Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Forums > Philips / Magnavox
Philips / Magnavox
stk392-110 upgrade to stk392-150 to repair philips?
Discuss stk392-110 upgrade to stk392-150 to repair philips? in the Brand Forums forum; stk392-110 upgrade to stk392-150 to repair philips? Need to fix convergence problem on my Phillips 51PP9303H\17. Can I replace bad stk392-110 IC's with stk392-150? They will be ...
Views: 161 - Replies: 5
Old 11-01-09, 02:08 AM   #1
New Member
Alias: jahzzz
User: #44172
Since: Nov 2009
  jahzzz is offline
Need to fix convergence problem on my Phillips 51PP9303H\17. Can I replace bad stk392-110 IC's with stk392-150? They will be OEM parts. Thank you.
Old 11-01-09, 08:07 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: stk392-110 upgrade to stk392-150 to repair philips?
Your thread has been moved to the Philips forum in Service And Support to maintain forum organization.
Yes, the -150 is a good replacement for the -110, as is the -120.
If you have not done so, read the first ten posts of the convergence repair sticky:
http://www.hometheatershack.com/foru...e-repairs.html
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 11-01-09, 08:27 AM   #3
New Member
Alias: jahzzz
User: #44172
Since: Nov 2009
  jahzzz is offline
Thank you so much. New to this forum stuff. I did read the stickey.. after I posted the one you moved. That resulted in my second to apologize! I just downloaded the complete SERVICE manual for that model. 1848 pg for 7.99. Thats not bad is it? Thank you again.
Old 11-01-09, 08:37 AM   #4
lcaillo's Avatar
User: #328
  lcaillo is offline
Where did you get your manual and where are you getting your parts, and at what price? Others may find the information useful.
Old 11-01-09, 09:05 AM   #5
New Member
Alias: jahzzz
User: #44172
Since: Nov 2009
  jahzzz is offline
I ordered and downloaded the service manual from Complete Service Manuals . Com for 7.99. Everyone else wanted like $18 to $25. The parts I'm going to first try and get locally here in Phoenix. If not... will probably order from Acme. Love the site and ALL the info you guy's provide! Thank you.
Old 11-01-09, 11:09 AM   #6
lcaillo's Avatar
User: #328
  lcaillo is offline
This is a site that I don't have in the list. I will add it. Thank you for the information.
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Forums > Philips / Magnavox »
philips?, repair, stk392-110, stk392-150, upgrade
