Changing a pull down screen to a fixed screen - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss Changing a pull down screen to a fixed screen in the Home Theater | Audio and Video forum; Changing a pull down screen to a fixed screen Hi guys. Ive been lurking on here for some time but never posted any. Ive been busy reading and learning ...
Old 01-23-08, 09:06 PM   #1 (Link)
New Member
Alias: Nick
Loc: NE, North Carolina
User: #12271
Since: Oct 2007
carolinacat is offline
Hi guys. Ive been lurking on here for some time but never posted any. Ive been busy reading and learning what I can on here. My HT room is made up of 5 Klipsch Lascala speakers and 4 tc sound 15's in sealed 10cf enclousers. My speakers/cabinets are all DIY. Im running an Aragon stage one and 2007 amp, Crown xti 4000 for the subs, 3 Sony 777es and an Escient dvdm 300 controlling everything, and Belkin pf60 for conditioning and Belkin battery backup for the Escient, Xbox 360 and Projector. My projector is a dell 2300 that i have had for years now. I am planning on upgrading to a panasonic ax200u soon. My screen is a Draper 106 pull down .
So heres my problem/question. I would like a fixed screen. This will allow me to rasie the screen up closer to the celing. And maybe go to a larger size. I dont know if i should sell the draper and buy a fixed screen or seeing as how this one is paid for cut the screen loose and make some kind of frame for it. Anyone have a link to something like that being done. I feel pretty sure it would be easy to do im just not sure how to hold the screen material to the frame and how to pull it tight. Thanks for any advice given.
Heres a link to a couple pics
http://groups.msn.com/Twinturbomusta...to&PhotoID=295
http://groups.msn.com/Twinturbomusta...to&PhotoID=296
Old 01-23-08, 10:19 PM   #2 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Re: Changing a pull down screen to a fixed screen
I think Bill has been working on something that would fit the bill, so to speak! I'm sure he'll chime in here shortly otherwise pm him. It's a lightweight screen frame for fabrics.
All I could help you out with would be a wood frame.
mech
PS Welcome to the Shack Nick!
mech
Got questions? Start a thread.
Old 01-24-08, 08:51 AM   #3 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
carolinacat wrote: View Post
Wow, Nick, Got bass?
Old 01-24-08, 12:46 PM   #4 (Link)
New Member
Alias: Nick
User: #12271
Since: Oct 2007
And you know you always want more. Overall im pretty happy with my setup just need to upgrade my projector and do something with my screen.
Old 01-24-08, 01:01 PM   #5 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
Nick I'll be honest with you... I'm scared to tell you to destroy your screen! Before cutting painting (as some people recommend) or doing anything that would/could destroy your commercial screen, see if you can sell it and put that money towards your new screen.
I would think the method I'm working on would also work since I'm using BOC, but I don't know how delicate your screen material is. I really wouldn't want to tell you to cut the screen material off and then ruin it and end up throwing everything out. If you can't sell it, or feel your won't get any money out of selling, sure then take a gamble.
I'm still working on this but my first prototype worked and now I just need to make a few updates, take the photo journal, and then put it all together as a thread.
I know you don't want to wait for that though
Okay here's what I am doing... Most people make a wood frame and then stretch and either staple or tack the screen material to that. There is nothing wrong with that method at all. Basically it's following the principles of what artists do.
Here's what I'm working on... I got screen door aluminum frame, cut everything to size, and then instead of staples or tacks, use spline just like you would do for making a window screen.
Now here's the problem, but only a minor one... When you get to the size of a projection screen, that's usually way bigger than any screen window or door and the frames need some cross braces. You can buy clips easy enough, but they cause the cross braces to be pressed against the screen material. This is fine if you're making a screened in porch, but not so fine if you're making a projection screen. Since I already had my prototype frame material (bought everything at Home Depot for around $20) I decided to just buy some 1/8th inch thick by 1/2 inch wide aliminum and rivited that on the back of the screen frame as cross braces. Now one thing to keep in mind, and that is this isn't the whole screen, it still will need a trim border. Weight wise though it weighs next to nothing and pretty much will be as heavy as whatever you make your black border out of.
Now if I didn't already have the framing I have... I would go this route...
Connecticut Screen Works has a wide variety of screening frames, but check out their screen wall systems... no center supports needed! These are extremely strong and can be made insanely BIG!
They also sell thicker and stronger regular screening frames that's less expensive.
What I like about this aside from the weight is with spline, you can change your screen later on without having to pull staples or tacks. That may not be an issue for most people because most don't change screens that often, but some may want to upgrade screens. For me it makes it light so I can take it up and down and put other screens up for testing.
This 'should' work for you, but like I said, don't destroy your screen unless you really want to rip it apart. You don't have to use a DIY screen with this, you could get some Da-Lite material and that should work. I'd see if you can sell your screen and put that money towards your new fixed frame
Another option is aluminum extrusion that has a 'T' molding slot. Some extrusions are rounded or arc'd and look very nice and just like some of the commercial screen frames. Instead of spline, you'd use T molding with it. You can wrap the frame in velvet, or if you want Flock it with velvet and it will look just like a commercial screen frame. Flocking would be more time consuming though.
Bottom line is it can be done, just think about it before you destroy something you might be able to get some money out of...
Old 01-26-08, 12:13 PM   #6 (Link)
New Member
Alias: Nick
User: #12271
Since: Oct 2007
Im gonna see if i can sell it to some of my friends localy sort of a package deal with my old projector. Id really like to upgrade to a 120 inch screen anyway. But if that falls thru im gonna just try to make a basic wood frame for it. Thanks guys
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
16:9 Screen Vs. 2.37:1 CIH Screen Prof. Anamorphic Projection 62 04-12-08 08:05 PM
Colorimeter for both PC screen and projector screen? John Simpson Video Displays and Processors 7 02-20-08 03:59 PM
Drop down fixed screen. Boris Pasternak Projector Screens | DIY Screens 16 12-13-07 04:28 PM
Fixed Screen Art Tiddler Projector Screens | DIY Screens 16 09-22-07 06:11 PM
Painted screen vs laminate screen Harry Muscle Projector Screens | DIY Screens 5 07-05-07 05:04 PM
Mach 5 Audio
