Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Real HT Info Podcast
RHTI 36: Adios Netflix Profiles, $50 Surround Sound, HDCP Broke My Movie, "Alpha Dog", Chris Smither
Discuss RHTI 36: Adios Netflix Profiles, $50 Surround Sound, HDCP Broke My Movie, "Alpha Dog", Chris Smither in the HD World | Computers | Games | Media forum; RHTI 36: Adios Netflix Profiles, $50 Surround Sound, HDCP Broke My Movie, "Alpha Dog", Chris Smither Episode 036 (6/23/2008) «» Netflix Kills Profiles on Sept 1 «» The Showcase: $50 Surround from JVC SXXSW6000 «» Troubleshooting ...
Views: 543 - Replies: 3
Old 06-22-08, 08:25 PM   #1
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
«» Troubleshooting answer: HDCP ate my movies.
«» Movie Review: Alpha Dog
«»Chris Smither: Leave the Light On
Old 07-01-08, 03:59 AM   #2
Alias: Steven
thewire's Avatar
Loc: lake ozarks MO
User: #9828
Since: Jun 2007
  thewire is offline
Re: RHTI 36: Adios Netflix Profiles, $50 Surround Sound, HDCP Broke My Movie, "Alpha Dog", Chris Smi
Some things I would try with the television might be to unplug - replug the set and player in several times. In order to get my HDCP enabled transcoder going, I have to unplug it for about 15 minutes, then restart the devices up to three times before they sync correctly. Before I would get nothing not even an image with wrong color signal.
After the sync is good, turning off the power to these devices completely (surge protectors off - no power) is alright and does not require a sync on next power up for some reason. This leads me to think that there is some kind of internal memory in a HDCP device that might be present to prevent tampering meaning perhaps the chip design holds some sort of digital stored info as opposed to all hardware. People would not be able to simply make a chip if they are unable to copy the internal language. This is just theory. Maybe the memory went corrupt and needs a reset of sorts kind of like emptying a cache. After all there is no mechanical on/off switch for HDCP so it has to store the on/off somewhere. There might be some kind of master reset on the television in some service menu normally not accessible. I don't see any actual support anywhere for the makers of HDCP chips on the web.
Edit: Not corrupt memory. They don't actually have a term for it unless you count "handshake issue" but it is actually a session of signals of both ends and one has "failed" to reset it seems.
# MDS. The audiovisual data is encoded into three Transition Minimized Differential Signaling (TMDS) data channels. These channels and a TMDS clock are carried over four differential pairs from the source to the sink.
# DDC. The Digital Display Channel (DDC) is a communications interface similar to I2C. This interface provides two-way communication in a master-slave relationship. The upstream device is the DDC master and the downstream device is the DDC slave.
# Hot Plug Detect. The sink indicates its presence to the source with the Hot Plug Detect (HPD) signal. The sink can toggle the Hot Plug Detect signal to reset the HDMI connection (and thus, the HDCP session).
# RxSense. Though not specifically defined by HDMI, many devices support a feature known as RxSense. There is no RxSense wire, but rather, sources can detect that a sink has terminated the TMDS differential pairs. Similarly to HPD, this signal can be used to detect the presence of a sink.
source - http://www.videsignline.com/showArti...leId=206800378
Old 07-01-08, 11:47 PM   #3
Alias: Steven
thewire's Avatar
Loc: lake ozarks MO
User: #9828
Since: Jun 2007
  thewire is offline
Sorry it doesn't work. Thought another try might be worth it.
Old 07-02-08, 08:05 AM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
I did try leaving it unplugged for a whole day, no luck. I'm wondering if there is some magic combination of key presses that will hard reset the thing..
I haven't been able to get on the phone with tech support during business hours (not that I'm hoping for a lot). I'll let you know the outcome when I do though.
« Home Theater Shack > HD World | Computers | Games | Media > Real HT Info Podcast »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
