| Projector Screens | DIY Screens 'Pigment' Free Gray- Initial Development and TestingDiscuss 'Pigment' Free Gray- Initial Development and Testing in the Home Theater | Audio and Video forum; 'Pigment' Free Gray- Initial Development and Testing Index PFG Introduction and Initial Performance Shots (Posts 1-4)
Theory and Further Testing and Discussion
This is a new gray ... |
Views: 4117 - Replies: 135
This is a new gray made from Kilz2 and Aluminum. I say 'pigment free' because other than the pigments in Kilz2 no conventional paint tint pigments were used. For now We'll shorten it to PFG until a better name is thought up. Preliminary testing is looking very good so I decided to take this out of the teaser thread and start a thread on it. This is still in a beta stage, but moving further along. Someone questioned me about doing some teases, but there's nothing wrong with a little tease now and then as long as it's not just that, a tease and nothing materializes out of it. That is not my intent. Okay, so we know it has Kilz2. I used that because it's inexpensive and I already have a couple gallons of it. Testing is promising enough that I am going to make a test panel using Luminous White. So the Aluminum part. It's a paint comprised of
![]() I did some preliminary screen tests and have a SW Gray Screen test panel for a side by side comparison since I know GS is a solid performer. The 4:1 panel seems to be a little better but over all for shades getting this dark I was pretty impressed with both the 3:1 and 4:1. Here is a lights out shot, 3:1 on the left, 4:1 on the right, with a light gray (roughly N8.5) as the background screen. ![]() I was pretty impressed with not only the blacks but the overall image. The shot above makes the background screen look washes out and almost like it was a lights on shot. Previously that screen was looking exceptionally good on its own, but these panels really put it to shame. Just looking at the image above it's like a veil was lifted. No hot spotting either. I am going to test out other movies too since Van Helsing is a dark film and the director also chose to shoot everything with a slight blue cast (Like Cameron did with T2) ![]() Lights on, there was a dramatic difference. First is lights off, then lights on. ![]() ![]() ![]() ![]() Finally for now Van Helsing the werewolf vs Drac, and the fate of Anna. ![]() ![]() ![]() I will be testing against a SW Gray Screen panel, and also running a test with a poly top coating. If I am satisfied with those then it's time to get some spectrophotometer readings and see where this stands. Overall this was extremely easy to make. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #2 | ||||
| Round Two A couple changes were made this time. I coated the 3:1 panel with Behr Matte Poly, and I added a Sherwin Williams Gray Screen panel. So in the up coming shots, the panels from left to right are Sherwin Williams Gray Screen, PFG 3:1 with Poly, and PFG 4:1 with no poly. There is a small strip to the far right of the screen that is my test screen and it's roughly an N8.5 shade. The Run Down "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #5 | ||||
| Re: 'Pigment' Free Gray- a New Gray It looks extremely promising to me! Send me some for testing!! ![]() It appears that the poly lightened the image a bit on the 3:1 when compared to the 4:1. What do you think Bill? So far I like the way it looks! But I've always been about contrast and deeper blacks! mech | ||||
| | #6 | ||||
| Re: 'Pigment' Free Gray- a New Gray The most amazing images to me are the ones with both dark and light areas, where you can really see the effects on both. Take this one for example: ![]() The blacks on the PFG screen absolutely blow away the SW screen (in fact, it looks washed out compared to the PFG screen). Yet, in the brighter part of the image (the planet), the seam between panels is almost imperceptible. This is the only screen I've seen that (to my admittedly amateur eye) doesn't have just about an equal trade-off between darks and lights. The benefit to darks far outweighs any hit to brights... I have to say, I'm super impressed at this point. The other point I'll make is that this is next to SW Grey Screen, which is as good as any DIY solution out there (at least any verifiable solution...some on AVS claim that the heavy metallic/silver screens are wonderful, but there's no hard data to support the claim). And, to me, PFG vs the SW GS looks like a step-change in performance. One other comment: many times, I take screenshots (even side-by-side) with a grain of salt. That's because when a projector is calibrated for one screen sample, it will by definition not be calibrated for the other samples in the same image. So, we see a darker grey screen next to a lighter grey screen...both blacks and whites are darker on the darker grey, and the panel that the pj happens to be calibrated for ends up looking "better". But, in this case, it clearly seems to be an expansion of the "range" of greys that can be displayed...blacks get MUCH blacker, while bright colors don't darken too much at all. This screen seems to really capture what the pj is sending, at all points of the greyscale. Bill, does it look a lot better than any other panels you have in person? I'm sure that soon we'll see it on someone's website for $150/gallon. | ||||
| | #7 | ||||
| Re: 'Pigment' Free Gray- a New Gray definitely very impressed though i still kinda feel like the sweetspot might be a lighter shade still - 5:1 or 6:1 the only thing that did catch my eye was the the 3:1 with poly panel looked kinda weird in the text credits screen shot - text almost seemed to be blooming but not like a hot spot? | ||||
