| Projector Screens | DIY Screens Is there a Behr N9 equivalent to True Value "Winter Mist"Discuss Is there a Behr N9 equivalent to True Value "Winter Mist" in the Home Theater | Audio and Video forum; Is there a Behr N9 equivalent to True Value "Winter Mist" I read here about the N9 neutral gray "Winter Mist" by True Value. Is there a Behr paint that matches ... |
| | #1 (Link) | |||
| Is there a Behr N9 equivalent to True Value "Winter Mist" I read here about the N9 neutral gray "Winter Mist" by True Value. Is there a Behr paint that matches it? I'm used to using Behr paint and like it. I don't know anything about the quality of True Value paints. Thanks. | |||
| | #2 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" Welcome to the Shack! I'm pretty sure there is a Behr match, I'll have to look dig around and find it though. There is a Valspar match, but I know that doesn't help you as far as Behr. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #3 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" Thanks. What is the Valspar match? I think there's a store not too far away that sells Valspar. Is there a specific line or name of Valspar paint I want to use? | |||
| | #4 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" If you have a Lowe's home improvement center near you they can match True Value Winter Mist in a Valspar base. See the link for details. http://www.hometheatershack.com/foru...html#post81648 | |||
| | #5 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" Harpmaker, thank you. In case I can't get the Valspar, does anyone know if there's a match for "Winter Mist" from Behr or Glidden? Thanks. Last edited by Barney Fife; 02-19-08 at 09:27 PM. | |||
| | #6 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" Barney Fife, You can get a color called "Snowfield" from Glidden. It's neutral, and it's RGB values are about 220. That's the closest to N9 that I'm aware of (more like an 8.6-8.7)...see below for the neutral Munsell shades. Jim ![]() | |||
| | #7 (Link) | ||||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" Quote:
No Lowe's, True Value's, Sherwin Williams, Ace Hardware, etc near you? Where in Wisconsin are you? The reason we do not recommend Glidden or Behr products is because outside of the N7 that X-Rite gave us, nothing has been tested. Either by us or by the folks at EasyRGB. There was some data at one point in time from Glidden but the numbers were off a bit - enough to draw concern. The only thing we can attest to is that the paint card samples at Home Depot for some of the Glidden products did test neutral. However, a paint card sample is not a fan deck and without samples to back them up... you won't get much of a recommendation from us. If the numbers from Glidden had lined up, I think we could have had something for you. But they didn't. mech mech Got questions? Start a thread. | ||||
| | #8 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" Thanks everybody. I bought the "Winter Mist" today from True Value, as I was wrong about getting the Valspar. I was unsure of True Value's paint quality, so I was looking for something I've used before. For what it's worth, the quart mix formula is: Base: Pastel Lamp black: 2.0 Exterior red: 0.5 Raw umber: 0.5 | |||
| | #9 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" The quality of True Value paint isn't the best out there. I'd say it's better than Walmart's ColorPlace brand but not as good as Behr, Valspar, or any of the other brands. People have used it though and it works fine for our purpose. The advantages of better quality paint are it covers better, meaning less paint and coats required, and it usually levels out better, meaning less or no roller marks once it's dried. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #10 (Link) | |||
| Re: Is there a Behr N9 equivalent to True Value "Winter Mist" That's why I was trying to find a match from Behr or another quality paint. I'll use it and see how it works. If anything, I could take a sample to Home Depot and they could match it with their computer. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Episode 21 - $99 the end of the War?, "The Contract", They Might Be Giants "Factory" | eugovector | Real HT Info Podcast | 10 | 11-13-07 06:07 PM |
| If I didn't already have the TV Winter Mist up... | E-A-G-L-E-S | Projector Screens | DIY Screens | 14 | 10-19-07 12:02 PM |
| 6.5" OB "bookshelf" speakers | BoomieMCT | DIY Speakers | 11 | 07-22-07 01:07 PM |
| Sunfire "True Subwoofer" Solitaire EQ 10 vs. $100 Yamaha | michael_98101 | Home Audio Subwoofers | 6 | 05-21-07 09:59 PM |
| My sub goes "tock" when it should go "thud" | BoomieMCT | DIY Subwoofers | 11 | 04-18-07 05:07 PM |
