| Projector Screens | DIY Screens Black Widow PFG - the Discussion - Black WidowDiscuss Black Widow PFG - the Discussion - Black Widow in the Home Theater | Audio and Video forum; Black Widow PFG - the Discussion - Black Widow wbassett wrote:
That opens a whole can of worms! Guessing that is...
We will have gain readings done but mech's ... |
Views: 30021 - Replies: 673
| | #26 | |||||
| Re: Black Widow PFG Quote:
take a wild stab ![]() Prof.. Home Theatre...the never ending story! | |||||
| | #27 | ||||
| Re: Black Widow PFG | ||||
| | #28 | ||||
| Re: Black Widow PFG Prof I will say seriously that there is some viewing cone so that means there is gain, but how much, we can't say right now until it's tested. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #29 | ||||
| Re: Black Widow PFG Great jobs guys and thank you. I assume an Designer White substrate will work for this or are you using something else that is better recommended? Thanks. | ||||
| | #30 | ||||
| Re: Black Widow PFG I used hardboard for my panels. I believe muzz painted his wall. Don't quote me on that though! mech | ||||
| | #31 | ||||
| Re: Black Widow PFG wow, I checked all the places listed on Henry's site and no one around me here even know's about this manufacturer. If anyone plans on buying these in bulk and willing to ship, let me know. Thanks. Seems the minimum is 1 gallon | ||||
| | #32 | ||||
| Re: Black Widow PFG It would be interesting to make up some PFG with the Auto Air Aluminum (AAA ) product. I still have some left over. Although, I would have to use the Behr 4850 white paint as the base. This paint is awesome guys. I think it would be as good if not better than the other white paints you have tried. The good thing about using the AAA is it does help with spraying as it was designed to be sprayed. Just a thought, Or is that 2 thoughts? | ||||
| | #33 | ||||
| Re: Black Widow PFG Looking good guys, with the correct measurements of importance now being done it shows how good and how bad some early work was. The most colour uniform screens have a unity gain of one. The moment you have gain you risk colour shifts off axis and in some cases on axis. ie a wide 35degree viewing angle and a high gain will appear non uniform across the width. The spectrum for a perfect screen is perfectly flat. For those unaware, these spectrum readings are how the material responds to light as radiation. The material or surface needs to equally absorb or reflect the viewable spectrum no matter what the source. The PFG screen spectrum looks good, however being a perfectionist I think some areas need attention. The result from the mix appears to create a curve, convex in relation to the reflected light. Slightly more dropoff at the Blue end of the spectrum. The issue of this is because of how a PJ creates it's light and reflected difference at different percentage luminances. Ie creating the 11 point black to white ramp. Because the PJ spectrum of light is lumpy in nature (even at D65) the effect of a non flat spectral surface is minor shifts in peceived colour balance as the PJ stimulas is raised and lowered. In effect with the Blue end spectral reflective response dropping away the perceived center weight of seen blue colour will shift to the left and right as the simulas ramps up and down. It is our perception of the resulting colour shift that is important. The base shade of TV mist is possibly too flat and/or the 588 has a minor convex curve to it which is hard to see. I suspect the 588. To compensate have a look for a shade which is slightly high Blue, low Green and high Red. B230,G228,R230 for example. If you get the idea a slight concave nature. The resulting spectrum mix with the 588 would in theory result in a flatter appearence. teehee another 20 hours homework for Mech![]() ![]() ![]() Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? Last edited by <^..^>Smokey Joe; 01-21-08 at 04:36 PM.. | ||||
| | #34 | ||||
| Re: Black Widow PFG Reading the Henry 558 PDF docs said it replaces ProGrade #818 AquaBrite and Henry #229 Aluminum Emulsion. I wonder if those are easier to obtain and if it is the same product? | ||||
| | #36 | |||||
The bottom line is you can spray your DW if you want to. I don't know about rolling. H. | |||||
| | #37 | |||||
So we are definitely talking higher than 1.0..A little viewing cone loss wont bother me.. Prof.. Home Theatre...the never ending story! | |||||
| | #38 | ||||
| Re: Black Widow PFG Have you met my wife? She wants to meet you.... well not so much meet.... ![]() ![]() ![]() ![]() ![]() ![]() On a serious note, we did try what you proposed with Violet Disguise - 239 236 240. If you go and look at the master list it gave us fits! All three of us (Bill, Jim, and myself) thought it would be ideal, and yet it failed... ![]() mech | ||||
| | #39 | |||||
But my reference white showed up a few minutes ago! ![]() mech | |||||
| | #40 | |||||
![]() mech | |||||
| | #41 | |||||
![]() But I am tinkering with some other things that have been tried before and some that haven't. Where they'll lead us... But I do know this. I have a heckuva lot of respect for you guys who've done this without a spectro! You guys are amazing and my hat is off to you! ![]() mech | |||||
| | #42 | ||||
| Re: Black Widow PFG Mech ahhh didnt see that in the list before, I see ....interesting. ![]() I have found some local brand Silver metallic and aluminium testpots in the garage from earlier experiments. My silver Metallic is lighter than the 588, I through some into some white and Magnolia(a violet tinted white)at 4:1 ratio and so far in mix pots is looking ok. Have to wait to the base coats(white) dry and go hard, a day or so, before I apply some mix. Oh I have already experimented a whiles ago with layers and light penetration. Your base shade adds to the combined spectrum as light will hit 5 layers of paint and return. I feel you should always do atleast 2~3 base coats and 2 topcoats. A consideration not to be forgottern and maybe a way to tweak total result ![]() Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? | ||||
| | #43 | ||||
| Re: Black Widow PFG Well I'm at 2 coats of Kilz2, 1 coat of EF08, 1 coat of Kilz2, and 2 coats of WM5:1. I've got six coats... the stuff was giving us fits for trying to find a match. ![]() mech | ||||
| | #44 | |||||
We won't even talk about off axis viewing because a gray screen with gain, IMO, ins't all that great off axis. That's part of the reason I ditched CGIII, gain of 1.8, for a lower gain, lighter shade of gray screen. | |||||
| | #45 | ||||
| Re: Black Widow PFG What is the best material to use the PFG on? Should I buy a tileboard from Lowes? I have a polywall screen now with Behr Silverscreen. I just ordered a SP-7210 and I'm worried that the Silverscreen will be too dark for it. Thanks Last edited by bidzer; 01-22-08 at 09:03 AM.. | ||||
| | #46 | |||||
| Re: Black Widow PFG Something strange.....I contacted DoItBest.com and here is the reply: Quote:
I have a contact number Home Depot gave me to somewhere in my state (non Home Depot), I'll call and see what they can do. | |||||
| | #47 | ||||
| Re: Black Widow PFG Also, which of the base would be better to get, LW or WM? I couldn't help but notice that the WM comes closer to 65K and seems to have a more balance curve. Am I just looking into this too much on something I would not notice at all between using LW or WM? Thanks. | ||||
| | #49 | |||||
If you don't want to reuse your polywall, then yeah anything will work, hard board, MDF... whatever you feel comfortable with. What is the lumen rating of the SP-7210? "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
| | #50 | |||||
So yes, LW would be perfectly fine to use and those bumps are partly the software that made the chart. I'm not saying it's is a laser flat straight line and the software screwed it up, just that with different graphing software you probably wouldn't see 'jaggies' but a smoother line. It still wouldn't be as flat as a surveyor's laser level but trust me these are very flat spectral responses. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
