Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers | DIY Subwoofers > DIY Subwoofers > Ported Subwoofer Build Projects
Donations Reviews Vendors
Views: 2718 - Replies: 22
Old 02-16-11, 02:37 PM   #11
HTS Moderator
gperkins
Since: Aug 2008
  gperkins_1973 is offline
Re: Need advice Mal-X 21" EP4000 build
As I said before I have two 15 cu ft (net) subs in my 17 x 17 foot living room. Dimensions are 48" high by 24" wide by 30" deep and they dont look that big I don't think. The malx is a big driver and will need at least a 20 cu ft box to make it work to its most efficency.
He could go sealed but I think he will be loosing out on alot off spl down low.
This is why the sonosub is so favourable.
cheers
Graham
Old 02-16-11, 02:47 PM   #12
Zeitgeist's Avatar
Jim
Since: Apr 2009
Ohio
My Photo Gallery
  Zeitgeist is offline
Compared sealed vs ported - on the low end... I agree.
Large, low tuning definitely gives you A LOT more.
I was surprised.
Old 02-16-11, 02:53 PM   #13
HTS Moderator
gperkins
Since: Aug 2008
Its pretty amazing what you can do with that 21" driver it really is.
2 21" malx's with an EP4000 on each sub =
Old 02-16-11, 04:05 PM   #14
1hagop's Avatar
Since: Apr 2010
Mountain House, Ca.
  1hagop is offline
I started this thread.
You guys are great you are giving me tons to think about. I already have 2 sonosubs they are 15" CSS SDX in 16" sonotubes 4 feet high. I am wondering maybe I could do 30" or 36" sonosub and 4 feet high to match the SDX's.
That would be 18.7 for the 30" and 27.3 for the 36". I have the floor space, keep encouraging me and we shall see what I decide. Also is there a volume that you all would think would be the best? Let me know and I will see if I can make it work.
Thanks again for all your support on this!!!!!
BTW 30^3ft would be 53" high. I think I could pull that off!
11, it is one louder.
Old 02-16-11, 11:53 PM   #15
vann_d's Avatar
vann_d
Since: Apr 2009
Denver
My Photo Gallery
  vann_d is offline
Dude, the bigger and lower tuned on this driver the better.
I have not seen (virtually via internet) anyone build a LLT with the Mal-X 21. This would kick serious bass.
People building large sealed enclosures with this driver are blown away. Think of what a large ported sub will do for you.
Old 02-17-11, 01:29 AM   #16
HTS Moderator
gperkins
Since: Aug 2008
Dito, do it you know you want to!
Old 02-17-11, 11:39 AM   #17
1hagop's Avatar
Since: Apr 2010
Mountain House, Ca.
  1hagop is offline
gperkins_1973 wrote: View Post
Yes I do. So I do not know anything about a ported build.
Where do I buy the ports?
Can I do more than on port, a 30^3ft build would be too long of a port could I do 2 shorter ports, or 3?
I am leaning toward a 36" sonotube 53" tall. If it is tuned to 16hz it looks like a pretty good line on winisd, but then again I do not know what I am doing in that program. Here is what I played with.
Old 02-17-11, 11:55 AM   #18
HTS Moderator
gperkins
Since: Aug 2008
I wouldn't bother with a 16hz tune on that sized sub. Here's a winisd file for you.
30 cu ft
Tune - 14hz
12" round port 42.84" long
Input power 1500 watts
Port velocity - 22 m/s
1st port resonance - 158hz
You could go with a 10" round port but it raises the port velocity up to about 32 m/s and if you decided to throw more power at it over the 1500 watts it would go higher.
cheers
Graham
Old 02-17-11, 12:41 PM   #19
Zeitgeist's Avatar
Jim
Since: Apr 2009
Ohio
My Photo Gallery
I'm going to go ahead and move this into the Ported Build projects - since it seems to be a better fit now..
Old 02-17-11, 01:16 PM   #20
1hagop's Avatar
Since: Apr 2010
Mountain House, Ca.
  1hagop is offline
30 cu ft
Tune - 14hz
cheers
Graham
Okay so I likes what I sees!
What do I do about the port. 12" PVC??? Do I center the port on the opposite side of the sonotube as the speaker or same side offset? I have never built a ported sub. Does the port tube stay straight or do I put a 90 in it.... I do not know
Thanks!
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > DIY Speakers | DIY Subwoofers > DIY Subwoofers > Ported Subwoofer Build Projects »
21", advice, build, ep4000, mal-x
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
