Dual RL-p18 LLT begun
34K views 110 replies 18 participants last post by  Scott S
#1 ·
Hi Folks,
I've been lurking here for a couple of months now and I guess it's time to start my first post. I have a dedicated theater room which is 14'x21'x8.5' that I built back in November 2003 and currently I have a pair of Definitive Technology BP-2002s behind my perforated 10.5' wide 2.35:1 screen. The BP's have a 12" sub built into them powered by a 125 or 150 watt plate amp. During most movies, the bass seems adequate but during some movies, presumably movies with notable LFE, I can hear the subs distort. I was watching Alien 3 the other day and at the very beginning of the movie, a spaceship pans across the screen and it was the first time I actually tried to lower the volume of the movie. Naturally, my wife or friends don't even notice the problem, but I have been noticing it more and more. I don't have REW setup yet and haven't used my newly aquired SPL meter from Sonnie to check FR and SPLs but I do intend to do that before switching over to the new subs. I'm sure the BP's don't go down as far as I thought they did when I first got them.:hissyfit:
I was considering a dual RL-p15 project but I have been waiting for the RL-p18's and I snagged two at Mike's introductory offer. I figured if one was good, two had to be better. :bigsmile: I received the drivers Thursday and I must say, they are absolutely huge! You can measure 18" with a ruler and try to estimate their size but until you have them sitting in front of you, you just can't imagine how big these things are! Getting the drivers and picking up the 6 pieces of MDF today made me realize that maybe one RL-p18 would have been enough but I am going to press on.:coocoo:
I would have went with an IB, but I don't like the idea of attaching the drivers directly to the structure of the house. I have 1400lbs of sand in my stage area and thought a LLT would be better in my situation. I think the bass traveling through my attic and into the rest of the house would freak my wife out even more than the two large boxes.:scared: At least she will only see the boxes during construction...
I don't have any pix yet but I will try to get some uploaded here as I make a little more progress. I am making two MDF boxes that will each have an internal area of 64.5"x37.5"x16". Each box will have one driver and one port. When I built the theater, I had never heard of LLT subs so I didn't leave gobs of space behind the screen so that is why I only have 16" or so of internal depth for these boxes. If I calculated correctly after bracing and the 8" port I should come in around 550L. I really wanted to go with 650L per box but that would have forced me to move my speakers up too high. Maybe I won't loose as much volume as I calculated...
If anyone can tell me how much volume the RL-p18 is going to take away from my internal volume, I would appreciate it. I will not be countersinking the drivers as I don't care what these boxes look like as they will be totally hidden behind the screen. Also, I am going to use 5/8" closed cell foam to line the inside of the box. Do I subtract the foam volume when calculating effective area? Lastly, should I line the port as well?
-Tom A.
#2 ·
Hi Tom and welcome to the Shack! Glad you got the meter okay and congrats on the pair of 18's. No doubt you are jumping in with a big bang here... :T I'll be looking forward to your build and the results. We have plenty of guys to help you figure things out... they should be along soon.
#3 ·
Around 4.5 liters.
If it's really closed cell foam (I recommend open cell foam instead), then you should subtract the foam volume when calculating effective volume.
Doesn't make a huge difference but doesn't hurt either. If you have some foam left - why not.
#6 ·
Here's some pix of my progress thus far. I know my woodworking skills are nowhere near that of most on this forum but the boxes will be behind my screen so it shouldn't really matter.
I'm standing on a step ladder looking down at the box laying on its side. Remember that is an 18" driver and it looks much bigger in person!:rubeyes: I haven't siliconed anything yet, just glued and screwed the braces and box sides so far. The port will be cut smaller once the total volume is determined.
My port hole didn't come out quite as good as I would have liked. I personally don't own a router but I borrowed a buddy's Ryobi but I couldn't come up with a good reliable way to cut circles. I tried a piece of clear acrylic I had laying around as a circle jig. I started ok but the router bit melted or cut into the acrylic and I went off course. I tried with a piece of 1/4" plywood I had laying around, making sure only the shaft would touch the wood but it still didn't work for me. The hole ended up getting elongated and burnt! My hats off to you wood workers! I ended up using my cheapo Black and Decker jig saw which naturally didn't cut perfect circles but it should be ok since it will be out of sight. Do you think turbulence will create a problem with my not so smooth roundover job? Also, I could only find a 5/8" roundover bit at the local big box stores so that's what I used. Oh well, hopefully it will still sound good.
