Music and DVD Concerts
What mode do you listen to CDs in?
Discuss What mode do you listen to CDs in? in the HD World | Computers | Games | Media forum; What mode do you listen to CDs in? Sonnie wrote: Is direct mode generally analog? I was trying to listen to a CD the other day and when ...
Views: 2121 - Replies: 47
Old 12-09-06, 05:07 PM   #26
New Member
Alias: Nomo
Loc: Wisconsin
User: #4713
Since: Dec 2006
  Nomo is offline
Re: What mode do you listen to CDs in?
Sonnie wrote: View Post
Is direct mode generally analog? I was trying to listen to a CD the other day and when I selected the direct mode I could get no sound. I only have the digital audio out connected though.
I believe on most if not all of HT receivers, it is on my Yamaha anyway, that direct or "pure direct" is analogue only, bypassing the receiver's DACs and DSPs.
Most times I prefer PLIIX, but around 10% of the time I'll go with pure direct.
Old 12-11-06, 09:02 AM   #27
Moderator Emeritus
Alias: Naut
Ayreonaut's Avatar
Loc: Richmond, VA
User: #203
  Ayreonaut is offline
On my Denon AVR 1905, Direct mode is either straight analog, or digital bypassing all processing except the DACs.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 12-11-06, 10:53 AM   #28
Platinum Member
Alias: Darren
Darren's Avatar
Loc: Washington
User: #43
  Darren is offline
Adz wrote: View Post
Very true. And if you put in your favorite CD and switch back and forth between stereo and direct modes on your receiver/processor, you will hear a difference. What sounds better to you?
It depends on what type of music I'm listening to. If I'm listening to Metal or hard rock then I usually go stereo because the quality of the recordings is usually lacking. The highs are harsh and the bass is thin. Stereo places more emphasis on bass. If I'm listening to something more refined that has been mastered well I'll go direct.
Old 01-16-07, 10:29 AM   #29
New Member
Alias: cafyon
Loc: Istanbul, Turkey
User: #5720
Since: Jan 2007
  cafyon is offline
What about 3 channel SACD?
Hi all,
I prefer to use a seperate stereo integrated amp for CDs. Output is analog (player's internal DAC) from player till I buy a DAC.
And sorry if this is off-the-scope but, is there anyone listened to 3-channel SACD layer on "RCA Living Stereo" disks?
Old 01-16-07, 09:23 PM   #30
pmenasce
Inactive
Alias:
User: #
Posts: n/a
If I'm sitting and really "listening" I go pure direct all the time. I don't like all the special effects messing with what the engineers did with the music originally.
My two cents ...
Peter
Old 01-17-07, 11:29 PM   #31
Alias: John
John S's Avatar
Loc: Columbus, OH
User: #842
  John S is offline
Re: What about 3 channel SACD?
cafyon wrote: View Post
http://www.hometheatershack.com/foru....html#post9091
Old 01-18-07, 10:20 AM   #32
Zarathustra19
Inactive
Alias:
User: #
Posts: n/a
Well, if I'm listening to a redbook cd I generally keep in in stereo, which IMO is the way it was mean to be heard. If, however, I'm listening to DVD-A or a 5.1 Surround recording, I go to the full surround speakers, either DTS or Pro II
Old 01-18-07, 01:02 PM   #33
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
I listen to CDs in stereo. My Denon 2910 does the decoding (for CDs and DVDs), bass management, etc. and I use analog outputs into my HK receiver. If I'm sitting in the sweet spot on the couch, this gives the best imaging, center vocal image, soundstage, etc. The other sound modes don't even compare.
(I also have first reflection points treated, bass traps in the front corners, and a BFD for the sub)
Old 01-18-07, 05:16 PM   #34
Alias: Eddie
Eddie Horton's Avatar
Loc: Hayden, Alabama
User: #3894
Since: Nov 2006
  Eddie Horton is offline
That's how it's done, Bri. Treat the room acoustically, then finish off with EQ. Can't wait till my room is done!! I'm jealous.