| | #8 | ||||
| Re: 'Pigment' Free Gray- a New Gray Looks good. Reminds me of my first posting at the other place. I had an aluminum screen with a clearcoat to knock down the hotspotting. Removing the topcoat and adding some white to the mix really made it shine. Just an FYI, at least in my experience, that adding a topcoat will reduce those nice dark blacks and muck up off axis viewing. Just curious, how do mineral spirits and water mix? Also, how is off axis viewing? Can you please post some pics? Thanks! | ||||
| | #9 | |||||
| Re: 'Pigment' Free Gray- a New Gray Quote:
Is this the pic you're talking about? ![]() It definitely looks like the poly is causing some light scatter of the white foreground on the black background...a little too much of the diffusion effect, I guess. I would assume that different polys will cause that to different extents, so it may take some experimentation to find the best poly (if that's what it is...keep in mind I'm still a novice) for this application. If I think about using this for my personal situation, I definitely would want to be able to protect it somehow, if the main mix is Kilz. Otherwise, my kids (and maybe even I ) will smudge the screen by doing something stupid. Another option is a more durable basecoat...I think Bill said he's going to try some things other than the Kilz. If it works with a matte SW paint, a topcoat may not be needed for protection, since it's fairly durable/washable.I'm keeping my eyes peeled for future developments. ![]() <-- My eyes![]() <-- are peeled. Oh, I kill me... ![]() Wait, I've got another... With the opacity and reflective properties of the aluminum, very little light is lost. I think that's what allows the brights to still look good while the blacks improve disproportionately. So, more total light is returned to the audience. In other words, the screen efficiency is improved. That insight is especially for mech and Bill...they love it when I talk about efficiency. ![]() <DISCLAIMER: For anyone reading this who isn't familiar with the efficiency discussion of a few weeks ago, please do not take my last paragraph seriously...I'm just joking around with our fine mods.> | |||||
| | #10 | |||||||||
The poly definitely lightened the 3:1 panel and I am still debating which of the three I like the best. I asked my wife and she said she liked panel #3 the best (PFG 4:1) The poly lightened the 3:1, and whites do look good, but there is something about it I'm not sure about. Some scenes looked fantastic, others didn't look as good as the other two panels. Still some work needed but this is definitely worth pursuing. As far as the blacks, wow, yeah I like them too and in certain brighter scenes I couldn't tell the difference between GS and the other two panels. Some shots I definitely could see all three panels very distinctly. Blacks were the worse on GS (and GS is a great screen with no reference like this) but the 3:1 poly coat took a major hit with the blacks after adding the poly. They were still darker then GS, but had a washed out duller look compared to the 4:1 ratio. Quote:
Mech I'll be sending you the actual mix when It's finalized. I'd like to see this up against some of the other higher end DIY screens and you have those prepared already. These blacks are more than just slightly better, they are a magnitude better while still keeping everything else bright and white. Maybe I'll try a color match for the shade of gray and test two panels out that way. I suspect that the paint alone isn't going to look anywhere close to the same. Again, something that has to be tested out though to be sure. Quote:
The poly and text did look a little strange to me too, but wasn't that bad in person. Still it did have a more blurred look than the other panels. As far as hot spotting, when I first fired my projector up, yes the poly panel looked like it had a 'circular' bright area in the lower half. It could be hot spotting or possible a problem applying the poly. I'll check it out further. The 4:1 panel doesn't appear to be exhibiting any perceivable hot spotting issues, just the poly coated panel. Quote:
As far as your poly coating statement, I concur. It lightened the 3:1 panel but I think a 5:1 would be just as bright and lighter but possibly help with the backs better than the hit taken with the poly. This isn't regular paint as we know so in this case my opinion is definitely leaning towards the thought that poly caused more negative affects than positive ones. I'll try a 5:1 side by side with it and we can see how they look. ![]() Quote:
Next I am going to run the Aluminum through a filter. I have noticed there are some larger flakes in the Aluminum paint that do show up as larger pronounced particles on the rolled panel. Once these are removed by running it through a filter, this should be able to be sprayed at that point as well as rolled. I'm actually kind of excited about this. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||||||
| | #11 | ||||
| Re: 'Pigment' Free Gray- a New Gray | ||||
| | #12 | ||||
| Re: 'Pigment' Free Gray- a New Gray Did I miss something or did this PFG just make a SW Gray Screen look bad in comparison?? Those pics make the PFG 'pop' in comparison the the SW gray screen if I'm getting it right. Just awesome! | ||||
| | #13 | |||||
