Fi Audio SSD12 Build Project - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 27 Old 10-25-07, 05:22 PM Thread Starter
hddummy's Avatar
Matt
The time has come for me to build another subwoofer!!! This one is for a friend of mine. I'm stoked!!! This will be essentially the same concept as my subwoofer seen here.
http://www.hometheatershack.com/foru...-feedback.html
Here is the plan so far. I will be using a Fi Audio SSD12 with dual 2ohm VC and an O-Audio 500W Bash amp. The box will be roughly 4.25 net cu.ft. and tuned to the 18-19Hz range. This one will also have an up facing driver The ports will either be in the top face or on one of the short side walls.
Comments/Suggestions about the hardware????
hddummy is offline
post #2 of 27 Old 10-25-07, 05:54 PM
Re: Well...I'm at it again!!!
I'll be looking forward to your progress reports...
I also moved this to the Fi Audio forum, but I left a redirect from the other forum in place for 30 days.
Sonnie is offline
post #3 of 27 Old 10-25-07, 05:55 PM
Mike P.'s Avatar
Mike
Sounds good. Make sure to post some build pics.
Mike P. is offline
post #4 of 27 Old 10-25-07, 09:59 PM
Will
Send a message via AIM to WillyD Send a message via Skype™ to WillyD
Do you already have the SSD12? If not, FiAudio may still have some of these X-series drivers left.
http://www.audiojunkies.com/blog/712
A pair of 12" X-series drivers for $160 shipped! Those in 8ft^3, VCs in series, drivers in parallel, tuned to 20Hz with 3 4" ports and hooked up to that Oaudio amp with the SSF set to 20Hz. Yeah, that'd work.
WillyD is offline
post #5 of 27 Old 10-26-07, 05:24 AM Thread Starter
hddummy's Avatar
Matt
Thanks for the suggestion, but I definately don't have room for two 12"s. Maybe two 10"s, but they didn't model quite as well as a single SSD12". That does look like a good deal though!!!
hddummy is offline
post #6 of 27 Old 11-03-07, 03:32 PM
Fi Audio
Plenty of X series drivers left. If anyone is interested in them I can post up info about them and even give a little further of a discount for the HTS forum members.
Fi Audio is offline
post #7 of 27 Old 11-08-07, 09:56 AM
NewbieMark
Inactive
Posts: n/a
^ These sound interesting, I would like more info.
post #8 of 27 Old 11-09-07, 08:55 AM
Fi Audio
The X series drivers were designed as our "entry level" car audio sub. They have 16mm of Xmax and 250W RMS power handling. They come only in dual 4 Ohm coil configurations so they can be wired for a single 8 Ohm load per driver or in pairs for a single 4 Ohm load.
As they were car oriented they tend to push for EBS alignments in most home applications. They make for a nice home sub, but not particularly a ultra deep HT sub.
There have been a couple of people that have done 6 cuft enclosures tuned to 23 Hz for home/music use using some of the common plate amps out there. As many have a SSF set to around 20 Hz it seems to work well overall.
Specs for the X12 are:
Fs 25.7
Re 3.9 Ohms per coil
Qms 4.01
Qes .38
Qts .35
Sd 481 cm^2
Vas 104.1 l
Xmax 16mm
BL 20
Spl 88.6 1W/1m
250W RMS
Specs for the X10 are:
Fs 25.9 Hz
Qms 3.90
Qes .35
Qts .32
Sd 310 cm^2
Vas 45.7 l
Xmax 16mm
Bl 20
Spl 85.4 1W/1m
250 W RMS
Both work well in mid/low 20 Hz builds in medium enclosures. They are well suited for music applications, but not as well for ultra deep HT setups. You could make some decently compact mid 20s tuned music/computer subs with them as well.
Ill see if I cant get some multi driver deals going if people want them as well...
Thanks,
Scott
Fi Audio is offline
post #9 of 27 Old 12-03-07, 07:23 AM Thread Starter
hddummy's Avatar
Matt
Sorry for the wait. The holidays are always a busy time of year. We finished the sub and I will be tuning it this weekend once the rest of his speakers show up.
hddummy is offline
post #10 of 27 Old 12-03-07, 08:20 AM
Mike P.'s Avatar
Mike
That's a good looking sub, Matt! What finish did you use on the cabinet?
Mike P. is offline
audio , build , fi , project , ssd12
