New Projector - need advice on screen gain - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss New Projector - need advice on screen gain in the Home Theater | Audio and Video forum; New Projector - need advice on screen gain Hi: I am in the process of moving and building my second home theater. The first was built about 8 ...
Old 08-13-07, 06:02 PM   #1 (Link)
New Member
Alias: Smitty
Loc: South Carolina
User: #10834
Since: Aug 2007
  srsmith is offline
Hi:
I am in the process of moving and building my second home theater. The first was built about 8 or 9 years ago..and I relied on the dealer to select the screen to go with a DWIN.
I just purchased the new projector - a Sony "Pearl" . I've been reading a lot about gain ratio's for projectors and am getting more confused. Based on some reviews I've read, it seems that a gain of less than 1.0 would be preferrable to a gain of greater than 1.0 in a dedicated room, and the I should seriously look into a light gray screen.
The new home will have a dedicated theater, with no light leakage, (windowless room off of a lower level). Based on the room size I am probably going to go with something like 110" diagonal 1: 1.78 screen
Based on some the threads posted I was looking at high contrast gray Carada with a 0.8 gain.
Any suggestions?
Old 08-13-07, 06:17 PM   #2 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
  wbassett is offline
Re: New Projector - need advice on screen gain
is it the VW100 or VW50?
Old 08-13-07, 06:38 PM   #3 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
  mechman is offline
srsmith wrote: View Post
Any suggestions?
Did you read this? I wouldn't recommend it. I'm going to be reviewing some Da-Lite samples the next couple days if you want you could watch for them. If you really want the Carada though, I'd go with either the Classic Cinema White or the Brilliant White.
mech
Old 08-15-07, 01:07 PM   #4 (Link)
New Member
Alias: Smitty
Loc: South Carolina
User: #10834
Since: Aug 2007
  srsmith is offline
Its a VW 50
Old 08-18-07, 01:20 AM   #5 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
  wbassett is offline
srsmith I agree about holding off just a bit for the Da-Lite screen reviews, they have some very interesting screen options.
For a 110" diagonal image with the VPL-VW50 you're going to have around 9fL of light at the screen with a 1.0 unity gain white screen.
I think a mistake most people do when they are thinking about gain is they aren't always looking at the big picture. You want a minimum of 12fL at the screen for a total light controlled environment. If you have ambient light issues you will need even more foot Lamberts.
So gain is used as needed to hit the desired level of screen image brightness based on your situation. For you, right out of the gate you need some gain for a 110" diagonal screen. To hit that you are going to need something 1.4 or higher.
The Video Spectra is a 1.5 gain white screen with a 35 degree viewing cone.
You can possibly get away with Da-Lite's Silver Matte screen which is a 1.3 gain screen but it is rather dark and I am afraid your whites will go muddy with it. You could always request a sample and try it, but with 11fL I think you may not like it.
Their Pearlescent screen is also a contender, darker than the Video Spectra, but not too dark. I estimate it around an N9 in shade. It also has a gain of 1.5. Again, request a sample, you may like this one a lot.
I'll get some information on some other screen materials for you, but the Pearlescent and the Video Spectra are my top picks and recommendation for Da-Lite screens.
I concur with mech, for Carada the only one you really want to be looking at is their bright white. It has the gain you need to get you up to the desired brightness level.
Old 08-19-07, 12:00 PM   #6 (Link)
New Member
Alias: Smitty
Loc: South Carolina
User: #10834
Since: Aug 2007
  srsmith is offline
Smile Re: New Projector - need advice on screen gain
Thanks for your advice, I really appreciate. Its all become quite a bit clearer.
Old 08-19-07, 03:35 PM   #7 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
  wbassett is offline
Here are some excerpts from ProjectorCentral's review on the VPL-VW50.
I highlighted some of the key statements-
ProjectorCentral wrote:
Since this projector has a long zoom lens, its lumen output will depend in part on where you install it. If it is installed as close to the screen as possible so that the zoom is in its widest angle setting, lumen output is maximized for all operating modes. If the projector is moved back so that the zoom lens is set to its longest throw distance, lumen output for all operating modes is reduced by 25%. Ceiling mounting will let you position the projector closer to the screen and allow you to use the brighter end of the zoom lens.
