Seeking for help, - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 34 Old 01-18-15, 11:31 AM Thread Starter
Re: Seeking for help,
this is how the excursion and the port air velocity looks like. the velocity peak from the old alignment (withe graph) is 23,3 m/s at 26,39Hz. The velocity peak from the new alignement (pink graph) is 25,46 m/s at 22,49Hz. The excursion graph speak for itself I think.
again, the port will be braced to reduce the port resonance.
Abdullah is offline
post #12 of 34 Old 01-18-15, 11:51 AM
Steeve B.
Port air velocity should be good. It is a little bit high but with a round over it will be fine.
Cone excursion is low so you have room to increase the enclosure size if you want. This will affect transfer fonction magnitude (might be better) and reduce port lenght which will increase 1st port resonance. If your port is resonsting it might ring and it will be annoying.
Steeve-O is offline
post #13 of 34 Old 01-18-15, 12:01 PM Thread Starter
How much more can I increase the box? because if I will increase its size the port air velocity will also increase. For example, when I make it 40 liters, the air velocity will increase to above 30m/s with the same tuning. But the bigger box gives the transfer function magnitude an increase at around 23-24 hz, so that is always good
How much does the excursion need to be? Does it have to be x amount of % of the total excursion at the tuned freq or something?
Abdullah is offline
post #14 of 34 Old 01-18-15, 12:36 PM
Steeve B.
Cone excursion has to be within subwoofer Xmax. Don't go above that because xmech (true mecanical limit) is unpredictable and you can easily damage the woofer.
If air velocity go to high add more port.
Steeve-O is offline
post #15 of 34 Old 01-18-15, 12:53 PM Thread Starter
How about this, added a second port of 4 inch, 40liters tuned to 24hz, port velocity is around 15m/s. But it says that the port length is 2031mm, is this 2031 for each of the port or does it has to be 2013 divided by the amout of the ports, which makes is around 1015mm per port, which is more workable than 2 2m long ports..
Abdullah is offline
post #16 of 34 Old 01-18-15, 01:37 PM
HTS Senior Moderator
robbo266317's Avatar
bigbadbill
It would be the length for each section, 2 x 2m.
In winisd if you select ported and then 6dB extended bass shelf you get a smoother response without the hump in it.
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is online now
post #17 of 34 Old 01-18-15, 03:38 PM Thread Starter
I fooled around witht the 6db extended bass shelf but the port becomes above the 2m which I find is pretty long.
So I messed around the old one and this is what I came up with, (yellow graph)
25liters tuned to 24hz, with again the same port specs (4'' and 1600mm long). Excursion still a bit on the low side. The vent airspeed is 25,46 m/s at 22,51 Hz. I hope it will sound pretty nice. Any thoughts someone?
Abdullah is offline
post #18 of 34 Old 01-19-15, 01:45 PM
bigbadbill
The Port velocity is a bit high but may be OK, don't forget that you will need a High Pass filter set around 24 Hz to prevent over excursion below the tuning frequency and I would recommend setting the crossover to the mains as low as possible, even 60Hz if the mains can go that low.
DIY completed:
post #19 of 34 Old 01-19-15, 06:35 PM
colofan's Avatar
colofan
I would consider using a passive radiator design instead of a port.
colofan is offline
post #20 of 34 Old 01-20-15, 11:45 AM Thread Starter
Sinds I have no experience with passive radiators I dont have any idea what the advantages are. Would there be major difference compared to a ported box?
Abdullah is offline
seeking