The last photo shows my 10.5' wide screen where the two boxes will go behind.
-Tom A.
#7 ·
You can sand that port flare on out some, but I doubt you'll notice any noise because of it not being perfect. You do however need to make sure the port end is sealed well and even with the port opening in the wood. I think that might make a difference.
If you have to cut that end again and redo the port, you can make a circle jig that will not burn the acrylic. The router bit should actually never touch the acrylic. You could even use a wooden yard stick, but cut a larger hole where the bit will not touch the sides of the hole... then mount the stick to the router... as follows:
Notice how the bottom plate of the router is removed and the screws used to mount the home made circle jig.
Then don't cut the entire hole out with the router. Just cut two half moons with about 1/4" left on each side. Use your jig saw to finish cutting that tiny bit that is holding the cutout to the panel. What we did was make one complete round about half way through the wood, then we made the two half moons and finished the cutout with the jig saw. This way there's no chance of the router sliding when you cut that last little bit.
#11 ·
Wow. Tom, that is going to be an insane bass maker. I can't wait to see how your project goes, please keep us up to date with lots of pics!
Thanks Owen, I think you are right, it should make plenty of bass. One probably would have been enough but as my friends always tell me, I never do anything small. :bigsmile: That of course doesn't mean I should have started out small.:dumbcrazy:
I forgot to take pictures this weekend of my progress...I'm basically just working on it on Saturday. Since the pictures above, I have added more bracing, cut the port to its actual size and cut the hole for the RL-p18. I was shooting for 550L per box and with all my bracing added and discounting some extra volume for the closed cell foam I purchased I came up with an effective area of 549L. Of course this doesn't mean I calculated it correctly but I hope I did! I also started on the second one this weekend, it's amazing how that one is coming together quicker. What's even more amazing is that I have gone through 7 tubes of liquid nails already and I need to go to Lowes and get more 2x2's, liquid nails and drywall screws.
Thanks go to Sonnie and thxgoon for explaining the circle jig to me, I still feel a bit stupid for not figuring that out. :duh:
Here's a picture of one of my RL-p18's in a trial piece of MDF next to my super fancy circle jig that works great with a finishing nail.
I purchased a Carvin HD1800 to supply 900 wpc into 2ohms. Each sub will have its own channel and I have a Art Clean Box ready to go also.
I have a few concerns though:
(1) I want to try using the sub out on my Yammy receiver but it's crossover is 110Hz. I hope that's not too high?
(2) Should I run a 20amp dedicated circuit for the Carvin? My breaker box is full now and actually my last project forced me to use an ultraslim double breaker to free up more room. I guess I can do that again, but I'm thinking about just trying it as is first as I doubt I'll really use 900 wpc very often. Is this poor logic?
(3) Can I really fit these boxes behind my screen...no just kidding...I measured several times and I know they will fit, yeah, that's the ticket.:bigsmile: They are getting very heavy though! I'm definitely gonna need help lifting them through the screen wall.
-Tom A.
#13 ·
Wow... that is a significant change in that room... :T
110Hz may be a little high truthfully, but you'll just have to try it and see to start with. I don't think you'll have any problems with the amp, not to a point of necessarily needing a dedicated circuit.
#14 ·
Yeah, and that's only a small part of what I had to do to get my dedicated theater room. The house is only 1400 square feet and there is no basement. I don't really have enough property to add on to the house and building up would be prohibitively expensive so I and my reluctant wife decided to convert the den into the theater. But since I closed off the only entrance to the backyard I had to remove the window in the kitchen, which is directly behind the theater, and put a door there. The den (now the theater) had an open floor plan with a pass through thingie that you could put stools up near and a large entranceway to the kitchen and an open area to the adjacent living room. That had to all be sealed off and a door added. I also had to remove the hall closet (now my equipment closet) and move the door to the garage around into the adjacent living room. Since the kitchen was now entirely sealed off from the rest of the house, dad and I knocked out the corner pantry closet and that became our entranceway. It was quite an endeavour and while my wife couldn't quite see my grandiose vision beforehand, she likes the setup now since we actually use all of the space in our house. Before, the living room was never used, now it's the new den.
Are there any options other than trashing the Yammy receiver if the 110Hz crossover on the receiver is too high?
-Tom A.