Old 01-18-07, 05:29 PM   #35
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
I'm just lucky that we found a rental (house) with a nice big rectangular living room. And lucky that it's on one end of an L-shaped layout with the bedrooms at the other end of the house. And that my wife lets me keep acoustic panels in the room (she didn't really have a choice - I got them and said "hope you like them" - hehe - I compromised a little bit on them, so they aren't stacked to the ceiling in the front corners, and now they're just doubled up in the corners).
But with flat frequency response, you don't even have to run the sub that hot to get fantastic bass for both music and movies.
I was tweaking some more last night, switched my VTF-3 Mk2 back to Max Extension (I get strong output to mid-teens, but lose a little headroom up higher), and re-did my BFD filters (on a different channel). Now it's extremely flat, even more than before, to high 30s, with a big rise from high 20s to high teens, with it dropping to "flat" level of higher bass around 15Hz (I'll try to post a graph or two tonight). I did this while running REW through the receiver, so I could work on the response as it combines with my Ascends (I cut some more in the 70s and around 100Hz to get it flatter to around there). Probably too many filters, but it's very flat now and I'll go with this for a while unless I play a scene that makes the sub show signs of stress.
I tried a bit of The Haunting DTS again after this, and for the first time (haven't checked the scene in a while, since doing all the tweaks) I heard the actual bass and creaks and sounds, and not the booms echoing around the room after the bass. At -15 it was massively loud, but it seemed like I heard just the bass and not the room. (and no stress from the sub)
Old 01-21-07, 10:29 AM   #36
Alias: Ray
RayJr's Avatar
Loc: Palmdale, CA
User: #5637
Since: Jan 2007
  RayJr is offline
I listen to music in PLIIx or L7....depends on the type of music.
Later
RayJr
Home Theater Junky...on a budget
Old 02-05-07, 03:32 PM   #37
Silver Supporter
Alias: John
Loc: Lafayette, IN
User: #6005
Since: Jan 2007
  cellexjohn is offline
This is an interesting thread. I'll give it a bump.
I personally listen to cd's in analog 2ch through my dedicated cd player. I let it do the processing. I run the preamp in direct mode with no base management for the mains. In this mode I walk up and turn off the sub as direct mode still sends full range to the fronts and still 80 and below to the sub. I spend a fair amount of time listening to jazz. I do listen to rock and some alternative also. None of which the mains have any problems with the base.
When tinkering about the house I listen to Sirius. Normally in 5ch stereo as it sounds fuller while moving around.
John
Old 02-05-07, 06:17 PM   #38
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Ayreonaut wrote: View Post
From a Stereophile interview of Jim Fosgate
Guttenberg: PLII can work its magic on LPs and CDs?
Fosgate: Yes. Please understand that PLII doesn't affect the stereo soundstage, other than to display the in-phase part of the program over the three front channels—the out-of-phase or randomly phased signals are sent to the rear. When switching between stereo and PLII, you'll see that the stereo soundstage stays intact but has greater depth and width. Sometimes you're not even aware of the extra speakers, until you turn them off and the soundstage collapses back to stereo.
Guttenberg: PLII comes in two flavors, Music and Movie. What's the difference?
Fosgate: In the digital implementation, the logic is the same for both modes, but the movie mode adds some time delay to the rear channels for a more frontal presentation. Of course, you can listen to movies in Music mode, which is the way I listen to DVDs. I recommend trying it both ways to see which one sounds better to you.
Guttenberg: Can PLII break on through to the two-channel faithful?
Fosgate: In real life, we're used to hearing in a 360º sphere from all around us. Stereo is unnatural in that it is coming only from the front speakers. With my triamped, all-tube system, stereo sounds very, very good—it's what great stereo is all about—but when I switch from stereo to multichannel, there's no comparison. It's not that one is so aware of the back channels, but PLII makes the front soundstage wider and deeper. Some of my guests aren't aware of the rear speakers' contributions until I turn them off.
