| Projector Screens | DIY Screens gray balance before taking photos and GTI N8Discuss gray balance before taking photos and GTI N8 in the Home Theater | Audio and Video forum; gray balance before taking photos and GTI N8 JimP wrote:
Hi boys..............can a pro photographer join into the discussion?
To tell you the truth Jim, you the kinda ... |
| | #26 (Link) | |||
| Re: gray balance before taking photos and GTI N8 To tell you the truth Jim, you the kinda person we've been looking and waiting for! Thanks for joining in! Now I've got read all these posts and get caught up. I'm sure I'll have a couple questions when I'm done! mech Got questions? Start a thread. | |||
| | #27 (Link) | ||||||
| Re: gray balance before taking photos and GTI N8 Quote:
Oh good golly yes! First the question, how do I white balance screen shots using the whibal card? Now a couple screen shots to help with my questions: Full ambient light shot: ![]() Medium to low ambient light shot: ![]() Dark shot: ![]() What would be the correct procedure for white balancing using the neutral gray card in these shots? Would it be best to set the card down in front of the screen using the ambient light? Or would it be best to take a shot with a white light projected onto the screen and the card on the screen? Of course doing this with each stage of ambient light. Thanks again for piping in Jim! It is appreciated! mech Got questions? Start a thread. | ||||||
| | #28 (Link) | |||||
![]() Bill you know as well as I that when that 'resident heavy' talked, we all donned the mudders! Those would be knee boots for working in the muck folks. That guy threw alot of garbage around... still does.Quote:
When kenyee brought up white balancing elsewhere it was kind of eerie for me. I was actually thinking about it quite a bit but never thought to ask. I'm happy we found a forum with some help available!mech Got questions? Start a thread. | |||||
| | #29 (Link) | ||||
| | #31 (Link) | ||||
I posted some pics a ways back. But it can be either or both for most folks. If I'm watching early in the day, I have some filtered outside light coming in. At night there's usually incandescents lit up. mech Got questions? Start a thread. | ||||
| | #32 (Link) | ||||
"Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #33 (Link) | ||||
That's basically my background and interst in this Jim... to be able to take pictures that are accurate to what I see on the screen. ![]() Thanks for jumping in here and lending a hand. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #34 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Alright I've done a bit of testing and I've found out that using the whibal card off of the screen to attempt white balancing doesn't work. As I was setting up the shot and looking at it I realized how ridiculous it was. With the image on the screen being as bright as it was, the whibal card was in darkness - even in medium ambient light. The resulting "balanced" pictures, after adjustment in photoshop, took on an extreme blue push. Unfortunately I cannot post the result. Being disgusted with myself for even thinking of it as a possibility, I discarded the images - quicker than the recycle bin could save them! I then set up the whibal on the screen and looked for what to use to project my white light on the screen. The few that know me here know I've always got a hockey game saved. So ice it is! I took two shots each of low - no ambient light, medium ambient light, and high ambient light. I then took shots of Bugs! A Rainforest Adventure. As soon as I'm done with the conversions I'll post them. But first a quick question for anyone here (and reading this for that matter). My thought process has me thinking that the ice shots I took, of each ambient light value, could be white balancing reference shots for good. Meaning I shouldn't have to retake them every time I take new shots, I could use the ones I took today. I'd appreciate anyone's input on this. Does it sound valid? I do know that tonight I will take 6 more reference shots when there's no daylight coming in. What do you think? mech Got questions? Start a thread. | |||
| | #35 (Link) | |||
| Re: gray balance before taking photos and GTI N8 O.K., anyone live in or around Montgomery or Wetumpka where I can come over and do some live testing? or I guess I can pull out my projector. Forgot I had one. ![]() I want to answer everybody's question which in part will require some research into each camera that's mentioned. I've got something I want to try first. Be back in a few minutes. | |||
| | #36 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Nope. I'm way north of you! I have to do a little more reading on the whibal card and how to do batch processing of white balances. Right now it seems extremely tedious to me and I know that there's got to be a better way. I'm off to soccer and T-ball with the kids for the evening. I'll be back later. Hopefully I can figure this all out shortly. Jim, From what I can tell, you have to set the white balance from the projected image. And I figured I'd have to use a white image. Do you think I can save these white balance figures and use them 'easily' for subsequent shots under the same lighting environments in the future? Let me know what you think... mech Got questions? Start a thread. | |||
| | #37 (Link) | |||
| Re: gray balance before taking photos and GTI N8 mechman, Using your E-500, use this one touch white balance procedure on page 90 of this pdf from Olympus. http://www.olympusamerica.com/files/...d%20Manual.pdf You will want to do this with each room lighting situation with your white card and a clear white projection from your projector. White snow is typically a little blue, so that would likely scew your color balance. Be sure to fill the camera viewfinder. One thing to think about is that your projected image should be based on 6500k, where your incandesent lights are somewhere between 2800 and 3400K. What they are likely doing is affecting your projected shadows more than the highlights. Color balancing for these type things generally presumes that everything is shifted an equal amount which isn't your case. Using the white card rather than the screen to perform the white balance procedure above will shift your color if the two are different. You might do as well using the white card when you are comparing screens to more accurately contrast the differences in the screens. Otherwise, if you are just wanting to show an image off of your screen (provided its different than the white card) make the white balance measurement off of the screen. What kind of bulbs are those in the ceiling? | |||
| | #38 (Link) | |||
| Re: gray balance before taking photos and GTI N8 kenyee, Is this the manual white balance you're referring to in your earlier post? http://www.fujifilm.com/products/dig...es/fxf30_e.pdf page 70 under "Custom White Balance". | |||
| | #39 (Link) | |||
| Re: gray balance before taking photos and GTI N8 wbasset Unfortunately, your S3100 doesn't have a custom white balance function. The closest white balance setting is going to be Daylight, which is probably 5200K. You'll still be 1600K off provided your projector is putting out 6500K. Page 42 under "white balance" http://www.fujifilmusa.com/JSP/fuji/...100_Manual.pdf | |||
| | #40 (Link) | ||||
![]() So when I hold the whibal card and white balance the camera using it, do I use the ambient light or should I project a white light? Thanks for the help Jim and you can call me mech (like mechanic), that's what my friends call me. mech Got questions? Start a thread. | ||||
| | #41 (Link) | |||
| Re: gray balance before taking photos and GTI N8 mech, Start with taking a reading (whether its off of the white card or the screen) with projector only if you are in a totally dark room. With combination lighting, take a reading off of the screen with both the projector and incandesent lighting on. When you did the custom white balance shot that came out blue, did you have a white light from the projector or was it with room lighting. I would speculate that it was with room lighting. That would explain the strong blue shift with the projected image. | |||
| | #42 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Room lighting. I read somewhere it may have been because the sheet of paper I used may have been bleached. Do incandescents always give out a blue push? mech Got questions? Start a thread. | |||
| | #44 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Well I've got the pocket whibal so I can't really use it as a manual white balance card. Can't get the white on it to fill the lense. I have DirecTV though and their new 'theme has a lot of white in it. I used that. Between that and bumping the f/stop up one it seems to have worked. The nice part is I can save the image on the camera as a jpeg after the manual white balancing and it looks a lot better than the one I converted earlier in Photoshop. Here's the earlier on top and the new on the bottom. ![]() ![]() The original RAW file for these two pictures seem identical in color, brightness, etc. It's amazing how much was lost converting it in Photoshop as opposed to the camera saving it as a jpeg. mech Got questions? Start a thread. | |||
