Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Which munsell number is Black Widow?
Discuss Which munsell number is Black Widow? in the Home Theater | Audio and Video forum; Which munsell number is Black Widow? Does anyone know aproximately where Black Widow would fall on the munsell scale? I currently have a one can solution ...
Elite Screens
Views: 535 - Replies: 1
Old 08-22-08, 04:40 PM   #1
Alias: Harry Muscle
User: #9944
Since: Jul 2007
  Harry Muscle is offline
Does anyone know aproximately where Black Widow would fall on the munsell scale? I currently have a one can solution that's aprox. N8.5 but will be switching to a brigher projector and am thinking of going for a darker screen, probably a N8.
Thanks,
Harry
P.S. My current projector is a Benq W100 but I'm going to be switching to a Mitsubishi HC1500. Screen size is aprox 95".
Old 08-22-08, 08:20 PM   #2
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
Re: Which munsell number is Black Widow?
Black Widow is an N7.5 shade of gray.
One thing to note though, it doesn't perform like a simple OTS gray that would be the same shade. The blacks would be the same, but whites and colors would be much brighter. Basically, if your projector can handle an N8 gray (which most newer projectors can with no problem at all) then you can handle the original Black Widow mix.
Very soon there will be a BWN8, BWN8.5 and even a BWN9 in addition to the original Black Widow that's an N7.5!
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
black, munsell, number, widow?
