| Projector Screens | DIY Screens Black Widow PFG - the Discussion - Black WidowDiscuss Black Widow PFG - the Discussion - Black Widow in the Home Theater | Audio and Video forum; Black Widow PFG - the Discussion - Black Widow I could never figure out the benefit of calibrating it. I have used one of the THX programs on a ... |
| | #451 (Link) | |||
| re: Black Widow PFG - the Discussion - Black Widow I could never figure out the benefit of calibrating it. I have used one of the THX programs on a pixar dvd, but in the end I just use it how it came from epson. The process for rolling: Taped off current kilz screen (54" x 96" .... 110" diagonal). Used a standard 7" roller. At home depot I purchased a 1/4" nap Purdy (brand) roller, ($8 for a single roller), that is double vacuumed so that there is no lint. The screen is painted directly on my wall. I rolled as per your tutorial, smoothly top to bottom, then going back over the previous wet line. Layed the first coat down and the waited about an hour and did a second coat. The quart of valspar and the AAA was plenty of paint, I probably could have done a third coat with no problem. If I look closely at the wall you can see the aluminum speckle throughout the paint. There are no roller marks and it layed down pretty easy. | |||
| | #452 (Link) | |||
| | re: Black Widow PFG - the Discussion - Black Widow Great and thanks for responding teke. Sounds like you have a 'picture perfect' BW installation and it wasn't that hard was it? ![]() The aluminum you are seeing is really the key. Without those speckles, it would be an N7-N7.5 gray and would really mute the image brightness. The tutorial is also how I paint walls when I paint a room. Painting a screen should not be any more difficult than painting a wall... if a person can do that then they can do a screen. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #453 (Link) | |||
| | re: Black Widow PFG - the Discussion - Black Widow I also see it being mentioned other places to thin the BW mix with water. I contend that this is not necessary. The Createx Auto Air Aluminum is already thinning the mix. Basically you're adding 8 ounces of a material that is already close to the consistency of water, that's around 25% of a thinner material being added right there. Any more water and in my experience it becomes way too runny and doesn't roll well. Plus it drips and splatters more. I've seen people say that by adding water it will thin the mix and make it a smoother surface when rolled, and others have said and debated that adding water thins out the concentration of aluminum... Well, I'd like to say it right now and for the record. We developed BW and I think if anyone knows how and why it works and how to apply it, that it would be the people that developed it. I urge anyone out there interested in making a Black Widow screen to please follow the easy directions we provided and not to listen to third party sources that may not be familiar with the application. Their intentions certainly are good, but if there are any questions I am sure we can answer them just fine. ![]() A quick recap, adding water is not necessary unless you are spraying, then thin as recommended for your sprayer. Rolling- No special methods are required, but a good quality roller cover is definitely recommended. Any other questions... just ask! ![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #454 (Link) | |||
| re: Black Widow PFG - the Discussion - Black Widow Well, I painted yesterday and all I can say it.....WOW! I got the job done before the game came on so that was a plus. I ment to chime in yesterday, but was too busy watching TV. This is what I did..... I mixed everything up in a gallon pail. First I put in half a quart of the Bermuda Beige then I a bottle of 4oz AAA. Then I mixed a tad with one of the free paint sticks I got from Lowes. Once it seemed mixed/turned gray, I added the remaining quart of Bermuda Beige and another 4oz bottle of AAA and mixed again. Once it looked mixed I pulled out my drill and started mixing the paint again to be sure it was mixed well. Since everything was already taped off and sanded, I started painting. The paint rolled on VERY smooth and easy. I took long strokes until the screen was completly painted. Imediatly after painting I turned my projector on, and was like OK.....Looks good, but wet. Seemed too bright and the colors really needed to be tweaked. So, instead of tinkering around with it, me and a friend went to the liquor store for Beer/Snacks for the game. Came back about a little over a hour later and the screen was **** near dry. Turned the projector back on and