| Projector Screens | DIY Screens Further Investigations Part IIDiscuss Further Investigations Part II in the Home Theater | Audio and Video forum; Further Investigations Part II Black Widow is a finished product. So where do we go from here? There's been a lot of talk about ... |
| | #1 (Link) | |||
| Further Investigations Part II Black Widow is a finished product. So where do we go from here? There's been a lot of talk about it being to dark of a mix so after a week of doing nothing it's time to start putzing with it again! ![]() I learned previously that adding Valspar Flat Ultra White to one of the previous trial mixes, that it had no effect upon the L*ab values or the xyY values. It basically just 'lightened' the mix. So I mixed up a 4:1:1 combination of Bermuda Beige:Valspar FUW:Auto Air Aluminum and a 3:1:1 of the same. I'm also tinkering with a straight 3:1 combination of AAA and Bermuda Beige. I have three samples of each drying and should have some numbers for them later tonight. mech mech Got questions? Start a thread. | |||
| | #4 (Link) | |||
| Re: Further Investigations Part II Three spectro readings: 4:1:1 Bermuda Beige : Auto Air Aluminum : Valspar Flat Ultra White (FUW) 197 198 198 0.312 0.329 56.3 79.8 -0.25 -0.29 3:1 Bermuda Beige : Auto Air Aluminum 183 183 182 0.313 0.329 47.2 74.3 0.00 0.17 3:1:1 Bermuda Beige : Auto Air Aluminum : Valspar Flat Ultra White (FUW) 191 191 191 0.312 0.329 52.2 77.4 -0.08 -0.08 In layman's terms, I think we hit the trifecta! So we took a completely neutral mix and added a white - which I have yet to measure any white neutral - and the result is a lighter more neutral mix. So the question is, how light can we go? I'm thinking along the lines of a 2:2:1 (Bermuda : FUW : Auto Air) or a 1:3:1 (Bermuda : FUW : Auto Air). I know that some of you are thinking about seeing full panels. But that will have to wait as my source of Auto Air Aluminum has run out since this mix was announced. At least in the convenient 4oz bottle size. Time to buy a quart I guess. I'm curious as to whether or not we can achieve some kind of a balance for the lower lumen crowd. As always I'm open to any input. mech mech Got questions? Start a thread. | |||
| | #5 (Link) | |||
| Re: Further Investigations Part II Actual after responding to this, I realized that you're using the Luminous White 6:1 ratio. I really doubt I'd be able to get lighter than that. ![]() Luminous White : HE558 6:1 213 215 214 0.312 0.331 67.8 85.9 -1.21 0.31 mech mech Got questions? Start a thread. | |||
| | #6 (Link) | ||||
| Re: Further Investigations Part II Quote:
![]() Have you started with a white base and then tinted it to find the appropriate color to make BW neutral? In other words, do the same thing as last time...only instead of starting with Winter Mist (and ending up at Bermuda Beige), you'd start with White and end up with the lightest possible neutral-causing base. The same process would be followed, since you have it perfected. ![]() At least, I think you started with W Mist...but maybe I'm ![]() | ||||
| | #7 (Link) | ||||
mech mech Got questions? Start a thread. | ||||
| | #9 (Link) | |||
| Re: Further Investigations Part II 1:1:3 BB:AAA:FUW 196 200 203 0.308 0.326 57.4 80.4 -0.86 -1.80 1:1:2 BB:AAA:FUW 188 192 195 0.307 0.325 52.5 77.6 -0.85 -2.04 2:1:2 BB:AAA:FUW 202 202 202 0.313 0.330 59.2 81.4 -0.14 0.34 1 outta three ain't bad. I think I'll sleep on this while they cure some. For those of you that don't understand these numbers I'll explain tomorrow. mech mech Got questions? Start a thread. | |||
| | #10 (Link) | |||
| Re: Further Investigations Part II Some numbers today after every thing's had a night to cure. AAA = Auto Air Aluminum BB = Bermuda Beige FUW = Valspar Flat Ultra White 4:1:1 BB:AAA:FUW 197 198 198 0.312 0.328 56.3 79.8 -0.27 -0.36 3:1 BB:AAA 182 182 182 0.313 0.329 46.9 74.1 -0.02 0.14 3:1:1 BB:AAA:FUW 191 192 192 0.312 0.329 52.4 77.5 -0.12 -0.17 2:1:2 BB:AAA:FUW 193 194 195 0.311 0.328 53.9 78.4 -0.30 -0.44 1:1:2 BB:AAA:FUW 188 192 195 0.307 0.325 52.4 77.5 -0.90 -2.08 1:1:3 BB:AAA:FUW 196 200 203 0.308 0.326 57.6 80.5 -0.88 -1.77 So my experiments from last night have obviously fizzled! But I think that it's safe to say that if someone is looking for a N8 version of BW -Auto Air the 4:1:1 seems to be it. The numbers. Bill could really do a much better job of this than me but her goes. The first three numbers are RGB or Red Green Blue. I think it's rather self explanatory but if you need more on this please ask. The second two sets of numbers are coordinates in color space. The x/y and the a/b numbers are coordinate plots and the L and Y are the Luminance plot. In all of the measurements I have done I almost always post them as above. RGB xyY L*ab Mainly because that's the order that I get them from BabelColor. The x and y numbers need to correspond to the particular point in color space that D65 resides - 0.312 and 0.329. sometimes you will see 0.312 stated as 0.313 because the actual value is 0.312730. The a and b numbers need to be as close to zero as possible. The luminance values are just that, luminance values. They tell you how light or dark the measured item is. Any questions? mech mech Got questions? Start a thread. | |||
