DIYTheater.com No Contrast screen paint kit - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss DIYTheater.com No Contrast screen paint kit in the Home Theater | Audio and Video forum; DIYTheater.com No Contrast screen paint kit Any ways, as I have finally settled on my screen size, I began the application. I had previously put down ...
Old 01-09-08, 04:36 PM   #1 (Link)
Alias: eb
Loc: Alexandria, VA
User: #13458
Since: Nov 2007
electronbee is offline
Any ways, as I have finally settled on my screen size, I began the application. I had previously put down four coats of Killz2 to cover up the red paint. I used that for a few weeks to be sure I was OK with the size and everything.
Yesterday, I put two coats of the included primer just to be safe. It does not dry as fast as the Killz2 and it smoothed out on top of the Killz2 very nice. I basically have to put my nose against the screen to see anything. The texture of the wall is less than that of an eggshell.
So, six coats total on top of the deep red paint. The directions say to wait a minimum of six hours before applying the screen paint so I let it go over night.
I just finished my first coat of the screen paint. Waiting an hour before applying the second coat. I noticed that the paint that got on my hands is sparkling. As if some super fine glitter was in the paint. Also, the paint is not as white as one might think. I have definitely seen whiter paint, I'd even say that Killz2 is more white than the screen paint. Now, just to clarify, this is a subtle difference in white and I am not saying that Killz2 has a higher gain and has a more uniform spectral balance. I have no clue on that.
I am taking pics which I'll post when I have completed the screen. I'll make some paint chips and take some pics of the screen paint and the Killz2 to see side-by-side.
eb
Old 01-09-08, 05:52 PM   #2 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Re: DIYTheater.com No Contrast screen paint kit
electronbee wrote: View Post
eb
Thanks for the update, eb. What shade did you end up getting?
EDIT: Nevermind, I should try reading your thread title.
Old 01-09-08, 08:14 PM   #3 (Link)
Alias: eb
Loc: Alexandria, VA
User: #13458
Since: Nov 2007
Heh...
Any ways, this paint is definitely more reflective. I have not even turned the projector on and the last coat is still drying but it's that obvious! Although this isn't a scientific observation, going by the illumination from the spot lights set off to the left and right of the screen edge, the lighting is more uniform. Before, the center of the screen was fairly dark. Now, it's considerably brighter and the illumination is more even across the entire screen.
I'm pretty stoked right now. Just 45 more minutes...
eb
Old 01-09-08, 09:59 PM   #4 (Link)
Alias: eb
Loc: Alexandria, VA
User: #13458
Since: Nov 2007
I LOVE IT!!!
Whatever mojo they got in that paint really works!
I´ll work on posting the pics tomorrow.
eb
Old 01-09-08, 10:13 PM   #5 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is offline
Excellent EB! What was the cost? And are the paint chips for little ol' me?
mech
mech
Got questions? Start a thread.
Old 01-09-08, 11:52 PM   #6 (Link)
Alias: Harp
Loc: Central PA
Harpmaker's Avatar
User: #12848
Since: Oct 2007
Harpmaker is offline
Hi eb!
I don't know if you have experimented with any of the pearl or silver "craft" paints (Delta, Folkart etc.), but if you have you may have noticed that the reflective particles in them, under close examination, appear to break white light up into colors especially a light green and light magenta. I would love to know if the top coat of paint you used does the same thing or if the reflections just appear white.
Old 01-12-08, 04:52 PM   #7 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
Harp, I can answer that and say no, DIY Theatre doesn't use mica or craft paint anything. This is specially designed and researched, and the DIY Theatre folks have a really good product.
Old 01-13-08, 06:12 PM   #8 (Link)
Alias: eb
Loc: Alexandria, VA
User: #13458
Since: Nov 2007
mechman wrote: View Post
mech
Yup... PM me your address and I'll mail you a paint chip. It's a 4x6 card that I rolled a few coats onto.
The total cost was $179 for the kit. It included 1/2 gallon of primer, 1/2 gallon of the No Contrast, and two rollers. It sounds expensive, and it is, but for someone like me who wanted it "done" it's well worth it.
Everything looks outstanding, the image looks like it is like "floating" in front of us.
I have not used any of the calibration discs yet either. I'll try those a little later. My bulb only has 40 hours on it or so.
eb
Old 01-14-08, 07:48 AM   #9 (Link)
Alias: mech
mechman's Avatar
User: #6446
mechman is offline
eb
Sounds good eb! Check your mail!
mech
mech
Old 01-30-08, 09:26 AM   #10 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
eb any updates?
Old 03-04-08, 02:35 PM   #11 (Link)
New Member
Alias: slybarman
Loc: Annapolis, MD
User: #17664
Since: Mar 2008
slybarman is offline
Photos and updates please!
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
Best MTM kit/plan for 70% HT, 30% music mrstampe DIY Speakers 20 01-10-08 09:15 AM
Tumult re-cone kit availability? Exocer Fi Audio 4 12-16-07 02:06 PM
Looking for Screen Paint Solution Panny82 Projector Screens | DIY Screens 40 12-03-07 07:39 PM
Setting White Level (picture/contrast) glaufman Video Displays and Processors 13 11-27-07 08:43 PM
Understanding Contrast Ratios in Video Display Devices Sonnie Video Displays and Processors 0 06-07-06 02:08 AM
Mach 5 Audio