Elliott Marston (Alan Rickman) Ah ha. Legendary Sharps. Matthew Quigley (Tom Selleck) You know your weapons. It's a lever-action, breech loader. Usual barrel length's thirty inches. This one has an extra four. It's converted to use a special forty-five caliber, hundred and ten grain metal cartridge, with a five-hundred forty grain paper patch bullet. It's fitted with double set triggers, and a Vernier sight. It's marked up to twelve-hundred yards. This one shoots a mite further. Elliott Marston An experimental weapon with experimental ammunition. Matthew Quigley You could call it that. Elliott Marston [Smiling] Let's experiment. Right now this is in a testing stage but it is showing enough promise that I felt it would be interesting to show the progress. When it is finally tweaked out and fully tested it will get a final solution status and then I can feel comfortable recommending it. Yes though, it is blowing away Gray Screen that much. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
| | #14 | ||||
| Re: 'Pigment' Free Gray- a New Gray If I knew how to make all those graphics and such their would be that evil scientist rubbing his hands together going insane with laughter. | ||||
| | #15 | ||||
| Re: 'Pigment' Free Gray- a New Gray I think we're at least a couple weeks before finishing up comparisons, spectro'ing it and what not. It's piqued my curiosity so much that I'm gonna attempt to get some tomorrow and mix some up. I kind of wish I didn't have to do a screen shoot off this week first! mech | ||||
| | #16 | ||||
| Re: 'Pigment' Free Gray- a New Gray Just incase you cannot get the reflective spots out, I can't believe I'm even saying this, what commercial screen would give this same effect? | ||||
| | #17 | ||||||
There are no sparklies that I could see in the 3:1 or 4:1 panels. I did see one in the 3:1 but only after I applied the poly, and it's off axis so not a big factor with this test panel. Before that I couldn't see any. When I rolled I did see a few big flakes and I removed them and then rolled the area again. That's why the screen shots are showing them. Again, this is one of the refinement issues I'm working out and filtering it should resolve this."Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||||
| | #18 | ||||
| Re: 'Pigment' Free Gray- a New Gray Graphic--"little baby from family guy with an evil happy face" ...you were right, I was concerned about the flakes. Edit: I don't think I've been this excited since I got my first HD t.v. ... cannot wait to get the final recipe It will be up on my wall that evening ![]() | ||||
| | #19 | ||||
| Re: 'Pigment' Free Gray- a New Gray Bill, what kind of filter will you use for the flakes? I was doing some painting with a flat black paint, and accidentally dropped some white paint flecks into it. I decided that I could filter them out, and tried running it through an old T-shirt. That absolutely didn't work. The paint was too viscous and just sat on top of the shirt...nothing went through (well a bit did, but it would've taken a month for it all to drip through). Anyway, I'm curious what type of filter you'd recommend using on paint (or in your case aluminum)... | ||||
| | #20 | ||||
| Re: 'Pigment' Free Gray- a New Gray Just a standard filter used for sprayers to remove large particles so they don't clog the sprayer. They are like a $1 for three or something like that. The Aluminum paint is the consistancy of water so it filters pretty easy. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #21 | |||||
| | #22 | ||||
| Re: 'Pigment' Free Gray- a New Gray Yeah exactly. The only thing that would need filtered would be the Aluminum paint and not the entire PFG. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #23 | ||||
| Good Reasons for going slow... Well this is a perfect example of not rushing that's for sure! The main ingredient was discontinued. Mech went looking for some and couldn't find the one gallon buckets and when the website was checked, that part number was nowhere to be found. I've been talking to the company for two days now, at first they weren't sure if it was discontinued or not, but today they called back and said it was. So that's bad news. Somewhat better news is they said there is an new product that looks to be essentially the same thing. I spoke to their engineers for about an hour, so I'll go pick some up, hopefully this weekend. That is hopeful, but means I have to test it from stage one again. It should go faster now though since I won't have to mess around with making all the samples and go straight to 4:1 through 6:1 test panels. It is listed as both roll able and spray able, but I'm not sure if the Wagner Control Spray is really the recommended unit. They don't recommend thinning it any more than it already is. Wagner does make sprayers design to spray latex paint that isn't thinned, but I really don't want to go the route of recommending a totally different sprayer. That isn't the goal to make this more complicated and expensive. I will test out the Control Spray though for those that already have one. So in that sense, I am glad I didn't rush this out and name everything or it would have been a big disappointment since the original medium is no longer made. It's still out there in stores, but when the inventory is gone, it's gone. Let's hope the replacement is the same and works as well. Also, this still needs color balance testing and if it is off I already figured out how to resolve that. It's just a matter of making sure the new stuff works. I'll keep everyone informed, this isn't a closed topic yet. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #24 | ||||
| Re: 'Pigment' Free Gray- a New Gray Any updates? | ||||
