| Projector Screens | DIY Screens A Study In ClearsDiscuss A Study In Clears in the Home Theater | Audio and Video forum; A Study In Clears So, I had a bunch of clear mediums and polyurethanes on hand. Found some red, green, blue and white paper ... |
Views: 673 - Replies: 24
| A Study In Clears So, I had a bunch of clear mediums and polyurethanes on hand. Found some red, green, blue and white paper in my kids craft section. Decided to see if different clear mediums show any major differences. I dabbed small amounts, with my finger, on each piece of paper. I wrote what the was medium under each spot. I even tried a few mixes. All pictures are under flash. Was really interested in looking at gloss and colour. And yes, I washed my finger between each change in medium .A couple of observations: 1. Notice how bad the Behr Faux Glaze really made red look. 2. Notice how orange the polys look on the red paper 3. Behr Flat Deep Base and Faux Glaze are the flattest of all of the mediums Let's discuss! Anymore testing I should be doing? | ||||
| | #2 | ||||
| Re: An Empirical Study In Clears Ben, Well initially looking at this, the satins really add a lot of sheen. Which one pushed red the least towards orange? It seems like the first 1:1:1 mix - Deep base, satin poly and matte poly. Which satin and matte's did you use for those? mech | ||||
| | #3 | ||||
| Re: An Empirical Study In Clears You are correct mech. The 1:1:1 Deep Base, satin poly, matte poly shifted red the least towards orange. And it is nice and flat. All of the products are listed in the pictures. The deep base and matte poly are Behr products and the satin poly is by Varathane. i find the Varathane to be less stinky than Polycrylic by Minwax. | ||||
| | #4 | ||||
| Re: An Empirical Study In Clears Ben this is the sort of thing I really wanted to see and test too. We know that not all 'clear' coatings are really clear. Empirical testing is the fastest way to quickly evaluate things that is for certain. I think it would be interesting and fun to test some of these and determine if there is any color shift and if so if it is consistent no matter what the color base it is applied to. Then we'll know exactly what it's doing to the screen and in which direction. I was also pointed in the direction of some hardwood floor clear coatings. Again, I want to say from my perspective yes we know certain things do work, but I also think we can do better, and benven this is a step in that direction! "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #5 | ||||
| Re: An Empirical Study In Clears I would think hardwood floor coatings would not come in matte/flat? At least the ones I have used have always had a nice sheen to them. I guess that's what they are made for! Hey, if anyone can spectro these, I can mail the sheets away. If a larger area is required I can certainly paint up some pieces of paper with the various products. Just let me know. | ||||
| | #6 | |||||
| Re: An Empirical Study In Clears Quote:
I was planning on pm'ing you when I get mine back from X-Rite! Should be next week some time I'd guess. I'm heading out to a hockey game tonight so I'll pm you my address tomorrow. Sound good?mech | |||||
| | #8 | |||||
![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
| | #9 | ||||
| Poly and 'Vertical Viewing Cone' Has anyone else noticed this? My screen is a bit higher than most peoples because I have to shoot over a 55" Sony SXRD HDTV. I built a custom stand to lower the set some so the bottom edge of my screen is right around 48" off the floor. I have a few test panels up right now, one with poly, and I noticed from a seated position the poly coated panel is lighter, but when I stand up it looks darker. It's definitely happening and I will try to capture it on camera tomorrow. I was doing screenies tonight and it would have been too much work tonight to keep adjusting the tripod. As is I started around 10:30 and just finished a few minutes ago. (Screen shots take longer than people think) Anyway, I was wondering if anyone else saw this. For most who's screen is lower than mine it probably won't matter, but it is definitely happening. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #10 | |||||
