Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Elite Screens offers the finest in affordable projection screens. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices ePVision.com: One-Stop place for High-end HDTV, Media hub in the box, Advanced ATSC/QAM/NTSC Tuner Receiver, Network HD Media Player and etc. Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. SVSound GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Home Theater Shack Stores Movie Stuff Vendors
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Remotes | Cables | Accessories | Tweaks
Views: 754 - Replies: 7
Old 02-17-10, 09:14 AM   #1
johnnyfamous's Avatar
johnny
Since: Jan 2009
canada Kelowna BC
  johnnyfamous is offline
subwoofer cable?? what wire
I have to tell you, its been frustrating to learn over the last year how much money i have wasted on fancy cables over the years. Sites like this are great learning tools. Thanks!
now the question, I am finishing off a DIY subwoofer build and I need a LFE RCA cable to connect to reciever.
I need about 30 feet and i would like the cable WHITE, need to run it along the basement ceiling and want it to blend in with the ceiling.
i went to the local cable supplier and they had a few choices,
rg6 the only one that was white.
rg59- is what they recomended for best signal quality
a couple versions of microphone cable- 2 wire, one was a thicker gauge.
i am good with solder so thats a non issue,
what would be the best cable?
what would be the potential issue if i went with the rg6? ,,, again because it was the only one that was white.
thanks for your insight!!
Old 02-17-10, 09:28 AM   #2
tonyvdb's Avatar
Tony
Since: Sep 2007
Edmonton, Alberta, Canada
My Photos
  tonyvdb is online now
Re: subwoofer cable?? what wire
Ether the rg6 or the rg59 would be just fine, High priced cables are just snake oil, and a normal decent (non skinny) rca cable in the length you need would also work just fine.
Home theater:
Onkyo TXSR805, Samson Servo 300 amp
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba A30, Panasonic BD60, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV, Nintendo Wii
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 02-18-10, 12:21 PM   #3
Shack Moderator
eugovector's Avatar
Marshall
Since: Sep 2006
Salem, OR
My Photos
  eugovector is offline
You could also get an f-connector to RCA style adapter and save yourself the soldering.
Old 02-18-10, 07:07 PM   #4
johnny
Since: Jan 2009
canada Kelowna BC
i need to run the line through a ceiling and walls , so i cant have ends on it, is a regular rca made of rg6? or 59? whats the best one? and what difference would it really make? not much i suspect?
if its a large or noticeble difference i will use what is best and not based on color alone??
thanks Guys!!
Old 02-18-10, 07:24 PM   #5
tonyvdb's Avatar
Tony
Since: Sep 2007
My Photos
johnnyfamous wrote: View Post
A regular rca is neither rg59 or rg6. Its closer to rg59 though and that would be more than ample for your use. Ive run video signals over rg59 over 1000ft without any problems.
Home theater:
Two Channel system:
My Webpage
Old 02-19-10, 08:02 AM   #6
johnny
Since: Jan 2009
canada Kelowna BC
thanks, would there be a preferance or whats the difference between a solid wire (rg6/59) versus a stranded mic cable for audio conections?
no diffence? does it just come down to shielding?
thanks,,, i promise i wont ask to many more questions
Old 02-19-10, 08:50 AM   #7
Shack Moderator
lsiberian's Avatar
lsiberian
Since: Mar 2009
Fort Worth, TX
My Photos
  lsiberian is offline
It's simply an electrical signal nothing more. Use whatever you like.
Old 02-20-10, 12:07 PM   #8
buzz
Since: Oct 2006
singapore
  buzztiger is offline
I have used Belden 1694a and lv77 for subwoofer. Both give a tight bass.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater | Audio | Video > Remotes | Cables | Accessories | Tweaks »
cable??, subwoofer, wire
Bookmark and Share
Massage Chairs   Wall Fountains   Bath Vanities   Electric Fireplaces
Dish Network
Search Engine Friendly URLs by vBSEO 3.3.2