| | #11 (Link) | |||
| Re: Further Investigations Part II Looking at those numbers it appears that I'll have three candidates for panels. It will all have to wait until more Auto Air arrives though as I'm pretty much out now - 3oz left. If you want the gist of what we're trying to accomplish, it's having several shades of this for different environments. Some folks don't like muddy whites and some don't like washed out blacks. Coming up with a screen that has both excellent blacks in ambient light and white whites is the Holy Grail of screens. mech mech Got questions? Start a thread. | |||
| | #13 (Link) | |||
| Re: Further Investigations Part II I just ordered 16 oz of AAA (hopefully enough to do my 120" screen). I am looking forward to the results of your tinkering. BTW - my theater room is my 1 1/2 year old's playroom during the day. Any concern with the aluminum additive to kids? Last edited by slybarman; 03-04-08 at 02:13 PM. | |||
| | #14 (Link) | ||||
Awesome that you are trying BW...you will love it! ![]() It's definitely safe for kids...we check the MSDS sheets to make sure it's safe before recommending it. The AAA is, as I understand it, paint for airbrushing...nothing dangerous about it. | ||||
| | #15 (Link) | |||
| Re: Further Investigations Part II Hey slybarman! Welcome! What are you looking for in a screen? You should start a new thread and throw out some room specs to go with it! ![]() (as mech runs out the door to go to a hockey game) ![]() mech mech Got questions? Start a thread. | |||
| | #16 (Link) | |||
| Re: Further Investigations Part II Thank you both for the welcome. The N8 BW sounds promising. I'll see how it does for the first couple guinea pigs. I have also stumbled across the DIY Theatres kit in the threads here on the shack. Any idea how BW compares against their product? Anyhow - My screen will be 120". Projector is Panasonic AX-200U. Throw distance and seating distance are both about 14.5'. Room is light controlled as far as the windows, etc, but the ceiling and walls are pretty light. Last edited by slybarman; 03-04-08 at 05:49 PM. | |||
| | #18 (Link) | |||
| Re: Further Investigations Part II Yes sir! I appreciate the information you shared with me. Mech pointed me over to this forum with regard to BW and I am interested to see how 4:1:1 mix shapes up. | |||
| | #19 (Link) | |||
| Re: Further Investigations Part II Well the one that actually looks better and is a bit lighter than the original is the 3:1:1. I did very little yesterday and it's back to work today, so I'm in a holding pattern again until next week. I had to paint another HE558 panel for comparisons to Auto Air Aluminum. I did however attempt to apply the same method using behr 4850 flat white. The numbers This is 3:1:1 with Bermuda Beige:Auto Air:Behr 4850 194 193 192 0.314 0.330 53.4 78.1 0.14 0.50 6410.4 And the numbers from Valspar's Flat Ultra White in the 3:1:1 mix are this: 191 192 192 0.312 0.329 52.4 77.5 -0.12 -0.17 6547.1 The numbers for Behr 4850 250 250 245 0.315 0.334 95.4 98.2 -0.97 2.26 6315.1 It has to be the brightest whites I've seen! ![]() The next experiment was Behr White Opal Pearlescent. I put a small dab on a panel that has one coat of Kilz2 on it. What it was originally? I don't know. But we can clearly draw some conclusions from reading the base numbers and then the WOP numbers on top. The base 237 237 231 0.316 0.335 84.3 93.6 -1.22 2.73 WOP - This is probably the first time I've come across a paint that has given me completely wacky numbers. Therefore I divided the sample and took measurements from 5 spots. I have never seen that much of a difference before! Usually I'll see a change of about .01 in either an a or b. But never anything this crazy! Keep in mind that I'm not saying that this cannot be used! Especially when it's mixed heavily with something else! Just throwing numbers out! Left upper side 213 211 203 0.320 0.339 65.2 84.6 -0.83 4.57 bottom left side 199 195 186 0.322 0.340 54.9 79.0 -0.28 4.93 dead center (where it's thickest) 198 196 189 0.319 0.338 55.3 79.2 -0.82 3.76 lower right 201 199 191 0.320 0.339 56.9 80.1 -0.76 4.24 upper right 213 209 200 0.322 0.340 64.1 84.0 -0.68 5.28 mech mech Got questions? Start a thread. | |||
