Elite Screens Silver Frame Screen Review - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss Elite Screens Silver Frame Screen Review in the Home Theater | Audio and Video forum; Elite Screens Silver Frame Screen Review Isn't the EZ-Frame material black? Why not just purchase that instead of the Silver? Spraying the aluminum wouldn't be a ...
Old 04-28-08, 03:18 PM   #26 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Re: Elite Screens Silver Frame Screen Review
Spraying the aluminum wouldn't be a problem though. I'd use something like a Rustoleum spray paint to do the job.
mech
Got questions? Start a thread.
Old 04-28-08, 04:03 PM   #27 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is online now
$150 difference....buys a lot of Rustoleum...thanks!
Old 05-03-08, 02:15 PM   #28 (Link)
New Member
Alias: satcruiser
User: #20337
Since: May 2008
satcruiser is offline
I just purchased a 120" SilverFrame fixed screen with the High Gain material but was very disappointed with the gain. The brightness is similar to what I was getting from projecting the image on my wall. The viewing angle is also uniform all the way to 80 degrees in each direction. I have a smaller Da-Lite 1.3 gain screen which is much brighter than this one.
I was just wondering if they packed the wrong screen material. The model number on the carton shows that it should have been the High Gain.
Any idea how to determine if this is really the High Gain screen? I also noticed in your comparison shots with the CineWhite material on top of the High Gain material that there seems to be little difference in brightness between the two. Can you explain why this is?
Thanks
Old 05-04-08, 12:20 AM   #29 (Link)
Alias: mech
mechman's Avatar
User: #6446
satcruiser wrote: View Post
Thanks
From what I recall it was pretty easy to tell the difference between the two. The high gain was brighter than the white but it also had a graininess to it in bright white scenes. From the sounds of it they sent you the wrong stuff. I'd guess that they sent the gray material.
If you look at the spectrums the high gain appears much brighter than the white.
mech
Old 05-04-08, 12:21 AM   #30 (Link)
Alias: mech
mechman's Avatar
User: #6446
I'd like to add that it should be easy to rectify this as the material is pretty easy to change out. Give them a call!
mech
Old 05-04-08, 12:50 AM   #31 (Link)
New Member
Alias: satcruiser
User: #20337
Since: May 2008
mech,
Thanks for the reply. I have already contacted EliteScreen and should be hearing from customer service next week.
I was just curious with regards to an earlier photo you posted in this thread where you compared the HighGain material with the CineWhite. The High Gain did not look brighter, at least not in the photograph. It actually looks less bright. Is this due to the way the image was captured? Did it look brighter in real life?
Old 05-04-08, 01:07 AM   #32 (Link)
Alias: mech
mechman's Avatar
User: #6446
mech,
Show me which picture you're looking at. If it was the one slightly off angle then it more than likely had to do with it being off axis. There's only so much you can do with a picture. That's why we have real data such as the spectro readings and the spectrum images. I don't know of any other forum that has them. Unless they get them from one of our members!
But yeah, the high gain was brighter than the CineWhite on axis. And looking back at the shots they all appear that way. Take a good look at the macro shot witht the penny in it. Is that how yours looks? I'm guessing no.
Overall though I really liked the frame on this screen. It was very simple to assemble and the screen material went in pretty easily too.
mech
Old 05-04-08, 01:21 AM   #33 (Link)
New Member
Alias: satcruiser
User: #20337
Since: May 2008
mechman wrote: View Post
A few more pictures...
I was referring to the above photos which as per my understanding you overlaid the CineWhite material on the HighGain to show the graininess in the HighGain.
I do agree with you that the frame is of excellent build quality and the screen is very easy to assemble. I think this is a real bargain for the price and rivals much more expensive screens as far as design and build quality.
Old 05-04-08, 01:32 AM   #34 (Link)
Alias: mech
mechman's Avatar
User: #6446
SC,
Looking at the pictures of the ice in the hockey shots, the HG seems to be brighter. Don't ya think?
mech
Old 05-04-08, 01:50 AM   #35 (Link)
New Member
Alias: satcruiser
User: #20337
Since: May 2008
SC,
There is a subtle difference but not what I would have expected as per the specs of a 1.8 vs 1.1 gain... but as you mentioned photographs could be misleading due to many factors.
I am hoping EliteScreen will send me a replacement material and I will post a photo of comparing the two.
Old 05-04-08, 01:51 AM   #36 (Link)
Alias: mech
mechman's Avatar
User: #6446
Keep us updated SC!
mech
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
Elite Silver Frame/EZ Frame Experience Kruppy Projector Screens | DIY Screens 20 02-10-08 01:13 PM
Da-Lite Screen Material Review mechman Projector Screens | DIY Screens 63 12-29-07 12:20 PM
Focupix and Elite Screens chas Projector Screens | DIY Screens 4 07-19-07 03:57 PM
Frame of acoustic panel chas Home Audio Acoustics 6 03-21-07 03:58 PM
Visual Reality Releases "Reality Screens" - Home Theater Projection Screens Powered by Goo Chris Boylan Home Theater, Audio and Video News 0 09-30-06 06:20 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167
