| Multimedialand Production The inevitable!Discuss The inevitable! in the HD World | Computers | Games | Media forum; The inevitable! tweeksound wrote:
I'm seriously contemplating 3 PreSonus DigiMax FS's and the RME Audio HDSP 96/52 PCI card for 24 chanels ... |
| | #26 (Link) | |||
| Re: The inevitable! Sweet! Let me know how well those interface with PT if you don't mind. When I was looking no one could give me a straight answer how well non digidesign hardware would work. I'd say with that much I/O and the mackie you'll have quite the workstation! | |||
| | #27 (Link) | |||
| Re: The inevitable! I'm pretty sure they won't work with PT. PT is very proprietary about what interfaces will work. I could be wrong. The ADAT of the 002 might allow me to use 1 of the presonus'. I do enjoy using PT so what I plan to do is record with a Cubase and then just import the tracks into a PT session. The Mackie's however are very unlikely to work, but again, until I try it, I won't know. | |||
| | #28 (Link) | |||
| Re: The inevitable! Well, it's been almost 3 months since my original post so I thought I'd give an update. I ended up going with pcaudiolabs.com for my new DAW. It's a Q9300 quad core 2.5Ghz and has the RME Hammerfall HDSP 9652. I had a couple freezes while starting windows that required a reboot. PC audio labs were great with support. They fixed the issue within 20 minutes of me calling, by remote access. Right now I'm getting by on just one 8 channel Presonus Digimax FS and love it but I plan to get another soon. I'm using Reaper and Sonar 5 producer. (Mostly Reaper though) What a step up in just about every way! Never let anyone scare you from using a PC based DAW. Going to school, there was always >15 minutes before class spent fixing the Pro Tools set up to actually work and even the teachers had trouble. I think it was because there were so many different people using it that there was always something being changed to fit someone else's work flow. I've done a couple dozen sessions so far including 3 long live concerts and I have not had a single hiccup. Very happy with every link in the chain. | |||