Thanks! mech | |||||
| | #11 | |||||
| Re: Poly and 'Vertical Viewing Cone' Quote:
![]() mech | |||||
| | #12 | ||||
| Re: An Empirical Study In Clears Ben, this is great stuff! Such a simple idea, in hindsight (wish I'd thought of it). ![]() A simple test like this (reinforced by mech's measurements) can go a long way with recommendations for the best topcoat to use without introducing a color shift. So, thanks for doing this guys! I'll be watching for the outcome. | ||||
| | #13 | ||||
| Re: Poly and 'Vertical Viewing Cone' Yeah my screen is up higher than most people would have their screen. I'm sure it's not a problem under normal setups, but it is definitely there. Interesting though. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #15 | ||||
| Re: An Empirical Study In Clears Took a while but I've got the readings for all of the clears. I've attached the excel spread sheet file. I've also forwarded them on to Bill and Jim so that they can plot them on a CIE chart. I'm also going to work on putting them into a post for those that are excel deficient. mech | ||||
| | #16 | ||||
| Re: An Empirical Study In Clears Before I start I think it should be mentioned that these readings were done using colored construction paper. It would probably be interesting to see these readings taken again using something less permeable, such as a laminate I guess. There are 11 readings per sheet and three measurements per reading. The 11th reading is of the paper itself. Here's where they were basically taken on each sheet: ![]() The first numbers are for the whitish sheet, the second is for the red sheet, third is for the green sheet and the last is for the blue sheet. 1. Behr Clear Matte Poly 219 206 184 82.6 0.65 12.7 0.339 0.355 62.7 215 95 115 56.0 49.0 12.7 0.452 0.306 23.9 87 160 106 60.0 -34.9 20.9 0.292 0.430 28.1 100 121 175 51.2 7.04 -31.4 0.240 0.235 19.4 2. Varathane Satin 214 201 179 81.5 1.10 12.6 0.340 0.355 59.4 204 71 95 49.8 54.3 15.4 0.486 0.302 18.3 61 145 94 54.0 -37.3 19.3 0.280 0.438 22.0 84 107 165 45.7 8.30 -34.3 0.229 0.219 15.0 3. Behr Faux Glaze 219 209 186 84.0 -0.06 12.6 0.337 0.355 64.1 198 84 112 51.8 48.0 7.07 0.442 0.294 19.5 81 158 107 59.3 -35.7 19.5 0.287 0.428 27.4 103 126 176 52.9 4.91 -29.0 0.244 0.244 21.0 4. Liquitex Matte Varnish 217 204 183 82.6 0.81 12.3 0.338 0.354 61.4 208 82 103 52.3 51.8 14.0 0.470 0.304 20.4 60 145 98 54.1 -36.9 17.5 0.277 0.430 22.1 86 110 165 46.7 7.19 -32.7 0.232 0.226 15.8 5. Liquitex Matte Medium 214 202 174 81.6 -0.16 15.6 0.334 0.362 59.6 202 79 101 50.8 50.6 13.3 0.468 0.303 19.1 71 150 95 56.0 -37.0 21.6 0.287 0.442 23.9 89 113 162 47.8 4.65 -29.1 0.238 0.238 16.6 6. Tri-Art Matte Polymer Medium 218 206 178 83.1 -0.68 15.7 0.343 0.362 62.4 210 86 105 53.4 50.6 14.4 0.466 0.307 21.4 78 156 104 58.5 -36.2 20.2 0.287 0.432 26.5 92 119 168 49.8 3.69 -29.1 0.238 0.241 18.3 7. Deep Base 217 207 186 83.4 0.05 11.5 0.335 0.353 62.9 202 84 111 51.9 49.5 8.90 0.450 0.296 20.1 90 163 110 61.1 -34.6 20.3 0.291 0.426 29.4 101 126 176 52.9 4.14 -29.1 0.242 0.244 21.0 8. 1:1:1 DB/Satin/Matte 218 206 184 83.2 0.54 12.3 0.338 0.354 62.5 204 80 105 51.4 51.2 11.4 0.462 0.299 19.6 79 157 104 58.6 -36.2 20.5 0.287 0.433 26.6 96 119 172 50.2 6.16 -31.0 0.238 0.235 18.6 9. 1:1:1 Deep/Satin/Matte 218 206 182 83.2 -0.05 13.4 0.339 0.357 62.5 203 80 105 51.1 51.0 11.5 0.463 0.299 19.4 70 154 101 57.4 -37.7 20.1 0.283 0.435 25.3 92 118 170 49.6 4.77 -30.6 0.236 0.236 18.1 10. 1:1:1 Satin/Matte/Polymer 217 205 181 82.8 0.16 13.4 0.339 0.357 61.8 210 84 106 53.0 51.5 13.3 0.465 0.303 21.0 96 161 119 60.9 -30.3 15.3 0.289 0.405 29.1 93 116 169 49.2 5.84 -30.9 0.237 0.234 17.8 11. Paper only 219 208 189 83.9 0.68 10.7 0.335 0.350 63.9 207 93 119 54.5 47.6 7.75 0.437 0.297 22.4 87 161 110 60.5 -34.7 19.6 0.289 0.425 28.6 105 130 179 54.3 3.87 -28.7 0.244 0.247 22.2 I'll have more as the day wears on as well as the CIE charts if either Jim or Bill get to them. I'll re-verify these numbers when I actually get my spectrophotometer back. I don't anticipate any changes though. mech | ||||