#17 ·
...If you don't go for a new circuit, what will the Carvin be sharing power with, and on a 15 or 20amp circuit?
The Carvin would be sharing a 15amp circuit with my popcorn machine. The kettle and light would NEVER be on during movie time.:neener: but the 50 watt tray warmer would be. IIRC, the only other possible draw on the circuit would be the 3 plate amps for my Def Tech 2002's and the center channel 8" sub. I don't even know if I will need these plate amps on for the Def Tech's once the LLT is built. IOW, I don't know what the low pass is to the subs. I'll have to play with that.
-Tom A.
#18 ·
Is the 110Hz the LFE crossover or is it also the high pass for your mains?
Well, I lied to you guys...sorry. I browsed thru the Yammy manual a few weeks ago and I could have sworn it said 110Hz. I re-read it again and it said the high pass is 90Hz. This should be better, right?
It also made a statement that the LFE channel has frequencies below 120Hz. Is this a Dolby/DTS thing or is that just how Yammy handles LFE? This is more confusing to me than it should be.:dizzy:
It looks like I can assign the LFE channel to the sub output, the mains or both. Would it be best to have the LFE go to my LLTs and set all other speakers to small so that the frequencies below 90Hz for the left, center, right and surrounds go to the LLT as well?
-Tom A.
#19 ·
The LFE channel range goes up o 120hz, so that is the correct setting in your processor. Some older receivers will incorrectly lowpass the LFE channel at the same frequency your redirected bass crossover is set to, but the goodones keep the LFE channel independent of that, full range up to 120hz. I'd send the LFE only to the sub.
Just to make it clear, the redirected bass from your speakers below 90hz will go to the sub as well as the full LFE channel, which is 120hz on down.
#21 ·
Thanks, that does clear things up. I hope to make more progress this weekend so that I can start playing with these things and see how good they sound!
-Tom A.
#20 ·
I'd say give it a listen both ways. Not that I have any suspicion that you'll be lacking in bass output, but it might integrate better with the mains playing low as well. then again, maybe you'll be getting the distortion back in the BPs, which you don't want, so you would go with just the LFE chan. I wish my Denon could cut off my mains at around 40Hz, so they would save on power trying to play really low, but still play low enough to blend well, unfortunately, 80Hz is my lowest crossover point. I think in my setup I like it better using the Main+LFE setting.
#22 ·
A little progress
Well, I made some more progress this weekend. I still can't believe how much liquid nails I'm going thru.:bigsmile:
The first shot is the backside of one of the front panels showing the ring I made for more support for the driver mount. This was the only time I used liquid nails without using screws also. I'm not sure if my logic was right, but I figured the screws wouldn't really hold that well since they were just being screwed into mdf so I just used the glue. Seems to be very strong. I put some t-nuts in the mdf and the driver seems pretty solid. I stood the front panel with the driver up and the driver seemed solid with no give in the mdf.
-Tom A.
#23 ·
More pix
Here's two more pix. The first one shows how the boxes will be placed behind my screen. For reference, they are 11 feet across.
The second pix shows the driver orientation. The boxes aren't sealed up, the front panels are just sitting on the box. You can see the duct tape on the left box keeping it from falling.
Hopefully next week I will apply the silicone to seal everything up and put the closed cell foam in.
Should I fit each piece of 5/8" closed cell foam in between each 2x2" bracing trying to minimize effective liter loss or should I just use one large piece of foam for each interior wall trying to glue/staple the sheet as close as possible to the mdf and 2x2" bracing? I was planning on using 3M 77 adhesive and cutting each piece to fit between the bracing.
-Tom A.
#25 ·
#26 ·
That was my first impression until I looked back at the linked picture, where he says:
That would indicate the driver is mounted against the ring and then bolted from the back?
Nope, Steve is right, I did it wrong!:surrender: I'm glad you guys are here to straighten me out. I did notice when I was fitting the driver to make sure the t-nuts were lining up that they tended to pull out a little. After I posted the pictures last nite, I was thinking maybe I could put t-nuts on boths sides of the baffle so that it would be more secure. I think I'll re-do it so they are on the back side only as Steve suggested. :T Thanks again fellas...time to make yet another trip to Lowes to get bigger bolts to go all the way thru the ring.
I believe some people put pieces of plywood behind the mdf to get a better bite. Is this only when t-nuts are not used or should I go ahead and add some plywood blocks since I have to re-do it anyway?
