Ported Subwoofer Build ProjectsDiscuss Ported EBS build - pics in the DIY Subwoofers and Build Projects forum; Ported EBS build - pics The problem with waffle grills is they aren't deep enough to allow for excursion, even if the subwoofer is flush ... |
Views: 3056 - Replies: 87
| | #31 | ||||
| Re: Ported EBS build - pics The problem with waffle grills is they aren't deep enough to allow for excursion, even if the subwoofer is flush mounted. http://www.terminalresolutions.com/catalog/at-g062.jpg If a sub is surface mounted, the grill would need to be at least 1.5 inches deep. My subs are surface mounted and I made my own out of 2 pieces of 3/4 inch MDF glued together and some speaker grill cloth. Very easy to do if you have a router. http://www.hometheatershack.com/forums/diy-subwoofers-sealed-ported/8554-mach-5-audio-ixl-18-4-build.html We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #32 | ||||
| Re: Ported EBS build - pics That picture looks like it except I ordered separate mounting tabs. Well I have a few options. I can build a wood and cloth one like Mike's. I could make a wood ring and possibly mount the waffle to it? I can think of something else? Or I can watch the sub woof in and out. That was my original plan, I just started thinking about protection. I really would like to watch the thing move. I just don't want to kick it by accident, since it will be on the floor. ![]() | ||||
| | #33 | ||||
| Re: Ported EBS build - pics One T nut is not behaving. I can not see any glue in it but it chewed up the threads on one bolt and won't let any others pass. I have removed it, possibly to retap, possibly to replace when I get some more. It is a bit of a holdup now. ![]() | ||||
| | #34 | ||||
| Re: Ported EBS build - pics Don't try to retap it just get another one. I've had that happen too. | ||||
| | #35 | ||||
| Re: Ported EBS build - pics This brings up a good point for future builds. Test all T-Nuts to make sure they are functional before installing them. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #36 | |||||
| Re: Ported EBS build - pics Quote:
Bummer about the T-nuts. I despise those things. To their credit, I have only had maybe three dozen pop out or cross-thread on me, in removing many hundreds of woofers and/or amplifiers. ![]() | |||||
| | #37 | |||||
Possibly some glue got in to a couple of them, or possibly they took a set a little off centre. Then the next time of use they started to cross thread or something similar. I discovered the problem on the third test, the one Mike suggested, to run them completely through. This should not be a big deal if they arrive today. I did call 2 local building supplies to inquire about "T nuts". They did indeed know what they were, however, they did not have any. ![]() | |||||
| | #38 | |||||
I only did one round of dent filling and sanding. It could have used more, partly because the plywood is softwood and dents easily. I did not start laying it on a duvet until after it was painted. I suppose I did take most of this into account though. It matches the rest of the decor, (imperfect). ![]() | |||||
| | #40 | ||||
| Re: Ported EBS build - pics I've seen this in a couple of DIY threads ....Is it necessary??? My Match 5 IXL 15.2.2 came with a rubber surround around the driver edge that fit tight in the opening, so I didn't use anything else. Should I add this weather strip??? ![]() | ||||
