Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
If I didn't already have the TV Winter Mist up...
Discuss If I didn't already have the TV Winter Mist up... in the Home Theater | Audio and Video forum; If I didn't already have the TV Winter Mist up... I have a new PJ coming. It is a Marantz vp-4001. As you guys know I have a TV Winter ...
Elite Screens
Views: 877 - Replies: 14
Old 10-11-07, 07:39 PM   #1
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
  E-A-G-L-E-S is offline
I have a new PJ coming. It is a Marantz vp-4001. As you guys know I have a TV Winter Mist for the Mitsu HC1500 light cannon I was using.
So I'm thinking I may need a white screen and possibly even with some gain for this lower lumen Marantz?
I don't want to lose any of its' higher contrast though?
Old 10-11-07, 08:27 PM   #2
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
  cynical2 is offline
Re: If I didn't already have the TV Winter Mist up...
E-A-G-L-E-S wrote: View Post
I'd check out the Marantz with the Winter Mist...it'll likely look great unless you're underpowered for the brightness of your pj and the size of your screen.
Other than that, I'd suggest waiting to see how the PFG solution pans out...it looks really good, and it probably won't be too long before we know more about it. It looks better to me than any other DIY solutions I've seen, but Bill and mech have more work to do before releasing it upon the masses.
Old 10-11-07, 08:50 PM   #3
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
cynical2 wrote: View Post
Other than that, I'd suggest waiting to see how the PFG solution pans out...it looks really good.
-I'm thinking since I am pushing it to a 110"(or at least 106") that it may be too dim without using it in a mode or iris that burns the lamp too quickly.
I will try the TV WM first but just wanted to have a sceen choice alternative ready.
-I agree
Old 10-11-07, 10:27 PM   #4
Alias: Gbr
Loc: Fort Myers
User: #11740
Since: Sep 2007
  GbrNole is offline
did you not read what i posted in the vp4001 thread???
you'll be fine with the winter mist as long as you run the PJ in it's medium iris mode which still equates to 4000:1 contrast ratio and spanks the out of the hc1500 for picture quality. run the PJ with both iris' open and it's just as bright as the HC1500 except it will be running with much more accurate colors and te contrast levels will still be a little better than you are getting right now.
there's no need to run this PJ in full lamp mode.
ps. that was for your 110" screen.
Old 10-11-07, 10:38 PM   #5
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
You should be fine, at least give it a test run when it comes in and decide then.
Keep in mind that Winter Mist is pretty light gray and there are actually commercial screen that say they are 'white' but actually darker than Winter Mist.
What are you going to be doing with the HC1500?
Old 10-11-07, 10:51 PM   #6
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
I sold it already. Posted here and avs and it sold in about 15 minutes.
Marantz comes tuesday.
Old 10-11-07, 11:42 PM   #7
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is online now
What did the Marantz set you back? That's a re-badged Sharp if I recall correctly.
mech
Gain Readings
Spectro Readings - not up to date but will be soon
Old 10-12-07, 08:25 AM   #8
Alias: Gbr
Loc: Fort Myers
User: #11740
Since: Sep 2007
  GbrNole is offline
mech, i think most people were in on the second-act deal for right about 1,250 bones and yeah, the marantz is a rebadged sharp xv-z3000 (i have the z3000) though the marantz has a much better warranty period and is alleged to have improved optics.
if i was buying another one today i'd definitely choose the marantz version unless i was getting the freakishly good deal that i got on my z3000
Old 10-12-07, 09:44 AM   #9
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
GbrNole summed it up perfectly
Old 10-12-07, 09:57 AM   #10
Alias: Gbr
Loc: Fort Myers
User: #11740
Since: Sep 2007
  GbrNole is offline
eagles, if you check out some of my screen shots i did in the neutral gray screen thread you have to keep in mind that:
1) i'm using a really source to make those pics.
2) my bulb has close to 800 hours on it.
3) all 3 shades of gray that i used were darker than your winter wind.
4) all pics were taken with both iris' stopped down and in movie 2 so it's as dim as it gets.
my screen is 90" so it's a fair bit smaller than your but it gives you an idea at least.
Old 10-18-07, 04:02 PM   #11
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
gbrnole....so what do you think about a white screen for this Marantz? Or from what I read above do you think I should stick with the Winter Mist? Before the whites weren't quite right because of clear segment on color wheel of HC1500, now they are not quite right with this PJ, so that's why I was thinking white....
...or anyone else that has a reccomendation for what type of DIY white screen.
Old 10-19-07, 07:34 AM   #12
Alias: Gbr
Loc: Fort Myers
User: #11740
Since: Sep 2007
  GbrNole is offline
your whites aren't quite right in what regard? too gray, too green, too blue, too red?
keep in mind i'm using a z3000 and the only real difference between your PJ and my PJ is that your PJ has stronger and more true greens than mine does so it's a hair more suited to material like designer white laminate and commercial screens than mine is (i need the more flat [strong] green value that neutral color provides)
i'm pretty sure that you mentioned you watch most all of your tv/movies in a darkened room - if this is the case your vp4001 will work just fine with white paint. if you add ambient light then you would really want to keep the winter mist. most of all though you need to make absolutely sure that your brightness and contrast levels are adjusted properly.
in the other forum i've seen an awful lot of people running extremely low brightness numbers (-15) while their contrast is up a bit (~+4) and this is massively different to the settings i have to use to get the proper balance.
back to white screen though- if you want to go white then i think your money would be best spent on designer white laminate otherwise i would just get a quart of behr UPW 1850 if you don't want to mess with poly or a qt or behr upw 1050 and poly coat it.
the old faithful kilz2 works wonderfully but you can't scrub it and check with bill to see if he has checked out sherwin williams premium white?
Old 10-19-07, 08:38 AM   #13
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
Sherwin Williams Luminous White will work too, and Rosco's Off Broadway White White is outstanding and the company even acknowledges it is regularly used as a screen paint.
UPW still works extremely well and should be on your list of options for a painted white screen.
Designer White is still an extremely good screen option, it costs a little more but has a lot of benefits to using it.
Old 10-19-07, 12:52 PM   #14
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
They are a tad too gray, which I attributed to the Winter Mist.
I don't want to be too washed out on weekend afternoons, but when I went from Kilz2 to the W.M., the contrast and color improvement was much more obvious than the help with ambnient light...it didn't seem to do all that much?
Hmmm......
Old 10-19-07, 01:02 PM   #15
Alias: Gbr
Loc: Fort Myers
User: #11740
Since: Sep 2007
  GbrNole is offline
technically winter mist is a bit too light of a shade to be a good neutralizer for ambient light - better than white but not a whole lot.
this is why i went for a midpoint between winter mist and winter mountain because i found winter mountain shade to be too dark and winter mist shade to be absolutely brilliant in a dark room but not so much if some ambient light shines in.
i don't find whites to be in the least bit compromised though?
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
