My Laminate Screen Build (dialup beware) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss My Laminate Screen Build (dialup beware) in the Home Theater | Audio and Video forum; My Laminate Screen Build (dialup beware) I received a free sample of a WilsonArt laminate from Bill. The information on the laminate can be found in ...
Old 02-11-08, 06:57 PM   #1 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
tritonman is offline
I received a free sample of a WilsonArt laminate from Bill. The information on the laminate can be found in this thread. Basicaly these were custom colors straight from Wilsonart.
http://www.hometheatershack.com/foru...-laminate.html
I got the brighter one from Bill, which is closer to the DW color. I believe the color code is N9.25. As you can see one of the stipulations of the free sheet was to do a write up of the screen build and send a sample to mech for testing. Here is the first part of the stipulations.
Sooo..here it is, the screen build. The end result will be a 92". I had alot of help from a friend on mine with this.
This is a pic of the back of the sheet with the numbers etc on it. I have no clue what the numbers mean but here they are anyways. I figure this would be of more use to mech and Bill.
Next is a picture of the laminate and the 4x8 1/4" sheet luan plywood that is going to be used as the backing for the laminate.
The next step will be to use Contact Cement on both the luann and the laminate. Here is the product used
Here you see the cement has been applied to the luann and the laminate. A paint roller was used to apply the cement on both pieces. After the cement was applied, any big pieces of the glue etc were removed or smoothed out to prevent any bubbles or bumps showing up later in the build. This had to be done on both pieces.
Here you see some pieces of wood placed on the luann in intervals to keep the laminate from touching the whole luann sheet at once. You place the laminate on top of the wood strips and center your laminate to where you want it to sit, then remove one strip at a time as you let the laminate touch the luann and work your way from one end to the other removing each wood stip along the way until you have the laminate attached to the luann
The laminate is now attached to the luann and smoothed out with a rubber roller. Once it was smooth the edges were trimmed to match the luann underneath to help with the cutting it to size. In my particular instance the measurements for the 92" screen were made to be 3/8" larger all the way around to have enough room to attach the border later.
The next step is to work on the border that will go around the screen. 1x2 wood was used for the border. Here are the pics of the wood. The edges were rounded to make them look better and not sharp.
Here you see the wood has been cut into 3/8" deep to match the 3/8" that was left all the way around the main size of the screen
Now you basically put some wood glue inside your groove that was cut, along with cutting your corners like molding and then slide it in on your edges of the luann/laminate, then place a few strategic finishing nails in the corners and underneath the long edge of the screen as well. When you place the nails in the underpart of the screen make sure you dont go too far in or you will end up with a nail showing up on the laminate side of your screen.
So here is our finished product.
Ok. So ive got my screen built, its almost pretty much ready to go. But how am I going to hang it? Well here is your answer. You will need 2 of these btw. At the Home store Depot I bought these at they were roughly 5$ each or less.
You install one of the stips on the top of your screen like the below picture.
The other one you install on your wall the other way. Then you just simply hang the screen and they will lock together. Then you have your nice new screen hung up and ready to go.
Dont mind the wall as its not completely done just yet, but you get the general idea. The next step for me is to order some black Duvetyne tape to black out the border all the way around to absord any possible light spill and to add a finished look.
Well there you have my screen all built and pretty much ready to go. At this point I dont have any screenshots of it in action. Bill is possibly coming over to my house this weekend and we will be taking some pics of movies in action. I hope to post them once we get them all uploaded and ready to go. Im hoping we also have time to take some addtional pictures of different laminates or materials to show any differences in the screen color i have compared to others.
Thanks and enjoy.
Old 02-11-08, 07:44 PM   #2 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Re: My Laminate Screen Build (dialup beware)
Beautiful! Any cut offs?
mech
mech
Got questions? Start a thread.
Old 02-11-08, 07:47 PM   #3 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Wow...1st class all the way! Absolutely beautiful. Looking forward to screenies!
Old 02-11-08, 08:08 PM   #4 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
mechman wrote: View Post
mech
I didnt forget about you mech Ive got you covered.
Old 02-11-08, 08:42 PM   #5 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
Just as an FYI..the projector that I have for the screenshots will be the Epson Home Cinema 720. The screen is 92" and seating is approx 12' from the screen. I will be including a picture of the lighting in the room as well to show where my lighting is so people can have a better understanding of where the light is coming from. Naturally there will also be pics of no lighting as well
Old 02-12-08, 09:08 AM   #6 (Link)
Alias: mech
mechman's Avatar
User: #6446
You know I just went through and looked at this again. Triton, you are a craftsman! And the carpet edge trim for the french cleat? Ingenious!
mech
mech
Old 02-12-08, 10:36 AM   #7 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
mech
Thanks Mech! I cant really take all the credit for this, I did have a lot of help in putting this all together.
