Philips 55P8288 Fuzzy Picture - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Philips 55P8288 Fuzzy Picture in the Home Theater | Audio and Video forum; Philips 55P8288 Fuzzy Picture Hey guys, Just found this forum and thought maybe you could help me out. My step-dad bought this tv for ...
Old 03-01-08, 03:19 AM   #1 (Link)
New Member
Alias: bthornton23
Loc: montello, wi
User: #17528
Since: Mar 2008
bthornton23 is offline
My step-dad bought this tv for $200 and my mom don't want it cause the picture is so bad, it went to my step sis but now she don't want it so im next in line.
I really like this tv and I have seen projections that are fuzzy before but this is really bad.
Example: When your in the menu with a black screen and green letters there is a green glow that spreads out about 3-4 inches around the letter. Now imagine this when you watching the thing. None of the colors are right cause everything blurs together. Not something I think I could get used to. Before I take this TV I would like to know if it is economical to repair.
Any help is greatly appreciated and Thank You in advance
Old 03-01-08, 04:31 AM   #2 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is offline
Re: Philips 55P8288 Fuzzy Picture
bthornton23,
Welcome to the Shack! I moved your thread here as it will likely get the attention it deserves here!
mech
mech
Got questions? Start a thread.
Old 03-01-08, 05:52 AM   #3 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Sounds like classic Philips contaminated coolant on the CRTs. There is a thread with info on this problem here:
http://www.hometheatershack.com/foru...html#post67456
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 03-03-08, 09:23 AM   #4 (Link)
New Member
Alias: bthornton23
Loc: montello, wi
User: #17528
Since: Mar 2008
Wow...having never worked on a television set before Im not sure how I will go about this but thank you very much for refering me to the very imformative thread. They way you describe the "halo" effect i believe this is more than likely the issue.
Thank again
Old 03-05-08, 07:45 AM   #5 (Link)
New Member
Alias: bthornton23
Loc: montello, wi
User: #17528
Since: Mar 2008
OK so I talked to the lady my step dad bought the TV from to see if they ever looked into getting the fuzzy problem fixed and she insists that the picture was fine before it was picked up. Maybe it was maybe it wasn't but I would like to ask this.
The TV has been moved a couple times. From the sellers to my ma's and from my ma's to my sisters. The problem was notice at my moms. Could vibration or bumping around in the moving process have caused this problem?
Also...if they plugged it in right away when it was cold could that cause the problem? It has been very cold here lately.
I would hate to dig into this and find out that it is something other than the coolant. It's always a possibilty but if these other 2 things are a possiblilty I may consider just taking it to a pro unless of course you would have a fix for that also
Old 03-05-08, 12:33 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
The problem could be made worse by moving, or temperature changes. These issues really don't matter, however, as the result is the same. Virtually all Philips made CRT RPTVs will develop the coolant contamination problem eventually. There may be other problems, such as convergence failures which are common. I would suggest upgrading the convergence chips as well as changing the coolant if you plan to keep the set for a while. You will have to adjust the focus and convergence anyway, so changing the output ICs is no big deal.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Nirvana Unplugged- of flannels and fuzzy green cardigans... robk_11 Music and DVD Concerts 3 02-08-08 11:16 AM
Review: Philips DVP5960/37 toecheese Home Theater Components 5 11-06-07 07:15 AM
philips ic convergence repaire help kuby71 Home Theater Projectors 14 11-05-07 08:07 PM
Philips lcaillo Manufacturer and Vendor Reference Information 0 05-06-07 07:40 PM
problem with tv philips 9p6031c102l twinturbo Manufacturers Service and Support 0 11-18-06 01:36 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
