| Projector Screens | DIY Screens Best shade of gray?Discuss Best shade of gray? in the Home Theater | Audio and Video forum; Best shade of gray? Oh, I know I'm hitting it with a lot more light than Bill is. :-)
I think regardless that I'll ... |
| | #26 (Link) | ||||
| Re: Best shade of gray? Oh, I know I'm hitting it with a lot more light than Bill is. :-) I think regardless that I'll try the third coat- unless you can think of a reason not to? It's been suggested that I pick up an ND filter in order to filter out some of the 25 foot lamberts I'm currently getting and I plan on following that advice very soon. | ||||
| | #28 (Link) | |||||||
| Re: Best shade of gray? Quote:
The only thing I can think of is possibly if you got too much texture from the roller. I use either a good quality 1/4" nap roller or foam rollers (not the small foam trim rollers, full size foam rollers). Again there is nothing I can see in the paint or finish that would cause sparklies. Think of it this way though, if you are over powering this and getting sparkies, it's better to have spent $40 something than literally over ten times that amount on something like a Da-Lite Pearlescent screen. If you're having sparklies with this, a screen with added components like pearlescence (mica) will light up light a traffic sign wrapped in Christmas lights. You really should get yourself an ND filter if the projector is that bright. Like I mentioned, as the bulb gets older you can remove the filter and keep the same screen brightness throughout the life of the bulb. If you go for a super dark screen now, you will be able to get the image down in brightness, but when the bulb starts to age the screen image will get dimmer and duller. Most likely you won't even make it through the bulb life before spending money on a new bulb when the old one actually had some life left in it if you had a filter you could just remove. Quote:
![]() Projector Central's review states: Quote:
![]() Right now you're blasting that screen with upwards of 28fL of brightness at the screen and that's insanely bright. You have to knock it down or else with lights out you're going to get eye fatigue before even one movie is finished and yeah... you'll hot spot or sparkle where others won't. Nothing against pearls, but be thankful you didn't add mica to the mix or you might have a real mess right now that could require starting over from scratch. In your case you definitely don't need it. Sorry if I swayed you away from an N7 shade, you could have handled it and even an N6 for that matter, but I would rather see you use a filter and extend your bulb life/image uniformity across the life of the bulb. By mid bulb life you'll be down to around 18fL which is still very bright, and at the end you'll probably be down around where I am. Consider yourself lucky! ![]() (BTW, screen size is a factor too... if you had the same size screen I have you'd we'd both have around the same fL at the screen). At least I know never to drop my screen size now. ![]() Right now I would say if you only have Gray Screen up, try sanding it smooth and shining a light on the screen. Stand to the extreme edge of it and look across the screen for any peaks and valleys. If it is smooth, roll on a final coat with Todd's instructions and make sure not to over work the paint or dry roll. You know you are dry rolling when you hear the roller making 'sounds' and you are pressing harder. As Todd instructs, apply only enough pressure to make the roller move. That's the exact same advice I give and it is very sound advice no matter who says it. ![]() I think we can get you fixed up, and I still say shoot Smokey a note too. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||||
| | #29 (Link) | ||||
| Re: Best shade of gray? Hey Bassett, thanks for the very detailed response! I used a 3/16's nap, but I'm pretty sure I "dry rolled" over much of the screen while I was rolling the second coat on in an attempt to even out the paint and get rid of the roller lines. Again, I didn't specifically follow Todd's instructions, and that's only my fault. I also wouldn't even consider top coating this in an attempt to obtain extra gain... that's pretty much the last thing I need right now! I'm pretty sure we can chalk the sparkles up to my poor rolling technique. That said, when I get the third coat on (most likely today), if it still sparkles I'll have to strongly consider going white again. I'll order the ND filter this week, especially if the sparkles remain after the third coat. You mentioned eye fatigue- I've actually spent quite some time with the projector watching movies and playing 360 and I haven't had any issues with eye fatigue then again I still have very young eyes (I'm 23). Oh, and don't get me wrong about the picture quality, you have no idea how incredibly amazed I am at how good of an image this projector throws, and the gray screen certainly doesn't detract from that. I watched Knocked Up last night in HD-DVD, and it was just phenomenal. It absolutely rivals the local cinemaplex that's gone dlp in all of their theaters. There really is no "dialing-in" the Samsung. It's "turn it on, and forget it." I like!! :-) | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| gray balance before taking photos and GTI N8 | kenyee | Projector Screens | DIY Screens | 74 | 06-03-08 06:21 PM |
| Can I improve on my Misty Evening Gray screen? | Sonnie | Projector Screens | DIY Screens | 50 | 02-08-08 12:40 PM |
| Is the "Gray Screen" my best option? | E-A-G-L-E-S | Projector Screens | DIY Screens | 74 | 09-26-07 12:56 PM |