-Tom A.
#28 ·
I think you might want to add a couple of braces close to the sub, from the front to the back!!
Good advice, thanks Rodny! Boy you guys are really helping me, I appreciate it! :hail:
Did you know that one port is higher then the other one??
Yeah, yeah, that was not my intention.:hissyfit: They were supposed to be at the same height but when I was cutting the driver hole for the second box, somehow I screwed up and cut it in the same configuration as the first box so basically I ended up with two right hand boxes.:whistling: Rather than buying another piece of mdf, I just flipped the baffle over (notice all the dark streaks on the left baffle?...that was supposed to be internal to the box) and moved one brace. Now of course, the box is "upside-down". Hey, I bet you can't tell this is my first sub project. :bigsmile: :duh: It shouldn't affect anything sonically should it?
-Tom A.
#34 ·
Bob, if these monsters get replaced with a second and then a third project, I'll make a bet the project after that will be structurally re-enforcing his house!
WAF is fairly low right now, I don't think I'll push it. :whistling: Actually, she doesn't mind the boxes since they are in MY room and they will be behind the screen but she is worried about the potential for shaking the foundation. :R She's already made me agree to no submarine movies while she is in the house. :bigsmile:
-Tom A.
#35 ·
Ah yes! I have the same contractual deal with my wife. Nothing with explosion, fighting, etc, etc. In other words, nothing with a decent sound track. I can see future marriage nuptials being rewritten to accommodate home theater fans. :dontknow:
Bob
#36 · (Edited)
Did a little more work today. I went and re-did the driver mounts with the t-nuts on the bottom side of the baffle this time. It does make a difference, thanks Steve! :T Instead of adding plywood chunks to the second layer of mdf I added 3/4" thick "cubes" made from 2"x2"s that I had left over from the framing. I also installed the four front to back braces that Rodny recommended, thanks Rodny! :T
Audio equipment Room Machine
I applied silicone to the insides of both boxes, this picture shows my sloppy silicone job on the right hand box.
Shelf Furniture Shelving Wood Wood stain
This last picture shows the closed cell foam install on the left hand box.
Shelf Shelving Furniture Display case Cupboard
I applied this with 3M 77 adhesive. It works very well and sets up rather quickly. If I have extra foam I will finish covering the port supports as well as the port itself. I think I will have enough but I want to wait because it's gonna be close. I didn't get the foam installed on the baffle as I was getting tired and hungry and I had two beef filets in the 'fridge that were ready for grilling :daydream: so I quit for the day. The baffle foam install is going to take a little longer since I will have to leave spaces between the foam for the braces that the baffle will be secured to. I didn't have time to install any foam in the right hand box either. I guess I'll get to that next Saturday.
-Tom A.
#37 ·
Help or Conspiracy?
Rodny suggested that I add two braces in each of my boxes from front to back. I thought this was a good idea but I thought Rodny was only trying to make my sub better. But now I have come to the conclusion that Rodny was conspiring to be the only person who could fit in his subs and he suggested the braces so that I could not fit in mine. :devil:
Well, my subs may not be as comfortable, especially with the two braces Rodny suggested, but I still wish to join the Sit In Your Sub (SIYS) Club. :boxer: :rofl:
Here's Rodny lounging in one of his SLLTs:
and here's my official documentation that I am formally submitting to the president of the SIYS Club so that I too may be a proud member of SIYS. :demon: :rofl:
Floor Flooring Room Hardwood Furniture
-Tom A.
#38 ·
Lol...I'm not only a client, but I'm also the president of SIYS!!!:dumbcrazy:
If you want to joint the club you need a BIGGER BOX!!!!:rofl:
:paddle:
One more thing .... your left sub might be one or two Db's higher than the right side,..... this is because
Spoiler
the left side port is about one or two inches higher:rofl: :rofl: :rofl:
#39 ·
:paddle:
But doesn't two count for anything? Please, oh please, Mr. President, can't I join SIYS also? :R
One more thing .... your left sub might be one or two Db's higher than the right side,..... this is because the left side port is about one or two inches higher:rofl: :rofl: :rofl:
Who said my floor is level, maybe the left side of my theater is lower than the right, yea, yea, that's the ticket, I DID THAT on purpose so that...
Spoiler
my overall dB would balance out between the lower left floor and the right floor. :rofl:
-Tom A.
