| Projector Screens | DIY Screens gray balance before taking photos and GTI N8Discuss gray balance before taking photos and GTI N8 in the Home Theater | Audio and Video forum; gray balance before taking photos and GTI N8 kenyee wrote:
If you take pictures in RAW, it's probably better to do it in post. If you're shooting JPEG, ... |
| | #51 (Link) | ||||
| Re: gray balance before taking photos and GTI N8 Quote:
grrrrr. I'll have more time to experiment later after I figure out the nuances of shooting in RAW with the whibal card. Shooting jpeg seems much easier...I'll shoot for the blue sunlight next chance I get. ![]() mech Got questions? Start a thread. | ||||
| | #52 (Link) | |||
| Re: gray balance before taking photos and GTI N8 mech I think it would be more accurate to shoot in raw and white balance it photoshop because that would take into account color shifts by strong color in other parts of the image. For convenience, jpeg would be better. For white balancing on the Direct TV bar, try a manual white balance using the white area to the right of the "DirectTV" logo. To my eye the picture looks a tad warm which is confirmed by taking some measurements. A manual white balance on this other white block might get you a tad closer. As for the red rope lights around the frame, aaargh. ......by the way guys, does anyone know why sometimes I get the instant email notifications and other times I don't?? | |||
| | #54 (Link) | ||||
As always thanks Jim! mech Got questions? Start a thread. | ||||
| | #55 (Link) | ||||
... but if it's a forum problem, everyone should experience it. ![]() | ||||
| | #56 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Hi Sonnie, Putting my detective hat on, how often does the system send out emails once a new post is made? For instance, does the system cycle every 30 minutes to see if a post is made and if so, then sends out emails? | |||
| | #58 (Link) | |||
| Re: gray balance before taking photos and GTI N8 OK I've taken my reference images, which I'll post below. There are 6 photos two each of High, Medium, and No ambient light. One set when there was filtered light coming in through the shades and one set taken when it was dark. Top three with filtered outside light coming in - bottom three with no light filtering in through the windows. From left to right, they'll be high ambient, med ambient, no ambient. All shot in RAW format and white balanced using the Whibal card in Photoshop cs2. ![]() ![]() Those should be OK for white/gray balancing all future photos taken in the same light conditions, right? Ken? JimP? Do you think I should have taken a closer shot of the Whibal card? Let me know what you two, and anyone else for that matter, think. For those wondering that's Designer White laminate on the left and Fashion Grey laminate on the right (my screen). mech Got questions? Start a thread. | |||
| | #59 (Link) | |||
| Re: gray balance before taking photos and GTI N8 mech, In Photoshop CS2, rawconverter, were you using the eye dropper tool located third from the left in the upper tool bar? If you were and the whibal card was larger than the tool, you should be O.K. To my eye, the grayish whibal card look a little different from one shot to the next. Is is apparant though that darker areas of the screen are influenced more by ambient lighting than the lighter areas. | |||
| | #60 (Link) | |||
| Re: gray balance before taking photos and GTI N8 JimP, Yes, but I was just using the <shift> key to get at it. I did notice when I zoomed in that the RGB numbers varied slightly as I moved it around. mech Got questions? Start a thread. | |||
| | #61 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Mech, That's not the eyedropper tool thats 3rd item from the left. That's the fourth item that gives you the RGB numbers. With the eyedropper that's third from the left enabled, you move the eyedropper to what should be a neutral gray and click it. That color balances your photo based on the area that the eyedropper covers. Are we talking about the same thing?? | |||
| | #62 (Link) | |||
| Re: gray balance before taking photos and GTI N8 I'm basically doing it the way it was shown in the videos from the Whibal manufacturer. I open up Adobe Bridge, browse to the Raw files, double click on the one I want to balance, and this opens up Photoshop with the "workflow" window. On a side note, I'm not all that fluent in Photoshop so please bear with me! In that workflow window if I hit the <shift> key it will switch to the white balancing tool. In the upper right of this pane there's the color histogram and above that are the RGB numbers. It doesn't matter which tool I use, I get the RGB numbers for where the cursor is. Hopefully that's a bit more clear to you, cause it's still a wee bit muddy to me! ![]() mech Got questions? Start a thread. | |||
| | #64 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Jim, What are you thoughts on using those particular shots as templates for white/gray balancing further screen shots within that type of ambient light? mech Got questions? Start a thread. | |||
| | #65 (Link) | |||
| Re: gray balance before taking photos and GTI N8 mech, those look good. Did you also lock the exposure on the camera (shutter/aperture/iso)? I noticed the white/gray don't look the same brightness in all pics, but that's probably what it should be. They do look properly gray to me (no weird coloration from the ambient light. I should do the same with my setup so we can compare results now that I finally have a K10D and full manual control instead of using my F30 :-) | |||
| | #66 (Link) | |||
| Re: gray balance before taking photos and GTI N8 I don't think I thought of it there. I left it on auto. I do believe the iso was locked at 100 though. When I took my DW and FG shots I just had the iso locked as well. Because of the difference in ambient light I left the aperture at auto. It doesn't appear that they're over exposed much. It's kind of tough not to over expose when shooting a bright image in the dark! mech Got questions? Start a thread. | |||
| | #67 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Will work only up to a point. Strong color that takes up a good part of the screen will influence the rest of the picture. You'll be in the ballpark, but fine tuning will likely be necessary. | |||
| | #71 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Since we're talking about why screenies don't matter, I thought it would be good to bump this oldie but a goodie which explains some of the things you can do to get an accurate color balance in your photos. While I'm not a big fan of bumping threads for 'hearing one talk to oneself', I think this one deserves to stay fresh in everyone's memory. ![]() mech Got questions? Start a thread. | |||
| | #72 (Link) | |||
| Re: gray balance before taking photos and GTI N8 Great point. The "screenies don't matter" idea is correct in many ways, but the fact is that they generate interest and people like to share them, and they are fun to share. They are useful for comparisons in the same image such as the screen materials, and for demonstrating artifacts and symptoms. A better understanding of how to do it right can make it more likely that they are useful. They are also more fun and more interesting when done well, and we know how most of us are crazy about finding better ways to do things. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
