| Projector Screens | DIY Screens Need Screen Help - Dedicated, light-controlled HTDiscuss Need Screen Help - Dedicated, light-controlled HT in the Home Theater | Audio and Video forum; Need Screen Help - Dedicated, light-controlled HT I have a quick question. I'm considering using Black Widow for my screen. I have the good fortune of having ... |
| | #1 (Link) | |||
| Re: Black Widow User! I have a quick question. I'm considering using Black Widow for my screen. I have the good fortune of having a dedicated HT room with no windows Since I have complete control over light, should I use the standard ratio or even BW? Kilz2 looks awfully good as is, the walls will be very dark matte and the ceiling will be flat black acoustical tile, so reflections will be (hopefully) well controlled. With my Kilz2 test, I think I could stand just a tad more contrast in black. Doug | |||
| | #3 (Link) | |||
| Re: Black Widow User! Projector: The ubiquitous Optoma HD70. I bought it at during the $200 rebate sale. Screen size: Negotiable. I did a preliminary test in the room at the estimated seating position, which is 11-12 feet back in an 18' room. I projected a 120" diagonal, but it looked a little big and I could begin to discern pixels. I found by zooming in just a smidge, to about 108" diagonal, I got a better looking image. Doug | |||
| | #4 (Link) | ||||
| Re: Black Widow User! Quote:
At your seating distance I would recommend either 96" or 102". This will increase the lumens output of your projector since you would need to adjust your throw range and thus give you a brighter and more vibrant image and enhance your colors. With the DW and a smaller screen with the projector possibly moved closer, this will enhance your Contrast output and ANSI. Hopefully someone will either negate my advice or provide something better or even agree. | ||||
| | #6 (Link) | |||
| Screen Size It's funny how greedy you get. I was hoping for something a little bigger, but 102" would work out well for a lot of reasons. From what you're saying, a small sacrifice in size will reap big rewards in contrast and ANSI. Since our current TVs are a 15 year old JVC 19" and a 27" Sanyo CRT, I think I can scrape by with 102! This relieves me of several other concerns regarding trying to come up with a flat painted screen. Overall, construction may be simplified. I'll be hanging a suspended ceiling tonight in the storage room so that the junk in the HT area can be moved so I can start framing in there. I hope to have photos posted in the gallery soon. Thanks for your help. Doug | |||
| | #7 (Link) | ||||
| Re: Screen Size Quote:
I would start with a 102" as you have said..watch it at your seating distance and see how it feels, you may need to watch a couple movies to see how your eyes feel at your seating distance and screen size. Its always easier to cut it down to 96 or even 92 should you feel its overkill at your seating distance. You would think a few inches smaller of a screen would not make a difference but it truly does. Sometimes a smaller screen can yield a greater movie experience than being overwhelmed by a larger one for the wow factor. You will definately gain some brightness and contrast with a smaller screen and your projector close. I would try as hard as you can to place the projector as close to the screen as possible to yield the most out of your particular model with the least amount of work for the pj. Oh and dont forget those pics!! Last edited by tritonman; 02-22-08 at 03:36 PM. Reason: Added comment | ||||
| | #8 (Link) | ||||
BTW, I plan to fly all the speakers, excepting the sub and center. Doug | ||||
| | #10 (Link) | |||
| Re: Black Widow User! Mech, Since I'm new to all this, perhaps you can educate me. My questions arise from reading other threads here. If I'm correct, you have gone from laminate to BW. It was the BW thread and some of the positive remarks that made me consider it in the first place. I was a little surprised when you responded with a laminate recommendation. I defer to your greater knowledge and experience. I'm sure your recommendation factored in my screen size, dedicated light controlled room configuration and my projector. Could you give me a little more detail why you feel laminate would be the better solution for me? If there was a paint with similar reflectivity, why would the laminate be preferred? I fully intend to pursue the laminate solution, I'm just trying to learn more about the differences in options. Thanks, Doug | |||
| | #11 (Link) | ||||
Mainly because of your room being light controlled, the benefits of a white screen can easily be realized. And... there's no better DIY white screen than Wilsonart Designer White. Number wise anyways. If there is, I have yet to see it! ![]() mech mech Got questions? Start a thread. | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Remote controlled for curtains | ACGREEN | Home Theater Design and Construction | 0 | 12-03-07 11:36 PM |
| Light spillage -- how much with FP? | MikeSp | Home Theater Projectors | 6 | 08-13-07 05:15 PM |
| Help with new light engine???????? | joey28 | Video Displays and Processors | 1 | 05-25-07 05:24 AM |
| Looking for Light Engine Parts !!!!!!!!!!!! | joey28 | Classifieds - Audio Equipment | 1 | 04-28-07 10:11 PM |
| Remote Controlled Curtain System | wbassett | Projector Screens | DIY Screens | 2 | 02-11-07 01:09 PM |