| | #17 | ||||
| Re: An Empirical Study In Clears Here are shots of the sheets themselves. You've seen the whitish one above. ![]() ![]() ![]() I'll be adding stuff as the day wears on... mech | ||||
| | #18 | ||||
| Re: An Empirical Study In Clears almost seems like a 50/50 mix of behr matte poly and behr faux glaze might be the best compromise of that bunch? edit: check that, 50/50 of deep base and faux glaze is what i meant to say. Last edited by GbrNole; 10-25-07 at 03:48 PM.. | ||||
| | #20 | ||||
| Re: An Empirical Study In Clears I've done a bit of data reduction. I'm a believer that the deviation of x and y in the CIE space is probably the simplest set of numbers to look at if we want to get an idea of the effect of the clearcoats on color. That being said, plotting the deviation (as a scalar) doesn't tell us which direction the color is moved from it's original. But, it's enough to get a quick look at how much the clearcoats effect the color. So, here we go: ![]() Thanks to benven for starting this effort and mech for the measurement data. | ||||
| | #21 | ||||
| Re: An Empirical Study In Clears I'd like to redo it with something other than construction paper sometime too. And I mean no offense to Ben but some of this may be from the coatings soaking in. I may have to start looking for some of these and do them on a laminate sample sometime in the future. mech | ||||
| | #22 | ||||
| Re: A Study In Clears I've also changed the title as I think we've moved beyond 'empirical'. It does appear that the glaze and the base have the least effect upon the color so far. mech | ||||
| | #23 | ||||
| Re: A Study In Clears Good one GbrNole. I didn't look at the data, but rather what my eye saw. And it looked, by eye, that the Faux Glaze did horrible things to red. Boy, just goes to show you how deceiving these things can be. And that without measurements, you are simply guessing, like I was. Nice graph Jim. That tells us the story. Fauz Glaze and Deep Base, like GbrNole and mech stated, have the least effect on the base colour. mech, no offense taken. I just had some paper around and wanted to see the effect. Just having some fun with this. I believe the art store where I purchased the white foam board has red, blue and green foamboard. If I have some time this weekend, I'll go see what they have and repeat. And yes, we have now moved away from empirical. It's ironic, my very first screen, which is still on the basement wall but now full of dings from hockey sticks and balls and pucks, had a topcoating of 1:1 Fauz Glaze and Deep Base. That was not easy to roll! | ||||
| | #24 | |||||
I don't have all the clears that are being tested here, and am trying some tests of my own that are also looking interesting. When I get everything sorted I'll post those results. What I am doing is applying the Behr poly to a piece of glass in different amounts of thickness. You really can see if it's clear or not that way. As we would conclude, thin coats are the best, thicker coats or poor application techniques can go cloudy quick. Ideally I'd like to see a clear coating that remains clear but still adds that diffusive layer to the screen. These are the types of tests that will shake out something. Great job so far guys! ![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
| | #25 | |||||
