Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! RAM Electronics: Audio, Video, Home Theater and Computer Cables. PacParts: Replacement parts & accessories from the most recognized manufacturers in the Consumer Electronics Industry! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Fi Audio: Infinitely amazing balanced high end musicality designed drivers! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Elite Screens offers the finest in affordable projection screens. Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Go Back   Home Theater Forum - Home Theater Systems - HomeTheaterShack.com > DIY Speakers and Subwoofers > DIY Subwoofers > DIY Subwoofers and Build Projects > Ported Subwoofer Build Projects
Ported EBS build - pics  Discuss Ported EBS build - pics in the DIY Subwoofers and Build Projects forum; Ported EBS build - pics I use egg crate on all my builds. Cut to fit and apply hot glue. Very simple. The foam I ...
Views: 3004 - Replies: 87
Old 01-08-09, 11:32 AM   #21
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: Ported EBS build - pics
I use egg crate on all my builds. Cut to fit and apply hot glue. Very simple. The foam I used in the build below was a little bit thin but at the time that's all they had.
http://www.hometheatershack.com/forums/diy-subwoofers-sealed-ported/8554-mach-5-audio-ixl-18-4-build.html
Old 01-09-09, 09:55 AM   #22
Alias: ginseng
bluejay's Avatar
Loc: Manitoulin Is., Ontario
User: #11443
Since: Sep 2007
  bluejay is offline
I like the look of the foam. Who sells that? I heard Walmart, but elsewhere?
Also, you have plywood glue blocks to double the thickness of each T nut attachment. Is that the common method? It seems like an excellent idea for me because my front baffle is single thickness.
Old 01-09-09, 10:14 AM   #23
Alias: Mike
User: #8033
Since: Apr 2007
I don't know what stores are available in your area, you'll have to phone around to see who sells egg crate foam mattress pads.
I believe the plywood blocks were 3/8 inch thick. It's just for the T-Nut to "bite" into as they don't hold well in MDF. You can also use a router and cut a 2 or 3 inch wide ring out of plywood to glue to the baffle.
Old 01-09-09, 10:45 AM   #24
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
In my area, I can order it from Sears
Yes, and the T nut won't chew into your main baffle panel, possibly weakening it?
Old 01-11-09, 03:18 PM   #25
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
This is a shot of the blocks I am gluing in to better support the T nuts. Bolt, nut, and washer are clamping them on. They are different sizes to accommodate bracing, etc. I had some 1/4" plywood around so that is what got used.
http://www.hometheatershack.com/forums/attachments/ported-subwoofer-build-projects/11550d1231704402-ported-ebs-build-pics-img_4145-2.jpg
Old 01-11-09, 04:06 PM   #26
Alias: Mike
User: #8033
Since: Apr 2007
After the T-Nuts are installed and before you mount the sub, run the bolts through all the T-Nuts to make sure the threads are clean and not binding.
I like the green color. It looks good!
Old 01-11-09, 08:17 PM   #27
Alias: Aaron
Aaron Gilbert's Avatar
Loc: Bonney Lake, WA
User: #28554
Since: Nov 2008
  Aaron Gilbert is offline
Sweet, another green subwoofer!! That looks like almost the same shade as I used. I also glued blocks behind my baffle to better hold the screws - though just coarse thread wood screws in my case, going into blocks of oak.
Old 01-12-09, 07:55 AM   #28
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
Will do
I have a grill coming, hopefully today. It also mounts with T nuts. This particular grill is described as having a total open area of 50%. It is all I could find around here so I went for it. What will the blockage of 50% tend to do? If it is going to be that bad, maybe I'll leave it off?
Has anyone tried a grill like this? (50% waffle grill)
Old 01-12-09, 08:33 AM   #29
Alias: Mike
User: #8033
Since: Apr 2007
If it's the waffle grill I'm thinking of then it won't work. Do you have a link or a pic to the grill you're referring to?
Old 01-12-09, 08:58 AM   #30
Alias: ginseng
bluejay's Avatar
User: #11443
Since: Sep 2007
  bluejay is offline
The picture is in a large pdf and would not copy, (for me).
I will take your word for it that it is unsuitable. That was my first impression too. It is black and made up of 5/16 square holes - 50%. I will take a picture when it does come.
Also coming are some plastic port tubes that I want to use as a flange, to cover my potted in ABS port joint. They are not the nice looking flared ones, just a flange.
I will not install any extra T nuts to hold the grill yet. They will be unsightly if I am not using them.
This sub of Aaron's helped inspire the green motif. The texture of the hardboard got me thinking "roller". I knew I could roller paint on inexpensively and it would not look (much) worse than the walls in the house.
http://www.aaroncgilbert.com/images/emeraldtitan/05230022.jpg
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers > DIY Subwoofers and Build Projects > Ported Subwoofer Build Projects »
build, pics, ported
Bookmark and Share
Dish Network