things looked better(not so bright anymore). Things looked ALOT better, but just not what I was looking for. So I popped in my kids Monsters Inc. DVD and did a THX calibration. I set it up off the "Theater" presets and adjusted as needed.....and WOW! I could not believe the difference. I then switched from the DVD to my Comcast HD box and turned to ESPN2 and man I could not believe it. ![]() This is soooo much better than a white wall. I have been connecting everything to my projector. The best picture comes from my PC for some reason(Radeon 3850). After school today I am going to pick up a BluRay Drive for my PC and see how it performs. Overall I am VERY pleased and would like to thank all that contributed to this mix. Also, I'd like to add that before I left this morning, I noticed the picture still looked good with sunlight coming into the room. Blacks looked black and colors still looked bold. I could be wrong, but the picture lookded a bit better this morning than it did last night. I guess it wasn't completly dry or whatever. Will see how it performs later tonight. Though overall, I am very impressed. | |||
| | #455 (Link) | |||
| | re: Black Widow PFG - the Discussion - Black Widow Crunk with all paints, not just BW even after it is dry it still can be up to a week before the paint is fully cured. The picture should get better as the paint fully cures. So if you're happy now, in a week you should be very pleased. ![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #456 (Link) | ||||
| re: Black Widow PFG - the Discussion - Black Widow Quote:
Water is recommended for the HE-558 version of Black Widow. HE-558 is a thick roof coating and when combined with a thick paint it needs to be thinned just a bit in my experience. But as Bill and Harp have already mentioned, AAA requires no thinning when rolling. I'll be spraying today and tomorrow so I'll have a better feel for thinning AAA for spraying later. mech Got questions? Start a thread. | ||||
| | #457 (Link) | ||||
| | #458 (Link) | ||||
| | #459 (Link) | ||||
I know a lot of people that use that 'W' technique that some (not all) professional painters use and you often see them do on TV. Personally I think that method stinks and is prone to missing spots, especially if you are painting white on white. I paint kinda like I mow, I do a straight line, turn around and overlap slightly where I just cut, and make another straight line... repeat until finished! I paint the same way, pretty much like in the tutorial and I have never had any issues with roller marks or missing spots. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #461 (Link) | ||||
| re: Black Widow PFG - the Discussion - Black Widow I've been very busy lately helping some people out over in the UK get their Black Widow ironed out and working. It's finished over there now and here are a couple pictures from one of the UK-BW folks. These are from an SD projector I believe and the individual is very happy with the results! ![]() ![]() ![]() ![]() Testimonial: Quote:
| | #462 (Link) | ||||
| re: Black Widow PFG - the Discussion - Black Widow Some more pictures in darkness: ![]() ![]() ![]() ![]() Quote:
| | #463 (Link) | |||
| | re: Black Widow PFG - the Discussion - Black Widow mech that looks really good to me. Glad the UK guys found materials that work for them. Those images also show that Black Widow (mainly the whole aluminum concept) can make a very dark screen perform like a much lighter screen. The lights on shots compared to a white wall shows the difference and is very pronounced. I maintain that the original statement of blacker blacks and whiter whites was not unfounded claims and hype as was said early on by some. This stuff really works! "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #464 (Link) | ||||
| | re: Black Widow PFG - the Discussion - Black Widow Just saw this on another site- made me feel pretty good! ![]() Quote:
| | #465 (Link) | |||
| re: Black Widow PFG - the Discussion - Black Widow I don't think I've seen this kind of acceptance in quite some time - if ever. I wonder what the naysayers are saying now! It's pretty obvious that everything we've said is true! ![]() mech Got questions? Start a thread. | |||
| | #467 (Link) | |||
| re: Black Widow PFG - the Discussion - Black Widow All of this looks amazing. Keep up the good work guys. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #469 (Link) | |||
| re: Black Widow PFG - the Discussion - Black Widow Now I'm confused. I thought they were using an SD projector. The AE2000 is HD (1080p). Was it just the content that was SD? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
