Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
My DIY Screen
Discuss My DIY Screen in the Home Theater | Audio and Video forum; My DIY Screen Well due to my limited budget I decided to give an idea a try. As some of you have seen ...
Elite Screens
Views: 1503 - Replies: 15
Old 02-10-08, 06:30 PM   #1
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
My DIY Screen
As some of you have seen here, I simply painted my 96" screen onto a wall using Behr "silver screen" that I built. I really was not happy with it although it worked. Recently after reading the great posts about using aluminum paint mix I was curious as to what I could do on a budget.
I went to my local Home Depot and picked up a 946ml can of Behr Ultra Pure White Flat finish (#1050) and 458ml bottle of Metallic silver (#743) that is located in the crafting area of the paint display.
After trying two different mixes I finally decided to just mix both together 100% so an entire can of the white mixed with the entire bottle of silver.
I painted the screen and waited for it to dry for about 6 hrs. I then tried two movies and to my joy the picture was MUCH better. The blacks were far better and the whites seemed to be just as goos as before maybe even better. Hindsight being 20/20 I should have only done half the screen and done a side by side test but of course my brain was not working
I will just say that it did make a very noticeable difference compared to what I had. If any one wants to actually do a side by side test to see if I am on to something that may not be a bad idea but for me it really made the contrast better and the color seems to be even better.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 02-10-08, 06:42 PM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: My DIY Screen
Glad it worked out for you Tony. For what you put into it, it's a cheap upgrade that works!
Old 02-10-08, 07:14 PM   #3
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Re: My DIY Screen
That is a LOT of silver in the mix (2:1)..What is the viewing cone like?
Prof..
Home Theatre...the never ending story!
Old 02-11-08, 10:16 AM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: My DIY Screen
Its really even, I was actually surprised. I thought I would have issues but from what I see there is no hotspot or dimming of the image on the sides. Viewing angle is good as I can see no difference even when sitting in the farthest left or right seats. My projector is not very bright (800) but it looks great.
Home theater:
Two Channel system:
My Webpage
Old 02-11-08, 05:15 PM   #5
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
  cynical2 is offline
Re: My DIY Screen
I'm glad you've got something that you're happy with, Tony! At the end of the day, that's what matters most. I'm a bit surprised that there are no hot-spotting or viewing cone issues. A couple of questions:
  • Do you have any idea how dark it is (perhaps by comparing to a known neutral)?
  • Do you see any red/blue push?
It would be interesting to get some spectro readings on it, at a minimum. Any chance you can send mech a small sample (can be as small as 2"x2")?
A couple of other requests that will help us better understand screen characteristics:
  • Can you take a flash camera shot of the screen from 6-8' away?
  • Can you take some screenies of a couple of movies (light scenes, dark scenes, colors)?
Jim
Old 02-11-08, 05:25 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: My DIY Screen
cynical2 wrote: View Post
I can do that, what would be a good neutral?
Blue looks bang on however the red may be a little hot but that may just be my settings on the projector.
I dont think I have any left but I will look tonight.
Jim
I will post some tonight if I have some time.
Home theater:
Two Channel system:
My Webpage
Old 02-11-08, 05:55 PM   #7
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
  cynical2 is offline
Re: My DIY Screen
tonyvdb wrote: View Post
Great, thanks!
The best thing to do would be to look at easyRGB.com for the brand of your choice. Do you have a Sherwin Williams near you? If so, you could go by and bring home some paint chips from there (that are close to neutral to your eye) over a range of shades. Then, let us know which is closest in color to your screen.
If you're able to send a sample to mech, then there's no need to try to get an idea of shade (and you can ignore the above). Mech can give you an exact color when he measures it.
Looking forward to your pics!
Old 02-11-08, 06:11 PM   #8
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Re: My DIY Screen
Me too...That's amazing that you don't have any viewing cone issues or any hot-spotting!!
The lower lumen projector could be the reason for no hot-spotting, but shouldn't have any effect on the viewing cone though..
Prof..
Old 02-13-08, 11:20 AM   #9
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: My DIY Screen
Ok, Here is a photo as requested. I had the camera directly below my projector at about 10ft from the screen. The room was totally dark with no lights other than the camera flash.
Does this look ok to you guys?
Home theater:
Two Channel system:
My Webpage
Old 02-13-08, 06:11 PM   #10
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Re: My DIY Screen
It looks very good actually...There doesn't seem to be any hot-spotting from the flash at all..
Quite remarkable really, considering the amount of silver in the mix..
A couple of screenshots would be good to see...
Prof..
Old 02-13-08, 10:54 PM   #11
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: My DIY Screen
Here is a shot from the Movie Night at the museum. Remember my projector is only a Sanyo Z2 720p so the picture quality may not be as good as what some of you are used to.
Home theater:
Two Channel system:
My Webpage
Old 02-14-08, 03:23 AM   #12
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
  cynical2 is offline
Re: My DIY Screen
Thanks for the pics, Tony! Screen uniformity looks great on the flash shot.
I'm really not trying to make a ton of work for you...but to my knowledge you're the only one that's used this mix. By chance, do you have any painted test panels, BOC, etc that you could place over a portion of the screen for side-by-side comparison?
Also, have you calibrated your pj settings since making the new screen?
Old 02-14-08, 10:20 AM   #13
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: My DIY Screen
I simply have not had the time. I may try to do it tonight but things have been so busy lately I was lucky just to have the time to take the pictures I have
I don't have any paint left that I used but it was Behr Ultra Pure White Flat finish (#1050) and 458ml bottle of Metallic silver (#743) that is located in the crafting area of the paint display
Home theater:
Two Channel system:
My Webpage
Old 02-14-08, 10:48 PM   #14
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
  cynical2 is offline
Re: My DIY Screen
No problem Tony, whenever you get to it would be great. If anyone else decides to try your mix, hopefully they can make a sample to be tested by mech.
Old 08-13-09, 10:29 AM   #15
Alias: David
Loc: Denver Colorado, 80233
User: #39394
Since: Jul 2009
  DavidHawke is offline
Re: My DIY Screen
Can you clarify please....
Is the "Metallic Silver #743" a Behr Product? Or another brand?
My local Home Depot has a silver Behr Product called "Luminoso". However, I have mixed it with UPW, and it fails to sparkle at all (like Craft Smart Silver does).
Did the #743 definitely sparkle through the mix.... or did it just turn the white paint a shade of gray?
Old 08-13-09, 11:24 AM   #16
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: My DIY Screen
It was not a Behr product but is sold at Home depot in the crafting paint spot and is in a grey plastic bottle. It does not sparkle as it is not supposed to unless you look really closely it just makes the white more grey with a bit of a reflective sheen look.
Home theater:
Two Channel system:
My Webpage
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