Overall, when set up to get the best image possible, the VW50 is capable of delivering a dazzling, high contrast picture with extremely deep black levels. Color saturation is outstanding, and color balance is close to ideal. As noted previously, pixelation is non-existent. These performance factors combine to give the picture a rich, natural quality that is easy to enjoy for hours on end.
With the projector's supremely high contrast, one does not need an exceptional amount of lumen output to generate a satisfying picture. That is a good thing, because at video optimized settings most people will opt for, lumen output can drop to lower than average levels. The maximum lumen output we were able to measure on our test unit was 562 ANSI lumens. That was with the projector set to "Dynamic" mode (not ideal color), the lamp on full power, the zoom lens set to its widest angle position, and lens shift set to neutral.
From that starting point, lumen output can be curtailed in any of several ways. As noted previously, using the telephoto end of the zoom range will cut lumen output by 25%. Switching to low lamp mode reduces light output by 35%. Switching from Dynamic to video-optimized Cinema mode reduces light output by 28%. Moving the lens shift from neutral position to maximum offshift up or down reduces light output by 5%. So as you experiment with combinations of these various options, the VW50 will produce anything from a reasonably bright 500+ lumens to well below 200 lumens.
The bottom line is that the VW50 has an adequate amount of lumen power to deliver a beautiful high contrast picture in a dark theater. With color balance optimized and the lens in its long throw configuration from a back wall, the user should expect to net about 300 ANSI lumens out of the box. We would not go too large with the screen size, ideally keeping it to no more than about 100" diagonal. If you are viewing nothing but bright, high contrast source material, it will light up a 120" screen quite easily. But with a lot of darker standard definition material in the mix, users with larger screen sizes will find themselves wishing the projector was a bit brighter.
Contrast and black levels are two of the VW50's strongest attributes. With either HD or standard def material, black level was deeper than on any of the other new 1080p projectors we are currently evaluating.
Based on the fact your projector has a fantastic contrast ratio and can also produce blacks very well, my recommendation is to skip a gray screen and stay with something N9 or lighter in shade, preferably a good quality white screen with a gain around 1.4.
Old 08-20-07, 09:29 PM   #8 (Link)
New Member
Alias: Smitty
Loc: South Carolina
User: #10834
Since: Aug 2007
  srsmith is offline
Based on the review and comments I 've been reading - it seems like I should position the PJ somewhat closer to the screen to maximize brightness, and try to avoid lens shift as much as is practical.
If I bring the PJ closer to the screen wouldn't that cause some potential hotspotting?
Again, thanks - I am now looking at the Stewart Studiotek 130. Seems like it might be a good (albeit more expensive) way to go.
Old 08-20-07, 10:26 PM   #9 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
  wbassett is offline
With the options and lumens your projector has I think you will be fine in that area (hot spotting) seeing that you don't have excessive lumens, but an incredible image quality.
Bringing the projector closer and if you reduce your zoom, will decrease the image size and increase the brightness, but let's work on options for a 110" screen, I don't think that is out of the question. You could drop to a 106" screen, but you'd only come up around 1 fL, so that drop doesn't seem advantageous.
With your projector and the size screen you desire it can be done and give you an exceptional image, and I think that's what you're looking for.
Hit Smokey up for the calibration part of things, and he will also be able to give you some ideas and tips on screens as well. The StudioTek 130 is a very nice screen and would serve you well, but I would kind of like to see you hit around 1.4 to 1.5 for your gain to give you a more vibrant image and the ST130 is a 1.3 gain.
If it is at all possible, shoot an image onto a matte white unity gain screen or wall and do a calibration to get a baseline. That way you really will know how much of an improvement you get with samples or the screen you ultimately go with.
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
Classroom Screen Advice schumarg Projector Screens | DIY Screens 12 11-18-07 09:58 PM
Screen advice? jedinite6 Projector Screens | DIY Screens 10 08-13-07 08:13 PM
Motorized projector screen POP UP, not DROP DOWN EchoMike Projector Screens | DIY Screens 4 06-12-07 08:57 AM
Any way to limit gain to +/-10.0 dB? maxcooper REW Forum 17 12-16-06 05:08 PM
Projector & Screen Recommendations Tommy Home Theater Projectors 37 07-20-06 02:46 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
