Mobile Audio DiscussionDiscuss can this be considered a TL? in the Mobile Audio Shack forum; can this be considered a TL? so the length is easy enough to figure out, cross sectional area a little tougher, and I'm not even about ... |
Views: 390 - Replies: 3
| can this be considered a TL? so the length is easy enough to figure out, cross sectional area a little tougher, and I'm not even about to start doing horn style....increasing or decreasing cross sectional area. Compression chambers and such... not a chance. So what would this do? It's 18.77 feet long, 1/4 wave of 15.5Hz thanks! | ||||
| | #2 | ||||
| Re: can this be considered a TL? by horn style, i was trying to say tapered, but i couldnt think of it... really, i dont know the difference between a horn and a tl that tapers. also, placing a driver 1/3rd to 1/5th the way in from the closed end, I don't get how the rest of the transmission does anything... I would think it would just echo and eddie and add a mess, and really you just effectively cut off 1/3rd-1/5th and shortened it. this obviousely isn't so, or no one would get them tuned right and had figured that....so can anyone explain to me how placing the driver anywhere between the two ends, the "dead" end still functions? Thanks!! | ||||
| | #3 | ||||
| Re: can this be considered a TL? I fear TL's, probably becasue i do not understand them, Sealed is simple, ported a little harder and then bendpass but understanding the Maths behind a TL is very hard considering there is not programs like WinISD to help with design. I have always stayed away from TL in home and in the car... Then again from my understanding a properly designed TL is something special, sorry i cant help you more Just build ported and sealed boxes | ||||
| | #4 | |||||
| Re: can this be considered a TL? Quote:
