Philips / MagnavoxDiscuss magnavox crt rptv converge is off. need HELP!!! in the Brand Forums forum; magnavox crt rptv converge is off. need HELP!!! hello im repairing my first magnavox model # 6p5440 w103 crt tv and ive successfully changed the fluid but the ... |
Views: 826 - Replies: 11
| hello im repairing my first magnavox model # 6p5440 w103 crt tv and ive successfully changed the fluid but the converge is off set and when i line it up in the middle the sides are off. i put the service code 062 in and a grid comes up but the lines are clearly bent and become worse as it leaves the center. i would like to know how to straighten out the curves. also the menu finally appeared but the channel changes and menu and stuff like that are very scrambled up and sort of flashing. if you could provide insight or help to atleast one of these problems it would be greatly appreciated | ||||
| | #2 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! The convergence procedure is not something that can be related in a few words. I suggest you get a copy of the service literature for your set and follow the procedure in the manual. I do not understand they symptom that you are describing with the menus. If you want help you have to be very specific and complete in describing what is going on. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #3 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! ok, well i have searched the web for a service manual and i cannot even find an owner's manual. They seem impossible to come by for the model number and i will go to work on the tv in the next few days so i will take pictures of the symptoms and post them so you can see but if you can try to describe what i have to do to fix the set i would really appreciate it because i cannot seem to find a service manual, thanks | ||||
| | #4 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! Try some of the links here: http://www.hometheatershack.com/forums/manufacturer-vendor-reference-information/4531-repair-tips-service-manuals-assorted-useful-links.html I know at least Treasure Chest has it, but you may find it on one of the free sites as well. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #5 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! i looked at treasure chest and they didn't have any service manuals for Magnavox model # 6p5440-w103 or 6p5440 w103 so it don't know where you found it if you could send me a link i would consider purchasing the manual since i have already invested atleast $20 and many hours of my time as long as its not to expensive | ||||
| | #6 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! Look under Philips. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #8 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! http://www.servicemanuals.net/ServiceManual/PHILIPS/6p5440/pos1/results.aspx The suffixes all lead to the same manual in the Philips software that I have. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #9 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! ok cool but before i purchase a service manual tell me what i'm dealing with. do you think the tv can be fixed. i've read that the alignment chips can be broken and i don't think they make those anymore. in the past how many of these have you successfully repaired? what do you think my chances are? | ||||
| | #10 | ||||
| Re: magnavox crt rptv converge is off. need HELP!!! I do not understand what you mean by "alignment chips." Generally, these sets can be repaired. They often have contaminated coolant AND convergence problems, and I do not recommend doing one without the other, but we fix them all the time. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
