Yes, a lot of effort went into the design and fabrication process. They sound remarkable. What's cool is that they can be stacked in multiples. One could have wall to wall bass if necessary. I'm thinking auditorium.
They're quite heavy. I imagine that each segment weights about 600 lbs. That means the combined weight is 1200 lbs. Good thing my floor joists are 3x12s
If you go to his website that he posted you can read about his horn there.
I have been through your builds a number of times from your website. Great to have you here and posting pictures and info about your great projects. Always liked the 100hz you designed. Just was to big for me. I am still looking at building a smaller design that will be roughly 100hz but only 40liter design.
Either way thanks for sharing again.:T
Related Threads
posts
744K
members
174K
Since
2006
