| Projector Screens | DIY Screens Laminate Mounting Methods, Pros and ConsDiscuss Laminate Mounting Methods, Pros and Cons in the Home Theater | Audio and Video forum; Laminate Mounting Methods, Pros and Cons I've read laminate threads discussing various mounting techniques. They seem to break down into two general methods:
Method A: Laminate ... |
Views: 617 - Replies: 2
| Laminate Mounting Methods, Pros and Cons I've read laminate threads discussing various mounting techniques. They seem to break down into two general methods: Method A: Laminate is attached directly to the frame. Method B: Laminate is attached to an underlying substrate, such as 1/4" plywood or peg board and the resultant sandwich is then attached to a frame. I was wondering if one method has proven superior to the other. I remember reading that if the laminate is glued directly to the frame, it has a tendency to buckle if glued to all of the frame. I can see that gluing the laminate to a large sheet can be tricky. Are there other disadvantages? Doug | ||||
| | #2 | ||||
| Re: Laminate Mounting Methods, Pros and Cons I think weight would be a big factor in gluing laminate to a sheet of plywood, particle board or MDF. Plus getting the glue on evenly and rollering the laminate perfect would require some effort and skill. I think the drawback to the gluing method that you read applied to the thinner (vertical grade) laminates. | ||||
| | #3 | |||||
| Re: Laminate Mounting Methods, Pros and Cons Quote:
Rockler sells some nice french cleats. I'm thinking of using them to mount the screen to the wall. Since I'll be studding out the wall, I can put jack blocks at the appropriate positions for the cleats Doug | |||||
