Crushed or spandex velvet? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss Crushed or spandex velvet? in the Home Theater | Audio and Video forum; Crushed or spandex velvet? I am trying to find a cheaper alternative to velvet for my walls. Would either of these do? 1. Spandex ...
Old 10-18-07, 09:58 AM   #1 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
E-A-G-L-E-S is online now
1. Spandex black velvet
2. crushed blak velvet
I know velveteen is good, but I can actually get these particular velvets for less.
Old 10-18-07, 10:35 AM   #2 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
Re: Crushed or spandex velvet?
Velvet is the best for absorbing light 'spill' from the projector, but would be prohibitively expensive to do a whole room in. I don't think you need to worry about absorbing light on the walls like you do with the projector border. You certainly don't want anything that is reflective, but the amount of light that hits your walls is nothing like what is hitting the screen.
You probably can get away with less expensive materials. What I would do would be get a couple small samples of a few things that aren't going to break the bank (say a yard since that's how they sell it by) and test it out on the wall and ceiling that gets the directly reflected light from the screen. If it absorbs that, they you'll be fine with any ambient light too.
I actually used black suede for my quick temp border and it works very nicely... not as good as Velvet, but it was also $2.5 a yard, so it worked extremely well for the price. Try a couple samples before jumping into any particular material.
Also you can sometimes snag a great deal on velvet curtains on ebay. I know you didn't say you were looking for curtains, but I'm sure you could use them and make them work as a wall covering.
Old 10-18-07, 01:25 PM   #3 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
So I just got done putting a 12" border around my screen with black spandex velvet. Looks great.
....but my ceiling and side walls are another story.
I cannot paint them and the velvet is too expensive to use that much of.
My ceiling is vaulted as well. So above the screen it is shaped like this (/) but on less severe angle. So the left side of the screen is 'much' closer to the ceiling than the right side.
I don't want to only cover the left half of the ceiling so I may be out of luck there as a piece on just the left half of the ceiling would look AWEFUL.
To the immediate left of the screen is a door, so it's hard for me to do anything to that wall as well....
To the immediate right is openess, then a column wall ~3.5' from the screen wall and only about 2' wide and from floor to ceiling.
Any ideas???
Old 10-30-07, 12:39 PM   #4 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
By Spandex Black Velvet, do you mean Velour? It has a higher pile than crushed velvet and the black is blacker than black for light absorption. I would think most commercial products would use something similar as real velvet is too expensive (made from silk).
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
