Multimedialand ProductionDiscuss Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live music? in the Movies | Music forum; Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live music? Sorry for such an off topic question, but I'm trying to record some live church music using something I already ... |
Views: 755 - Replies: 15
| Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live music? Sorry for such an off topic question, but I'm trying to record some live church music using something I already have. Is it possible to basically use the same equipment used for REW to record live music using "Sound Recorder"? I see a need for using headphones in the preamp to monitor the sound. I'm using a Vista laptop. Would using another mic be better? | ||||
| | #2 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi The Behringer mic and preamp should be fine for recording music as long as you want to capture everything in one go and not individual artists or instruments - the mic is an omni so not best suited to trying to narrow down who/what you want to capture. For more knowledgeable input on this general area try the Audio Production forum. | ||||
| | #3 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi From what I see here, it shouldn’t be a problem. Not sure about monitoring with headphones, though, but I think it’s pretty common with other programs, so I’d be surprised if it didn’t work. Regards, Wayne | ||||
| | #4 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi Thanks guys. What I'm trying to record is a church chior, so an omni directional mike like the Behringer mic will probably do. | ||||
| | #5 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi Yep – an omni will work great for a choir. Keep in mind, however, if you have live instruments on stage that’s probably what you’re going to get the most of in the mic. Regards, Wayne | ||||
| | #6 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi I would recommend Audacity as the program for recording...it's free and works as well as Pro Tools and CuBase (all of which I use regularly). -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #7 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi Thanks Mike, I'll look into it. The chior doesn't have musical instruments. Its a very remarkable 4 part harmony. I was thinking about using dual Behringer mics, but don't know if I'm creating unnecessary problems. Suggestions? | ||||
| | #8 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi Mike, I've got Audicy up and going. Fairly intuitive. Can you suggest a set of headphones appropriate for one time project available from some place like guitar center. This is for monitoring through the preamp. My intent is to tweak out bass, mids and highs. My preamp has these adjustments available. Also, on Audicy, I'm not sure where my signal is suppose to remain within on the running plots. I'm guessing that I should never exceed +-1 while recording. Can you suggest an online forum where these type of questions are addressed. The only one I found didn't go into this detail. | ||||
| | #9 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi I’m moving this to our Audio Production Forum, since it really doesn’t have anything to do with REW. I’m actually a bit surprised that Mike says Audacity is as good as Pro Tools or CuBase. My main beef with Audacity is that it doesn’t allow for real-time EQing, gain or other adjustments, which makes it kind of cumbersome. But then, the price is right. ![]() As far as headphones, it’s hard to go wrong with anything from AKG or Sennheiser. As far as the signal level, just keep it from maxing out in the running plots. That’s make the signal clip, which will show it having a “flat top” if you reduce the gain after the recording is finished. It’s easy enough to increase the signal level after the fact if you need to . Hopefully you found the plug-in download for additional functions and effects – it includes one called “Simple Amplifier” that adjusts gain. By the way, a second mic would help with a stereo/ambient effect. That might be good if you’re intending say, to distribute this to the church members. If this is just for practice, i.e., for the choir members or director to study and critique themselves for improving their performance, then the single mic will do. Regards, Wayne | ||||
| | #10 | ||||
| Re: Can you use the Behringer mic, SoundblasterUSB card and preamp with computer to record live musi If you want headphones for setting the eq on the preamp then you'd probably want to spend as much on your headphones as you can and get some with the best FR you can afford. When I started recording music for church I made the mistake of mastering a cd using a cheap set, the end result was that everyone got a cd with too much bass. Another free program you should check out is Reaper. If your computer has a stereo line in then reaper can record 2 individual channels (just like protools etc). "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | ||||
