Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Screen shots of Elite Cinegray screen?
Discuss Screen shots of Elite Cinegray screen? in the Home Theater | Audio and Video forum; Screen shots of Elite Cinegray screen? I'm wondering if anyone has any screen shots of the Elite CineGray screens (doesn't matter exactly which screen since I ...
Elite Screens
Views: 727 - Replies: 7
Old 10-30-08, 02:48 PM   #1
Alias: Harry Muscle
User: #9944
Since: Jul 2007
  Harry Muscle is offline
I'm wondering if anyone has any screen shots of the Elite CineGray screens (doesn't matter exactly which screen since I believe the material is all the same across all their lines as long as it's called CineGray). If you have a comparision between it and CineWhite that would be fantastic, however, at the very least I'm looking for a shot of CineGray.
Thanks,
Harry
Old 10-30-08, 04:15 PM   #2
Alias: Harry Muscle
User: #9944
Since: Jul 2007
Re: Screen shots of Elite Cinegray screen?
I just found a full blown review on the CineGray screen with two screen shots ... in case anyone else is interested it's located here: http://www.projectorreviews.com/proj...meHC/index.php
So now the only thing left (or so I think ) is to get input on wether a CineGray screen or PowerGain screen would do better in a room with poor light control ... but I created a new thread with that question so as to keep things organized .
Thanks,
Harry
Old 10-31-08, 10:55 AM   #3
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
Harry I'll have to look up the PowerGain, off the top of your head do you know if it is a retro-reflective screen? If so and if your projector is ceiling mounted then any benefits of the higher gain will be negated.
It also depends on how dark the CineGray. Off hand I would take a guess that with poor light control you'll be better off with the CineGray and the viewing cone should also be much wider than a higher gain screen.
Even with the extra gain, you're going to take a hit with black levels with lighting issues.
Remind me of your layout and projector again please.
Old 10-31-08, 11:11 AM   #4
Alias: Harry Muscle
User: #9944
Since: Jul 2007
We're moving places, but the plan is that the projector is going to be a Mitsubishi HC1500 and it will be ceiling mounted. The room layout is 10x20 feet with the screen at one end and seating at the other so seating distance is about 17 feet or so. There's windows located directly behind the seating area, which will have blinds, but during the day there's gonna be a decent amount of light spillage. During the night I will probably have a small light on since my wife doesn't like watching in complete darkness. Also the planned color for the walls is fairly light and the ceiling is white.
Currently I have a painted N8.5 screen (using one of the exterior Behr paints recommended here) so I'm already used to a gray screen. Also the projector I have right now is a Benq W100 which is dimmer than the HC1500 that I will setup in the new place.
My first inclination is to go with the CineGray since gray screens seem to be better able to deal with ambient light, however, I see recommendations for high gain screen in situations that have ambient light also. So basicaly I'm trying to figure out which will produce better result in the presence of ambient light, a gray screen or high gain screen. Btw, the ambient light in my situation is coming from behind the sitting area, not the sides.
Thanks,
Harry
P.S. I know this setup isn't anywhere near ideal, but I'm trying to make the best I can of the situation.
Old 10-31-08, 11:22 AM   #5
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
Again the big factor will be if the high gain screen is a glass beaded retro-reflected screen. If so, then skip it, you won't get the benefits of the higher gain with a ceiling mounted projector, in fact it could make things worse.
Let me explain- IF it is a retro-reflective screen that means it will reflect light back at the source (think a traffic sign and your headlights). This would reflect light back up at the projector and ceiling, and with a light colored ceiling that light will then reflect back onto the screen causing the image to wash out some.
If it isn't a retro-reflective screen, see if they will send you a sample to check out and see how you like it. Always remember to recalibrate though when going from a white screen to a gray screen, it really does make a huge difference.
Old 10-31-08, 11:29 AM   #6
Alias: Harry Muscle
User: #9944
Since: Jul 2007
Sorry, I forgot to add that piece of info. From that I've read on the various news groups, it's angular reflective, not retro-reflective.
Thanks.
Old 10-31-08, 03:06 PM   #7
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is online now
You are correct Harry and everything you need to know about the PowerGain is in my review.
Like most high gain materials I've looked at, there's a touch of graininess in bright white scenes. BW has a extremely slight graininess too if you stand close to it.
I'll try and get in touch with Elite for a CineGrey sample later today.
mech
Old 10-31-08, 03:27 PM   #8
Alias: Harry Muscle
User: #9944
Since: Jul 2007
I bit the bullet and bought the Elite EzFrame CineGray screen. I found an amazing deal on eBay and just couldn't pass it up ($160 shipped for a 106" screen). Once I get it and have it setup (which will be a few months since we're moving, etc.) I'll try to post my comments. In the mean time though I'd love to hear your review if they send you a sample.
Thanks,
Harry
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
cinegray, elite, screen, screen?, shots
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