Im just glad to have the opportunity to post something like this for others to see and hopefully get some ideas from. Its been too often I had used other peoples ideas and not had a chance to share any of my own or had anything worth contributing.
Old 02-12-08, 07:54 PM   #8 (Link)
Silver Supporter
Alias: muzz
Loc: Easton,MA
User: #4518
Since: Nov 2006
muzz is online now
Looks good tman.
Very well done.
Thanks for sharing that, I hope you enjoy it!!
Old 02-21-08, 12:33 PM   #9 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
muzz wrote: View Post
Looks good tman.
Very well done.
Thanks Muzz, always glad to share!
Old 02-21-08, 12:55 PM   #10 (Link)
Alias: Brian
Loc: Tewksbury, MA
User: #15852
Since: Jan 2008
bidzer is offline
It does look awesome. Looks like you have a nice area to work on it
Old 02-21-08, 02:48 PM   #11 (Link)
Alias: mech
mechman's Avatar
User: #6446
Hey Keith,
Throw some pics up in the Laminate Showcase sticky thread!
mech
mech
Old 02-21-08, 04:27 PM   #12 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
Hey Keith,
mech
Will do!
Old 03-21-08, 09:55 AM   #13 (Link)
Alias: mech
mechman's Avatar
User: #6446
tritonman wrote: View Post
Did I give you my address Keith? And did you get the lighter or the darker of the two?
mech
mech
Old 03-21-08, 10:29 AM   #14 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
mech
Nope you never sent me your address that I can remember? I believe I did ask you for it? I think we are both just getting old and forgetful!!
I got the brighter one of the 2..N9.25
Old 03-28-08, 02:30 PM   #15 (Link)
New Member
Alias: slybarman
Loc: Annapolis, MD
User: #17664
Since: Mar 2008
slybarman is offline
How tight against the wall is your screen using the carpet trim french cleat? I was considering using this method to hand a wood frame around a painted screen - would that work or does it leave a gap between the frame and the wall?
Old 04-04-08, 01:19 AM   #16 (Link)
Alias: Tiny
Loc: Tuscaloosa, Alabama
User: #19096
Since: Apr 2008
MonsterMaddness is offline
I gotta say I'm impressed. I think I'm gonna build one of these for my setup!
Old 04-04-08, 01:47 PM   #17 (Link)
Alias: Tritonman
Loc: Latham, NY
User: #16320
Since: Feb 2008
slybarman wrote: View Post
It does leave a small gap, i can measure it for you if you are interested in how big the gap is. Im pretty sure the gap is minimal at best. I dont recall it being very large at all.
Old 04-23-08, 12:12 PM   #18 (Link)
New Member
Alias: strongisland
User: #18895
Since: Mar 2008
strongisland is offline
Hey Triton,
I followed your screen build to the T. I couldn't be happier. Thanks for the post. Project pictures and screen shots to come soon.
Old 06-03-08, 01:57 PM   #19 (Link)
Alias: dae06
Loc: S.E. Minnesota
User: #21335
Since: May 2008
DAE06 is offline
Is there a certain color of laminate to use? Or could I paint this with the black Widow or Cream and Sugar?
Old 06-03-08, 02:26 PM   #20 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
Laminates are a stand alone screen option. If you want to paint there are less expensive substrates you can paint.
Old 06-04-08, 07:21 AM   #21 (Link)
Alias: dae06
Loc: S.E. Minnesota
User: #21335
Since: May 2008
DAE06 is offline
Is there a list of laminate colors that will give us an N8 or N9 shade?
Old 06-04-08, 01:20 PM   #22 (Link)
Alias: Harp
Loc: Central PA
Harpmaker's Avatar
User: #12848
Since: Oct 2007
Harpmaker is online now
DAE06 wrote: View Post
For a list of color data for many paints, mixes and laminates read this Sticky:
http://www.hometheatershack.com/foru...ster-list.html
The column marked "L" can also be read as the Munsell N value by moving the decimal point one place to the left. For example, the second listing is for Formica Platinum Laminate and the L value is 69.0; this can be read as a N value of 6.9 .
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
