Samsung HLC473w Post convergence problem - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Samsung
Samsung
Discuss Samsung HLC473w Post convergence problem in the Brand Specific Service Forums forum; Samsung HLC473w Post convergence problem Hi I have a Samsung 47" RPTV model HLC473WBX/XAC. The convergence chips were relaced twice since I purchased the unit ...
Old 02-05-08, 08:22 PM   #1 (Link)
nik
Alias: nik
Loc: Keswick on
User: #15453
Since: Jan 2008
  nik is offline
Hi
I have a Samsung 47" RPTV model HLC473WBX/XAC. The convergence chips were relaced twice since I purchased the unit back in 2003. The first replacement of the stk's was done by a local repair shop that cost around $375. Soon after the stk's were replaced, my wife and I noticed some lines, diagonal pattern, from top left corner to bottom right corner. This was an intermittent occurance. As time went on the lines became more frequent. Last month the second convergence problem ocurred on the unit . I replaced the stk's, set up and test ok.
But the lines are still present.
I don't know if the stk's have anything to do with the lines but I thought I put a brief history about the lines
Any help would be appriciated, Thank you
nik
Old 02-06-08, 05:20 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Samsung HLC473w Post convergence problem
The lines are likely unrelated to the convergence problems. Repeat failures of convergence ICs in these sets are likely due to using inferior parts or inefficient setup. Have you read the posts at the top of the convergence repair thread?
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 02-06-08, 06:40 PM   #3 (Link)
nik
Alias: nik
Loc: Keswick on
User: #15453
Since: Jan 2008
  nik is offline
I followed your instructions and I bought Sanyo chips off the internet, installed them and fixed the convergence problem. I also installed a fan with an external power supply so that the chips would be kept at a cooler temperature. If the lines are not a convergence problem, then I am at a loss as to how to fix them. The instructions you gave me in regard to the covergence problem were very thorough and I really appreciate it as the chips are working and we are now able to watch tv again. What kind of setup beside setting the convergence settings are you referring to? Is there a set up in the service menu that I have missed? I read in another forum that it could be high setting in the RGB and vertical height. Im not sure what that really meant. Any help you could give me with this would be appreciated.
Thanks,
Nik
Old 02-06-08, 07:16 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
  lcaillo is offline
Can you post a picture of these lines?
Old 02-06-08, 09:38 PM   #5 (Link)
nik
Alias: nik
Loc: Keswick on
User: #15453
Since: Jan 2008
  nik is offline
Here's two pics of the lines.
Thanks again
Nik
Old 02-07-08, 06:32 AM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
  lcaillo is offline
Those lines have nothing to do with convergence. More likely a wire dress problem or a filering issue in the set, or a source issue. My best guess is that some wires were not put back where they belonged and are picking up some interference. It can be very important to dress wires the way they came from the factory in some sets.
Old 02-08-08, 06:56 PM   #7 (Link)
nik
Alias: nik
Loc: Keswick on
User: #15453
Since: Jan 2008
  nik is offline
You hit the nail right on the head. I tried moving a couple of wires around and found that the first tech that did some work broke a clip holding wires, so when I changed the chips I did notice the clip being out of place but after reading your post I found that the wires were not in the right position that they should have been. There are still lines on the screen. It is just finding the right combination of wires that are causing interference. Thanks very much for all of your time and help with this matter.
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Samsung »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
