remote have a look at ebay they can sometimes be found for a really good price. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | |||
| | #4 (Link) | |||
| Re: Where to find Pioneer SD-643HD5 Remote control? Hey Leonard. I got this set working and come to find out I can adjust the convergence without the remote. Awesome! Here's my next question, before I spend all the time calibrating the convergence, I would like to deal with the overscan problem. I put up an overscan test picture and I'm at about 5% all the way around. This makes a noticeable difference when I'm playing video games. Is there any way to correct this? Also, the convergence grid isn't completely square at the top and the bottom of the screen. I can't fix it from this menu because you only have control over red and blue. Any suggestions? | |||
| | #5 (Link) | |||
| Re: Where to find Pioneer SD-643HD5 Remote control? You have to change it at the service level and it will require significant adjustment to geometry and convergence. 5% is not bad for a CRT based unit. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #6 (Link) | ||||
| Re: Where to find Pioneer SD-643HD5 Remote control? Quote:
Also for some reason depending on the display pushing the overscan to far will cause the image to bend slightly on the edges and convergence adjustment wont fix it.. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | ||||
| Tags |
| control?, find, pioneer, remote, sd-643hd5 |
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Remote Control for Midi devices? | charlesp210 | Remotes | Cables | Accessories | 13 | 04-08-08 12:11 PM |
| How can I control the volume on my stereo with my tv remote? | drew | Remotes | Cables | Accessories | 4 | 03-20-08 01:08 PM |
| Universal Remote Control MX-500 | SteveB | Remotes | Cables | Accessories | 1 | 05-24-07 08:27 AM |
| Universal Remote Control | lcaillo | Manufacturer and Vendor Reference Information | 0 | 05-01-07 07:18 PM |
| Remote control changes channels on both receivers | BradGinter | Remotes | Cables | Accessories | 7 | 01-30-07 02:07 PM |
