Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers | DIY Subwoofers > DIY Subwoofers > DIY Subwoofers and Build Projects > Ported Subwoofer Build Projects
  Discuss Ported EBS build - pics in the DIY Subwoofers and Build Projects forum; Ported EBS build - pics I don't see that term "EBS" used too often. I am pretty new to subwoofers, all of Home Theater in ...
Views: 3054 - Replies: 87
Old 01-07-09, 06:59 AM   #11
Alias: ginseng
bluejay's Avatar
Loc: Manitoulin Is., Ontario
User: #11443
Since: Sep 2007
  bluejay is offline
Re: Ported EBS build - pics
I am pretty new to subwoofers, all of Home Theater in fact. EBS and LLT are equally new to me as well. I did not know what either meant 2 weeks ago. I did notice that two of the tuning choices inside WinISD are described as EBS 3db or 6db.
After reading the LLT description a couple of times I came to the conclusion that my chosen design was not aiming low enough to meet LLT criteria.
This has a lot to do with my budget on this project. I was up in the air for a long time choosing drivers. For an extra $100 or so I could have procured a driver more suited to LLT, something lending itself to flatter response below 18 Hz.
So for now I will enjoy all I can with an extended bass shelf design using the MJ-18m. If the cash crunch ever lets up around here I can easily upgrade to an IXL-18.2.2. I think that is a better subwoofer for a large and low tuned box, based on playing around in WinISD for only about 1 week.
Old 01-07-09, 10:31 AM   #12
Alias: PHIL
ISLAND1000's Avatar
Loc: SHERMAN, TX
User: #8655
Since: May 2007
  ISLAND1000 is offline
Your project is gonna produce some prodigious bottom end. The box will probably need more braces. I built a similar sized ported box using an 18" Pro driver and began with 2x4 braces spanning the center of each panel. It wasn't enough bracing. The panels would vibrate at higher dbls at certain frequencies and it was perceptible. At lower volumes it wasn't. Try yours and see.
The IXL 18 2.2 IS an excellent driver. Others have used it and rave about it.
Old 01-07-09, 11:17 AM   #13
Silver Supporter
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is offline
Build looks great, Have you decided on a finish?
Old 01-07-09, 12:49 PM   #14
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
Yes, I picked out a green paint yesterday. I am trying for an environmentally friendly sub.
The next pictures are before and after I siliconed the port tubes in. I also squeezed a bit of no nails adhesive into a few gaps to see if that product will stand up to subwoofery. I have heard good things about it from my cabinet maker friend.
http://www.hometheatershack.com/forums/attachments/ported-subwoofer-build-projects/11435d1231353775-ported-ebs-build-pics-img_4138.jpg
http://www.hometheatershack.com/forums/attachments/ported-subwoofer-build-projects/11436d1231353775-ported-ebs-build-pics-img_4139.jpg
Old 01-07-09, 01:06 PM   #15
Alias: PHIL
ISLAND1000's Avatar
Loc: SHERMAN, TX
User: #8655
Since: May 2007
I just love lookin down the throat of that sub and seein all the innards and stuff. Great photography.
Old 01-08-09, 07:27 AM   #16
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
Now that I look at it some more, I am hoping the actual tubes and their mounts are going to aid in this problem.
Me too. If something loosens up in there, I will definitely hear a rattle or buzz of some sort. That being said, my cabinet maker friend swears by the strength of glue over mechanical fasteners so I have to give his theory a try. I used his shop and he gave me a hand when 4 hands sped up the process.
Old 01-08-09, 07:45 AM   #17
Alias: Mike
Mike P.'s Avatar
User: #8033
Since: Apr 2007
  Mike P. is online now
Looks like it's time to install the sub and fire it up.
Old 01-08-09, 07:48 AM   #18
Alias: Josh
Loc: New Hampshire
User: #31152
Since: Dec 2008
  Quake25 is offline
Looking good so far! Have you decided on a batting and/or fill? I am still considering these materials myself.
Just ordered my Driver and Sub...I'm right behind you!
Old 01-08-09, 08:35 AM   #19
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
I am semi allergic to pink fiberglass insulation, so definitely none of that. I don't want to have light fasteners like staples, detaching inside and gumming up the magnet. The inside will be hollow as you see it.
I just do not think I will be that hard to please. I need a sub do dump off the low frequencies present in home theater, so my other speakers don't over excur. Plus the music these days contains tons of low frequency tones, boom boom boom. My regular speakers make tympany sound like tympany, cello sound like cello, and guitar sound like guitar. I expect the sub to make boom boom boom sound like boom boom boom.
I am not trying to oversimplify the subject or make light of the technical details. I just think I am not that hard to please and batting won't help make it better to me.
Old 01-08-09, 10:15 AM   #20
Alias: PHIL
ISLAND1000's Avatar
Loc: SHERMAN, TX
User: #8655
Since: May 2007
bluejay wrote: View Post
There are some technical considerations regarding acoustics and physics using batting. But since your box and driver combination wasn't an attempt to use a smaller box than optimum for your driver and desired frequency response then the only reason you need batting is to reduce internal reflection. There is even a debate over whether ANY batting is needed. But since egg crate foam is easy to obtain and it's cheap and it's easy to install, I say cover the inside with some foam. It makes a "box" seem a little bit more complicated for those that "don't know anything" and need to be impressed with your sonic accumen.
« Home Theater Shack > DIY Speakers | DIY Subwoofers > DIY Subwoofers > DIY Subwoofers and Build Projects > Ported Subwoofer Build Projects »
build, pics, ported
Bookmark and Share
Dish Network
