Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Attaching screen matrial to frame, argh
Discuss Attaching screen matrial to frame, argh in the Home Theater | Audio and Video forum; Attaching screen matrial to frame, argh I evaluated materials and purchased some CenterStage XD from seymourav. Built the frame over the weekend and got to the ...
Elite Screens
Views: 312 - Replies: 3
Old 08-03-09, 08:52 AM   #1
Alias: patchesj
User: #38686
Since: Jun 2009
  patchesj is offline
I evaluated materials and purchased some CenterStage XD from seymourav. Built the frame over the weekend and got to the point of attaching the material. I am using the screen door channel and laying the screen material in with the tool and spline. I'm having a hard time figuring out the best way to do this. It might be that I was tired and was covered in velvet and spray glue, but I quickly threw in the towel last night. Is there a special trick to getting this done? The instructions I have say to start in the top left corner and work a few inches at a time, alternating between the top rail and side rail and then around to the bottom right corner. I've been able to get about 2 feet in either direction before being perplexed with wrinkles. FYI the screen is 110x62.
Thanks!!
Old 08-03-09, 12:06 PM   #2
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is online now
Re: Attaching screen matrial to frame, argh
You may want to try this method. It's from Elite and it's for their material. But I'm certain it would be universal for stretching screen material.
Gain Readings
Spectro Readings - not up to date but will be soon
Old 08-03-09, 12:11 PM   #3
Alias: patchesj
User: #38686
Since: Jun 2009
  patchesj is offline
Hmm. starting in the center of the long bars makes more sense to me. Starting in the corner just wasn't doing it. I'll try this tonight.
Thanks
Old 08-03-09, 12:18 PM   #4
Alias: mech
mechman's Avatar
User: #6446
If that doesn't work, put in a shout to Chris. He's a pretty fast responder.
Send Chris a pm.
Gain Readings
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
argh, attaching, frame, matrial, screen
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
