| Projector Screens | DIY Screens Material for DIY acoustically transparent screenDiscuss Material for DIY acoustically transparent screen in the Home Theater | Audio and Video forum; Material for DIY acoustically transparent screen Any ideas on good performing but affordably priced material for a DIY acoustically transparent screen?... |
Views: 2335 - Replies: 13
| Material for DIY acoustically transparent screen Any ideas on good performing but affordably priced material for a DIY acoustically transparent screen? | ||||
| | #2 | |||||
| Re: Material for DIY acoustically transparent screen Quote:
mech | |||||
| | #3 | ||||
| Re: Material for DIY acoustically transparent screen Hey! Are you in the Twin Cities? Preferably the south metro? mech | ||||
| | #4 | ||||
| Re: Material for DIY acoustically transparent screen Thanks for the speedy reply Mech! I live in Chaska and I can definitely wait for your review...looking forward to it. Any thoughts on the SmX screens/material? | ||||
| | #5 | ||||
| Re: Material for DIY acoustically transparent screen To be honest with you, I haven't looked at them yet. ![]() If you want to come take a look at them pm me. Chris Seymour sent me a nice 24"X24" piece. The Da-Lite samples are small - 8"X8". I'll bet Chris will chime in here soon... maybe he can give you some pricing info on his screen material. mech | ||||
| | #6 | |||||
| Re: Material for DIY acoustically transparent screen Ooops you said Quote:
mech | |||||
| | #7 | ||||
| Re: Material for DIY acoustically transparent screen PM me for a sample if you like. You can also find downloadable comparative audio tests. Cheers, Chris Seymour AV | ||||
| | #8 | ||||
| Re: Material for DIY acoustically transparent screen Thanks Chris...PM sent. | ||||
| | #10 | ||||
| Re: Material for DIY acoustically transparent screen Chas has yet to decide if I recall correctly. ![]() | ||||
| | #11 | ||||
| Re: Material for DIY acoustically transparent screen I was leaning towards the SeymourAV material...but abandoned the whole idea as I felt the viewing distance was too close, and the screen size too small for good results with an AT material. | ||||
| | #12 | ||||
| Re: Material for DIY acoustically transparent screen As far as the Da-Lite screen goes.. you can request a sample pack via their website. They sent me a nice pack of various screen samples and a catalog for free. Received it within a couple of days. | ||||
| | #13 | ||||
| Re: Material for DIY acoustically transparent screen I used the CCC material from Dazian for my acoustically transparent screen. I feel it works very well and looks good. And, we only sit about 9' away from it using an old XGA Panasonic LCD projector. I only needed a few dB boost in the high end (put into the crossover) to compensate for speakers behind the screen. My new receiver has Audyssey EQ however, so that would no longer be required. | ||||
| | #14 | ||||
| Re: Material for DIY acoustically transparent screen I am also looking at the Seymour AT screen 12' wide 16.9, I am going to build a Torus insted of a flat screen. Looking forward to your test results. Thanks, Rick. | ||||