I find this strange. At least with music sources, I find there is a difference in how the sound is mapped across the front 3 speakers when switching between DPLII Music and Movie. Movie puts a lot more sound in the center speaker, and Music keeps the soundstage a little wider across the front with more sound going to the sides.
At least this is how it works on my HK AVR240.
My HT Gallery (Updated pics of my setup and room treatments)
My REW measurements with bass traps and BFD eq
Old 02-15-07, 04:20 PM   #39
Alias: rob
robk_11's Avatar
Loc: palmyra, pa
User: #6308
  robk_11 is offline
I prefer music in stereo. I am usually streaming off my Roku Soundbridge though. I haven't broke out a CD in a loooong time...
Old 03-31-07, 08:56 PM   #40
Alias: Greg
goatfarm's Avatar
Loc: Scenic southern Indiana
User: #7897
Since: Mar 2007
  goatfarm is offline
2-channel stereo for everything except pipe organ. Then I add the sub.
Old 04-01-07, 02:44 AM   #41
Alias: spin
User: #337
  spin is offline
Mostly in Stereo mode for me.
However, I also occasionally switch to Pro Logic II Music mode, but with the surrounds turned off.
Old 04-13-07, 07:33 PM   #42
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
I usually listen in Stereo. Stereo with bass management to be exact. I don't want my left and right to perform <80hz even though they can. My subwoofer is better than them in those frequencies and that is how I like it.
Occasionally, I will play with PL2 Music/Movie, DTS NEO Music/Movie, and L7 Cinema/Music....some songs sound better with another format and such....but I usually just listen in stereo.
Old 04-14-07, 08:10 AM   #43
downhill
Inactive
Alias:
User: #
Posts: n/a
CD's stereo only, unless I have a friend over wants to experience the other soundfields that DSP's provide.
Old 07-29-07, 11:07 AM   #44
Alias: Jusbe
Jusbegood's Avatar
Loc: Redmond, Washington
User: #5052
Since: Dec 2006
  Jusbegood is offline
I listen to CD's in Multi-Channel Stereo through my Sony STR-DA3000ES. You get all the sweet spots anywhere that you sit.
Pioneer|VSX-24TX,CT-F950, SX-V90, PL-55DX
Onkyo CP-1044F TT
JVC: TD-W805
Sony| KF-50WE610, STR-DA3000ES, DVP-CX777ES, CDP-CX450, RCD-W500C
ESS AMT3 Rock Monitors, ESS AMT4's
Signet Center Channel
Old 08-01-07, 01:36 AM   #45
Alias: Shawn
Loc: Topeka
User: #9911
Since: Jul 2007
  SierraMikeBravo is online now
I usally listen to Dobly PL for music. At times, I'll listen to direct stereo, but I find I prefer the surround aspect of Dolby.
Old 08-01-07, 05:39 PM   #46
Alias: AC
ACGREEN's Avatar
Loc: WICHITA, KS
User: #6917
  ACGREEN is offline
I know that purists listen in only stereo, but I love the "all-channels" stereo that Yamaha has. IT really highlights when you have a week speaker and is the reason I upgraded to a large center channel. I can't wait to listen to it in 7.1.
Old 08-01-07, 09:50 PM   #47
Alias: Mazer
mazersteven's Avatar
Loc: Melbourne, Florida
User: #8008
Since: Apr 2007
  mazersteven is offline
DTS Neo 6
Old 08-02-07, 03:28 PM   #48
Alias: rick
Loc: miami,fl
User: #9137
Since: May 2007
  enrique is offline
i listen to redbook via analog thru my cd player,usually 2ch in either stereo or bypass/direct.Smetimes it's 5ch depending on the mood i'm in.But it's all analog.DVDA/SACD is another story all together which i still enjoy.
