Been having issues with cables not holding up. Either audio goes out or the video does.
Currently looking at Blue Jeans Cable, for my next cables. Is this a smart choice, and do I need the silver plated leads.
Over priced, look at monoprice and buy one of theirs and you will be happy. What is the cause of the cables failing, are you constantly unplugging them?
Hey Mike. Is it a very old cable? What version is it (1.2, 1.3a, 1.3b, etc)? Is the A/V signal dropping in & out or going out all together? Aside from something being physically wrong with the cable it may be a bandwidth issue. I'm sure a Blue Jeans cable would be a fine upgrade.
Yes, some cables no matter how much they cost can have bandwidth issues especially over long runs, just because they are expensive does not always guarantee they will work for what you need, what you need to find is a low cost cable which has been fully tested and guaranteed to work over long runs, and it need not cost a fortune.
My first problem occurred when I had issues with my dvr tiling and audio breaking up and freezing the frame. Provider came out and said I would be better off with component cables. I have not had that issue since. After that I started messing around and realized the cable was bad.
My next and only other occurrence so far was with my blu ray. It has been working fine. (panasonic bdp60) Then it quite playing audio. Could be many things, but hoping the cable. only have two cables right now ( I really need or want 3) so without unplugging and rerouting and then I guess at least i might get audio through receiver ( don't know if I would actually need video going to tv .) Anyway in a big nutshell that is where I am at. I am sure I could keep going.
What led you to conclude the issue was with your cable?/QUOTE
After I realized the component cables were allowing better colors to be produced, and now more tiling issues.
Now as for the one with the blu ray player, I only have one other cable and it is leaving my receiver going to display. I guess I could take the one I think is bad and go from my set top box and see if I get sound out of it to tv
Now I am baffled. The other day put in a movie, no sound. this seemed unusual. Tried everything could not get it going. This evening I took the supposedly bad cable from my set top, I have sound. Put it back on my blu ray and I have sound, although with a different movie. Could one movie not allow sound thru hdmi or something else?????????
I may have to recant my complaint with my cables. I tinkered around a little more. The component inputs don't seem to be working on my Onkyo 606. It's about 4 months out of warranty. My on screen display seems to not be working either. Neither of which should be an issue, because I never use the component inputs anyway. But these symptoms could be associated with my sound issue. The presumed bad cable seems to be working fine now.
I found on avsforums that others are having similar issues, all have had their 606's about the same time frame or less.
I'm not sure with the 606 but dont you have top assign the inputs in the user menu of the Onkyo? I wonder if thats why the component inputs are not working.
did all of that. tried both comp. inputs on back with both my set top box and my blu. I am sure that I disabled the hdmi input at the same time I selected comp. for tv or blu. If I did not would the receiver automatically be looking for signal thru hdmi and not see the comp.????
With my set top if I have both the comp. and hdmi plugged it automatically goes out on the hdmi cable.
Although I have been watching tv with comp. direct to tv. Anywho just things I am going over in my brainhousing. Going to go do some further checks.
Related Threads
742.3K posts
170.9K members
Since 2006
