Temporary Screen Solution - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss Temporary Screen Solution in the Home Theater | Audio and Video forum; Temporary Screen Solution I have a question. I have a Optoma HD70 projector in a light controled room. I have really enjoyed the ...
Old 04-07-08, 10:10 PM   #1 (Link)
Alias: Tiny
Loc: Tuscaloosa, Alabama
User: #19096
Since: Apr 2008
MonsterMaddness is offline
I have a question. I have a Optoma HD70 projector in a light controled room. I have really enjoyed the threads on the DIY laminate screens and would like to construct one myself but my wife and I plan on moving in the not to distant furture and would hate to spend that kind of money when hopefully I can project a bigger image in the furture. I went looking for a 4x8 piece of polywall thinking it would be a cheap tempoary screen but couldn't find it. I can't paint one because we will be trying to sell the house soon. I found a piece of white tile board I figured I could use but there's some pretty bad hot spoting on it. Is there anything I can do to elimanate it? Any help would be greatly appreciated.
Old 04-07-08, 10:31 PM   #2 (Link)
Alias: Harp
Loc: Central PA
Harpmaker's Avatar
User: #12848
Since: Oct 2007
Harpmaker is online now
Re: Tempoary Screen Solution
MonsterMaddness wrote: View Post
... I found a piece of white tile board I figured I could use but there's some pretty bad hot spoting on it. Is there anything I can do to elimanate it? Any help would be greatly appreciated.
Yep, paint it!
I would suggest starting with Kilz2 and see if that alone is what you want. If you need blacker blacks and more vivid colors then you can try one of the off-the-shelf neutral gray paints; and then, of course, there are the Black Widow mixes.
Old 04-08-08, 07:32 AM   #3 (Link)
Alias: Tiny
User: #19096
Since: Apr 2008
Thanks, is there any particular mix that stands out above the rest?
Old 04-10-08, 07:20 PM   #4 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
How long will you be in the house (and using this screen), Tiny?
Old 04-11-08, 08:39 AM   #5 (Link)
Alias: Tiny
User: #19096
Since: Apr 2008
Well, It's hard to say. We're not moving because of a job or to another state or anything like that, we just need a bigger place in a better part of town. We hope to move sometime in the next year. I went ahead and ordered some Henry's 558 roof coating. I think I'm gonna go with black widow. For the past year I've just been projecting onto a bare wall. I didn't get a screen cause I'm cheap and needed the money I would spend on a screen to put toward a receiver. However, I've really been impressed with these DIY threads and decided to make my own. I have already seen a HUGE improvement in the picture with just two coats of kilz2 but would like darker blacks.
Old 04-12-08, 01:42 AM   #6 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Sounds great! Keep us updated!
Old 04-17-08, 10:15 PM   #7 (Link)
Alias: Tiny
User: #19096
Since: Apr 2008
I went with a 4:1 LW mix. It does look great. Only thing, even after three coats I had some roller marks. You usually can't tell and have to be looking for them when you can. I'll probably try again when we move. I still got a whole can of Henery's 558.
Old 04-18-08, 12:27 PM   #8 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Did you add water to the mix tiny?
mech
Got questions? Start a thread.
Old 04-19-08, 05:38 PM   #9 (Link)
Alias: Tiny
User: #19096
Since: Apr 2008
Nope, I didn't see the post about adding water to the mix until after I had painted it unfortunately. However, now that the screen has fully dried, the roller marks are even less visible. Last night I had some friends over and my brother brought over his ps3 so we could watch some blue ray movies on it. I couldn't really see them even in some really white, snowy scenes of the film. Nobody even noticed and I asked them several times about it. But for future reference, how much water should you add to the mix? Also, which screen do you think looks better, black widow or a WA laminite screen?
Old 04-19-08, 08:24 PM   #10 (Link)
Alias: mech
mechman's Avatar
User: #6446
Re: Temporary Screen Solution
Well I only say add water if it dries to fast. The back rolling is essential when using HE558. Sounds as though yours has turned out fine though!
With regards to my Fashion Gray laminate, I prefer Black Widow. My FG screen has turned a touch greenish as the polyurethane has cured over time. I'll be spraying it soon!
mech
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
Cheapest IR solution possible brandonnash Remotes | Cables | Accessories 5 02-26-08 09:32 PM
Looking for Screen Paint Solution Panny82 Projector Screens | DIY Screens 40 12-03-07 07:39 PM
Easy-Flex DIY Painted Screen Solution Tiddler Projector Screens | DIY Screens 87 10-01-07 02:59 PM
Temporary Treatments as Trial to Permanent srckkmack Home Audio Acoustics 20 03-29-07 01:16 PM
Mach 5 Audio
