Next on my list... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Next on my list...
Discuss Next on my list... in the Home Theater | Audio and Video forum; Next on my list... Deciding upon a Black Widow formula for me Spraying my Fashion Gray Laminate with Black Widow Testing samples of the ...
Old 04-13-08, 12:57 AM   #1 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is offline
Next on my list...
  • Deciding upon a Black Widow formula for me
  • Spraying my Fashion Gray Laminate with Black Widow
  • Testing samples of the UK Black Widow
  • Dulux Vivid White
  • Auto Air Aluminum medium and coarse
  • Checking out Harp's Cream and Sugar - I like the name Don!
Anything else I should be looking at?
mech
Got questions? Start a thread.
Old 04-27-08, 03:55 PM   #2 (Link)
Alias: mech
mechman's Avatar
User: #6446
mechman is offline
Re: Next on my list...
mechman wrote: View Post
  • Dulux Vivid White
One and two are out lately due to inclement weather again - it's snowing right now believe it or not!
I've tested the UKBW and am forwarding them a sample of Bermuda Beige.
The last three I'm in no hurry to accomplish.
I've added a few things though.
Someone pm'd me where tiddler stated that a behr 1850 reference gray mixed with 25% Minwax poly will give 'close' to the same results of BW. So I have some of that and the third coat is drying. I'm not expecting much as tiddler is the same individual who recommended the Dulux 'Veil' and then of course changed the brand of paint. He's also the same individual who stated that BW needed to be compared to a similar shade, that was done as well. Last I heard he's on a sheen kick over at AVS. If you ever head over there check each of his posts and see if they have been edited. I'd hazard a guess of over 50%. So yes I'm, playing Mythbuster on this one too. Anyone hazard a guess what will be next?
I'm also working with some white paints I've found that piqued my curiosity. I have one panel drying and another to start on after the last coat for the first.
Finally I'm also mythbusting the flat paint diatribe. I've tested Pittsburgh Paints flat Bermuda Beige with AAA and it came out neutral. And in my little sample I saw lots of Aluminum at the surface so I'm painting a panel of that as well.
Had the weather not turned sour I think I would have been doing yard work!
mech
Old 04-27-08, 06:49 PM   #3 (Link)
Alias: mech
mechman's Avatar
User: #6446
mechman is offline
Initial assessment of this is 'busted'.... again. While it hasn't really cured yet, this thing hot spots like no tomorrow! And why oh why would someone recommend adding sheen to a flat enamel/matte paint?!?!?! Might as well just use satin...
Numbers were neutral though. Again it's not cured but the initial numbers
190 189 188
0.314 0.331 51.2
76.8 -0.02 0.75
6408.6
I'll bet it will cure a bit tighter to neutral. But I doubt curing will do anything with all this sheen. Looking at this, I can definitely say that sheen plays a very small, if any, part in BW-AAA. And I can honestly say that a lot of folks have told me that sheen can be a bad thing - Bill, Smokey, etc. And this particular example will be a very good example of too much!
It will also serve as an excellent opportunity to show hot spotting on a less than 100" screen.
mech
Old 04-27-08, 08:26 PM   #4 (Link)
Silver Supporter
Alias: muzz
Loc: Easton,MA
User: #4518
Since: Nov 2006
muzz is offline
Yeah.....OK ...
OK Cheswick, whatever
Yeah, the sheen is the difference.......
Heard that ridiculous before..
"I want MY cigarettes Nurse Ratched, MINE noone elses"!!
Old 04-28-08, 09:54 AM   #5 (Link)
Alias: mech
mechman's Avatar
User: #6446
mechman is offline
Who says flat paint doesn't work well with Black Widow?
PPG flat 4:1 with AAA
192 192 193
0.311 0.328 53.7
78.3 -0.20 -0.67
6553.9
I'll get some photos later but the aluminum is clearly evident at the surface and at this point I see no reason why this would perform any differently than the flat enamel. I'll do some comparison photos to the behr reference gray in satin.
mech
Old 05-04-08, 01:28 AM   #6 (Link)
Alias: mech
mechman's Avatar
User: #6446
mechman is offline
I'm thinking that I may actually get around to spraying this week.
The two whites that I've tested have exhibited the same faults that all whites seem to exhibit - Red and Green numbers are the same and the Blue drops off 4 points or so.
While one was the brightest white I've spectro'd so far it offered nothing new to the table. And since they're not readily available and more expensive than off the Shelf whites, I'm tabling that stuff for possible future use.
I'll try to get the pics of 'tiddler's reference gray' done this week as well.
After a bit of thought, I've removed my diatribe as it didn't pertain to anything of importance. It was just a bit of amazement how someone needs to come up with their own set of standards... constantly.
Back to developing... it's what we do here at the Shack!
mech
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
Craig's List add SteveB Chat Box 4 10-11-07 12:12 PM
Equipment List abhi Home Theater Equipment 0 01-29-07 12:42 PM
Equipment List Wayne A. Pflughaupt Home Theater Equipment 0 01-09-07 05:42 PM
Tom's Theater List Tommy Home Theater Equipment 2 05-25-06 07:55 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
