Mike P. wrote:
I would suggest buying a plate amp. |
Hello Mike,
Do you think this Dayton Audio SPA-250 will have sufficient power for both my subs @ 4 ohms? Any thoughts on Dayton Audio. Has anyone used it before? Its rated at 252 Watts RMS @ 04 Ohms... say 125 Watts per sub. should be good enough if the stated rating is true.
I have 220 Volts in the AC mains, this model also comes with a switchable selector for 120volts or 230 volts.
http://www.parts-express.com/pe/show...imilarProducts
Kindly review its specs, would like to have ur expert advice on it. (yes Price is a killer.. 120 bucks) Praying its good enough!
Omer
