Is there a Behr N9 equivalent to True Value "Winter Mist" - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens
Discuss Is there a Behr N9 equivalent to True Value "Winter Mist" in the Home Theater | Audio and Video forum; Is there a Behr N9 equivalent to True Value "Winter Mist" I read here about the N9 neutral gray "Winter Mist" by True Value. Is there a Behr paint that matches ...
Old 02-19-08, 11:44 AM   #1 (Link)
Alias: Barney
Loc: Mayberry
User: #17063
Since: Feb 2008
Barney Fife is offline
I read here about the N9 neutral gray "Winter Mist" by True Value. Is there a Behr paint that matches it? I'm used to using Behr paint and like it. I don't know anything about the quality of True Value paints. Thanks.
Old 02-19-08, 02:23 PM   #2 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
Re: Is there a Behr N9 equivalent to True Value "Winter Mist"
Welcome to the Shack!
I'm pretty sure there is a Behr match, I'll have to look dig around and find it though.
There is a Valspar match, but I know that doesn't help you as far as Behr.
Old 02-19-08, 05:10 PM   #3 (Link)
Alias: Barney
Loc: Mayberry
User: #17063
Since: Feb 2008
Thanks. What is the Valspar match? I think there's a store not too far away that sells Valspar. Is there a specific line or name of Valspar paint I want to use?
Old 02-19-08, 06:45 PM   #4 (Link)
Alias: Don
Loc: Central PA
Harpmaker's Avatar
User: #12848
Since: Oct 2007
Harpmaker is online now
If you have a Lowe's home improvement center near you they can match True Value Winter Mist in a Valspar base. See the link for details.
http://www.hometheatershack.com/foru...html#post81648
Old 02-19-08, 07:39 PM   #5 (Link)
Alias: Barney
Loc: Mayberry
User: #17063
Since: Feb 2008
Harpmaker, thank you. In case I can't get the Valspar, does anyone know if there's a match for "Winter Mist" from Behr or Glidden? Thanks.
Old 02-19-08, 10:17 PM   #6 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Barney Fife,
You can get a color called "Snowfield" from Glidden. It's neutral, and it's RGB values are about 220. That's the closest to N9 that I'm aware of (more like an 8.6-8.7)...see below for the neutral Munsell shades.
Jim
Old 02-20-08, 09:30 AM   #7 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is offline
Barney Fife wrote: View Post
Barney,
No Lowe's, True Value's, Sherwin Williams, Ace Hardware, etc near you? Where in Wisconsin are you?
The reason we do not recommend Glidden or Behr products is because outside of the N7 that X-Rite gave us, nothing has been tested. Either by us or by the folks at EasyRGB. There was some data at one point in time from Glidden but the numbers were off a bit - enough to draw concern. The only thing we can attest to is that the paint card samples at Home Depot for some of the Glidden products did test neutral. However, a paint card sample is not a fan deck and without samples to back them up... you won't get much of a recommendation from us.
If the numbers from Glidden had lined up, I think we could have had something for you. But they didn't.
mech
mech
Got questions? Start a thread.
Old 02-20-08, 05:59 PM   #8 (Link)
Alias: Barney
Loc: Mayberry
User: #17063
Since: Feb 2008
Thanks everybody. I bought the "Winter Mist" today from True Value, as I was wrong about getting the Valspar. I was unsure of True Value's paint quality, so I was looking for something I've used before. For what it's worth, the quart mix formula is:
Base: Pastel
Lamp black: 2.0
Exterior red: 0.5
Raw umber: 0.5
Old 02-20-08, 06:11 PM   #9 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
The quality of True Value paint isn't the best out there. I'd say it's better than Walmart's ColorPlace brand but not as good as Behr, Valspar, or any of the other brands.
People have used it though and it works fine for our purpose.
The advantages of better quality paint are it covers better, meaning less paint and coats required, and it usually levels out better, meaning less or no roller marks once it's dried.
Old 02-20-08, 07:31 PM   #10 (Link)
Alias: Barney
Loc: Mayberry
User: #17063
Since: Feb 2008
That's why I was trying to find a match from Behr or another quality paint. I'll use it and see how it works. If anything, I could take a sample to Home Depot and they could match it with their computer.
Old 02-20-08, 10:57 PM   #11 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
I painted my screen (my 2nd screen iteration) with TV Winter Mountain, and it went on just fine. I don't think you'll have any problems. Good luck!
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens »
Similar Threads
Episode 21 - $99 the end of the War?, "The Contract", They Might Be Giants "Factory" eugovector Real HT Info Podcast 10 11-13-07 06:07 PM
If I didn't already have the TV Winter Mist up... E-A-G-L-E-S Projector Screens | DIY Screens 14 10-19-07 12:02 PM
6.5" OB "bookshelf" speakers BoomieMCT DIY Speakers 11 07-22-07 01:07 PM
Sunfire "True Subwoofer" Solitaire EQ 10 vs. $100 Yamaha michael_98101 Home Audio Subwoofers 6 05-21-07 09:59 PM
My sub goes "tock" when it should go "thud" BoomieMCT DIY Subwoofers 11 04-18-07 05:07 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
