Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Screen Build Help!!
Discuss Screen Build Help!! in the Home Theater | Audio and Video forum; Screen Build Help!! I am setting up a home theater in the basement and was looking around the site for a good design ...
Elite Screens
Views: 443 - Replies: 11
Old 11-03-09, 11:54 AM   #1
Alias: BengalfanMT
Loc: Big Sky Country MT
User: #44266
Since: Nov 2009
  BengalfanMT is offline
Screen Build Help!!
I am setting up a home theater in the basement and was looking around the site for a good design to build a 110" 16 x 9 screen. I would also like to make a masking system either removable or mechanical. I have read some people using the pink foam board but ideally would like to have a mechanical version so I have more flexibility for different aspect ratios. Any links to some good builds would be appreciated as well as some detailed instructions. I am pretty handy but would like this to look as nice as possible. Thanks for the help in advance.
Old 11-04-09, 12:36 PM   #2
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Re: Screen Build Help!!
The only thing I can think of would involve curtains and or their hardware. I don't think I've ever seen a write up here on anything like this. So I'm counting on you!
Gain Readings
Spectro Readings - not up to date but will be soon
Old 11-04-09, 12:46 PM   #3
Alias: BengalfanMT
User: #44266
Since: Nov 2009
I will keep you posted if I figure it out. I work in the window business and was thinking of attaching the screen using screen spline. Have you ever heard of people having any luck with that? Thanks
Old 11-04-09, 10:38 PM   #4
Alias: mech
mechman's Avatar
User: #6446
  mechman is offline
BengalfanMT wrote: View Post
Yes I have seen that used before. I believe they used the heavier gauge (?) spline if that helps. And I believe wbasset has done some experimenting with it as well. He should chime in soon.
Gain Readings
Old 11-07-09, 07:35 AM   #5
Alias: mjg100
Loc: Glasgow, Kentucky
User: #18092
Since: Mar 2008
  mjg100 is offline
mechman wrote: View Post
I knew I should have started a new thread. Read posts #5 & #6 for my mechanical horizontal masking system on my 106" AT screen. www.hometheatershack.com/forums/projector-screens-diy-screens/21538-converting-106-elunevision-screen-screen.html
Old 11-07-09, 07:37 AM   #6
Alias: mjg100
User: #18092
Since: Mar 2008
  mjg100 is offline
Posts #5 & #6. www.hometheatershack.com/forums/projector-screens-diy-screens/21538-converting-106-elunevision-screen-screen.html
Old 11-07-09, 07:39 AM   #7
Alias: mjg100
User: #18092
Since: Mar 2008
  mjg100 is offline
Same link, read the first post. www.hometheatershack.com/forums/projector-screens-diy-screens/21538-converting-106-elunevision-screen-screen.html
Old 11-13-09, 01:39 PM   #8
Alias: BengalfanMT
User: #44266
Since: Nov 2009
Thanks for all the help, for the time being I made my 110" fixed screen with seperate outside frame and will adapt my masking system to it. I did attach the screen with the spline from a window screen and it worked out great. It passed the WAF as well because she sent and email to me saying she was not at all excited about having a screen compared to the wall untill we watched a movie on it last night and she was letting me know that she was bragging to her friend how nice it looked!! Now to the masking system.
Old 11-19-09, 05:30 PM   #9
Alias: steiny93
User: #31709
Since: Jan 2009
  steiny93 is offline
idea for the masking
have you ever looked at how a stewart masking screen operates? they are incrediblely simple
basically they have a spindle at the top which the material rolls onto and off of
a metal spindle / black out material / stepper motor with a stop and your golden
I have one of the stewart auto masking screens, if your interested let me know and I could shot some pics of the mechanism for you if interested
Old 11-19-09, 06:10 PM   #10
Alias: mech
mechman's Avatar
User: #6446
  mechman is offline
Steiny,
Take the shots! They may be helpful to others in the future.
Gain Readings
Old 11-19-09, 08:06 PM   #11
Alias: mjg100
User: #18092
Since: Mar 2008
  mjg100 is offline
How close is the masking to the actual screen material?
Old Yesterday, 11:04 AM   #12
Alias: BengalfanMT
User: #44266
Since: Nov 2009
steiny93 wrote: View Post
I could use the pics if you would put them up. The screen has been great so far and would like to see how that system works. Thanks in advance.
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
build!!, screen
